Home » Modeling » EMF » EMF Standalone Main Application
EMF Standalone Main Application [message #423907] Thu, 09 October 2008 10:05 Go to next message
I use my EMF Model which based on a XML-Schemata in a RCP and in a
Plug-in which can be run in command line as stand-alone application.
The Plug-in xyz.jar starts fine. But if i try to load my XML-File
i get a excption that the class
org/eclipse/emf/ecore/resource/resourceSet was not found.
Do i have to set a classpath ?
Here my manifest file:
Manifest-Version: 1.0
Main-Class: build.main.BuildMain
Bundle-ManifestVersion: 2
Bundle-Name: Build Plug-in
Bundle-SymbolicName: build
Bundle-Version: 2.1.8
Bundle-Activator: build.BuildPlugin
Bundle-Vendor: Manager
Require-Bundle: org.eclipse.ui,
org.eclipse.core.runtime,
build.plugin.monitor,
plugin.model,
org.eclipse.emf.common,
org.eclipse.emf.ecore.xmi
Bundle-RequiredExecutionEnvironment: J2SE-1.5
Bundle-ActivationPolicy: lazy
Export-Package: build.main
Bundle-ClassPath: src/libs/javaAPI.jar,
src/libs/jdom.jar,
src/libs/xerces.jar,
Re: EMF Standalone Main Application [message #423912 is a reply to message #423907] Thu, 09 October 2008 11:02 Go to previous messageGo to next message
An RCP application normally should be started as a proper Eclipse
application, not just by setting up the classpath. Maybe you need
org.eclipse.emf.ecore in the list below?
exquisitus wrote:
> Hi
> plugin.model,
> src/libs/jdom.jar,
Re: EMF Standalone Main Application [message #423983 is a reply to message #423912] Mon, 13 October 2008 09:18 Go to previous messageGo to next message
sorry didnt explain it correct i got three Plug-in
1. plugin.rcp
2. plugin.model
3. plugin.commandline
In my RCP plugin all works fine i can load, edit the Model. My
commandline plugin has a classic Java Main Application.
I want to load in the commandline plugin a XML-File and use therefor
i use my generated EMf model plugin.
So what do i have to enter in the MANIFEST.MF to run this?
> exquisitus wrote:
>> Hi
>> plugin.model,
>> src/libs/jdom.jar,
Re: EMF Standalone Main Application [message #423985 is a reply to message #423983] Mon, 13 October 2008 11:11 Go to previous messageGo to next message
You can look at the dependencies listed within each plugin when viewed
in the package explorer. You'll need those. You might also need
registrations that others happen because of plugin.xml processing.
> 1. plugin.rcp
> 2. plugin.model
> Thanks
>> exquisitus wrote:
>>> Hi
>>> plugin.model,
>>> src/libs/jdom.jar,
Re: EMF Standalone Main Application [message #424049 is a reply to message #423985] Wed, 15 October 2008 05:35 Go to previous messageGo to next message
I do not realy knwo what you mean with
you might also need registrations that others happen because of
To start my command line i put the following jar in a dirctory
plugin.model,
then i start the commandline plugin like this
java -jar plugin.model-jar load C:/testfile.xml
then i become the exception
>> 1. plugin.rcp
>> 2. plugin.model
>> Thanks
>>> exquisitus wrote:
>>>> Hi
>>>> plugin.model,
>>>> src/libs/jdom.jar,
Re: EMF Standalone Main Application [message #424086 is a reply to message #424049] Wed, 15 October 2008 20:14 Go to previous message
Comments below.
You really need to read about Eclipse extension points...
> plugin.model,
Where is org.eclipse.emf.ecore?
I should guess the exception?
If you invoke "Generate Test Code" and run the generated XyzExample.java
in the *.tests project as a standalone Java application, that should run
properly. Maybe that will be a good starting point...
>> viewed in the package explorer. You'll need those. You might also
>> need registrations that others happen because of plugin.xml processing.
>>> 1. plugin.rcp
>>> 2. plugin.model
>>> Thanks
>>>> exquisitus wrote:
>>>>> Hi
>>>>> plugin.model,
>>>>> src/libs/jdom.jar,
Previous Topic:Generating Edit Code into the Model Project
Next Topic:uma model editor - resource does not exist
Current Time: Wed Nov 05 04:37:41 EST 2025
Powered by FUDForum. Page generated in 0.03777 seconds
