Home » Modeling » EMF » feature change notification fails while using transactional editing domain
Re: feature change notification fails while using transactional editing domain [message #423799 is a reply to message #423784] |
Tue, 07 October 2008 11:09 |
Ed Merks Messages: 33142 Registered: July 2009 |
SeB,
I hate to ask just the obvious question, but is this state change being
executed in the context of a write transaction? It would appear not.
It seems to me such change should be produced by executing a command...
SeB.fr wrote:
> Hello,
> One of my model element "Plugin" as a feature "status" that is
> imlemented by me.
> This feature set's a user preference (java.util.prefs.Preferences) and
> reads it (see below).
> in the PluginImpl I call the following when I am notify of a change in
> the preference node
> if (eNotificationRequired()) {
> StatusType newStatus = isInstalled ? StatusType.INSTALLED :
> StatusType.NOTINSTALLED;
> StatusType oldStatus = isInstalled ? StatusType.NOTINSTALLED :
> StatusType.INSTALLED;
> eNotify(new ENotificationImpl(PluginImpl.this, Notification.SET,
> MiddlewaresPackage.PLUGIN__STATUS, oldStatus, newStatus));
> But this fails because (I think) I am using an
> transactionnalEditingDomain.
> Exception in thread "Thread-3" java.lang.IllegalStateException: Cannot
> modify resource set without a write transaction
> org.eclipse.emf.transaction.impl.TransactionChangeRecorder.a ssertWriting(TransactionChangeRecorder.java:322)
> org.eclipse.emf.transaction.impl.TransactionChangeRecorder.a ppendNotification(TransactionChangeRecorder.java:284)
> org.eclipse.emf.transaction.impl.TransactionChangeRecorder.p rocessObjectNotification(TransactionChangeRecorder.java:266)
> org.eclipse.emf.transaction.impl.TransactionChangeRecorder.n otifyChanged(TransactionChangeRecorder.java:222)
> org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify (BasicNotifierImpl.java:247)
> com.nds.france.mhdk.middlewares.model.middlewares.impl.Plugi nImpl$1.pluginInstallStateChanged(PluginImpl.java:162)
> com.nds.france.mhdk.ide.plugins.PluginLaunchableApp$PluginIn stallNodeListener.childAdded(PluginLaunchableApp.java:92)
> java.util.prefs.AbstractPreferences$EventDispatchThread.run( AbstractPreferences.java:1476)
> Do you have any idea on how to work around this problem, is this a bug ?
> Thank you.
> SeB.
> PS : the setStatus implementation
> * store the installed status in the user preference store provided by the
> * JRE
> public void setStatus(StatusType newStatus) {
> PluginLaunchableApp.setInstalled(getName(),
> StatusType.INSTALLED == newStatus);
> where
> public static void setInstalled(String name, boolean isInstalled) {
> if (name != null) {
> Preferences pluginsInstalledPrefs = PLUGIN_INSTALL_NODE.node(name);
> try {
> if (!isInstalled) {//remove the node
> pluginsInstalledPrefs.removeNode();
> }//else node created so nothing more to do
> pluginsInstalledPrefs.flush();
> } catch (BackingStoreException e) {
> IdePluginsPlugin.logErrorMessage(e);
Ed Merks
Re: feature change notification fails while using transactional editing domain [message #423806 is a reply to message #423799] |
Tue, 07 October 2008 11:43 |
Sébastien Gandon Messages: 184 Registered: July 2009 |
Hello Ed and others,
I probably did not make myself clear enought.
This feature is not persisted a file it is a Volatile because it reflects
a preference node in the Preference registry.
So when the preference node in the registry changes (I have attached a
listener), I would like the GUI being notified that the model value
changed so that it is updated.
This means there is not write transaction running, it is just a preference
listener that is notified of a change in the Preference node and then
fires the model eNotification.
More over in the model implementation we do not about the editing domain
being used.
I just want my table cell to reflect the model value itselft reflecting
the Preference node value.
Is it more clear?
SeB.
Ed Merks wrote:
> SeB,
> SeB.fr wrote:
>> Hello,
>> imlemented by me.
>> the preference node
>> Thank you.
>> SeB.
>> * JRE
>> where
>> if (name != null) {
>> try {
Re: feature change notification fails while using transactional editing domain [message #423809 is a reply to message #423806] |
Tue, 07 October 2008 12:01 |
SeB,
Comments below.
I don't always listen so well. :-P
> reflects a preference node in the Preference registry.
Volatile has no runtime meaning. In hindsight it should not have been
in the Ecore model at all. It's purely a code generation option...
Probably you intend it to be transient.
So from a transaction point of view, it looks like a write modification
and in fact it is.
> preference listener that is notified of a change in the Preference
> node and then fires the model eNotification.
You'll need one to make the transaction API happy.
> domain being used.
Not sure I follow.
> reflecting the Preference node value.
> Is it more clear?
Mostly. You'll still need a transaction to convince the transaction
APIs that this write access isn't a programming error.
> SeB.
> Ed Merks wrote:
>> SeB,
>> being executed in the context of a write transaction? It would
>> appear not. It seems to me such change should be produced by
>> SeB.fr wrote:
>>> Hello,
>>> imlemented by me.
>>> and reads it (see below).
>>> in the preference node
>>> Cannot modify resource set without a write transaction
>>> bug ?
>>> Thank you.
>>> SeB.
>>> by the
>>> * JRE
>>> where
>>> if (name != null) {
>>> try {
Ed Merks
Re: feature change notification fails while using transactional editing domain [message #423850 is a reply to message #423816] |
Wed, 08 October 2008 00:28 |
Originally posted by: cdamus.zeligsoft.com
Hi, SeB, Ed,
There isn't, currently, anything that you can just extend or override in
the Transaction API to exclude certain features from transaction
control. You could, in a custom implementation of the
TransactionalEditingDomain interface, implement a custom
TransactionChangeRecorder, but that would probably be difficult.
If all of the objects of some particular resource should be excluded
from transactions, then you could just remove the
TransactionChangeRecorder from the adapter-lists of it and its contents.
However, doing so eliminates the concerruncy controls that prevent
such phenomena as lost updates and dirty reads.
HTH,
Christian
Ed Merks wrote:
> SeB,
> Yes, you'd want to keep the two separate. Maybe there's some way by
> specializing some class in transaction framework to ignore notifications
> on certain features...
> SeB.fr wrote:
>> The problem is that the ecore framework does not know what is the
>> Editing Domain being used.
>> And I do not want Editing Domain api to be part of my model
>> implementation.
>> Is there any possible workaround ?
>> May I implement notification at the Edit level ?
>> I'll give a try.
>> SeB.
Re: feature change notification fails while using transactional editing domain [message #423908 is a reply to message #423850] |
Thu, 09 October 2008 14:24 |
Hi Christian, Ed,
That is what I did, I mean I sub-classed the
TransactionalEditingDomainImpl class in order to create a custom
TransactionChangeRecorder that filters out my feature.
This is quiet easy actually.
thanks fo your help.
SeB.
Christian W. Damus wrote:
> Hi, SeB, Ed,
> HTH,
> Christian
Re: feature change notification fails while using transactional editing domain [message #423909 is a reply to message #423908] |
Thu, 09 October 2008 14:58 |
Hi, Seb,
Good! I'm glad that it turned out so well for you, and especially that
it was easier than I had anticipated.
cW
SeB.fr wrote:
> Hi Christian, Ed,
> SeB.
>> Hi, SeB, Ed,
>> in the Transaction API to exclude certain features from transaction
>> contents. However, doing so eliminates the concerruncy controls that
>> prevent such phenomena as lost updates and dirty reads.
>> HTH,
>> Christian
Current Time: Fri Apr 26 21:12:51 GMT 2024
Powered by FUDForum. Page generated in 0.03606 seconds
