Home » Archived » XML Schema Definition (XSD) » Schema locations
Schema locations [message #42696] |
Thu, 29 April 2004 11:03 |
Originally posted by: invalid.soft-gems.net
Hi group,
Currently I'm trying to find a consistent solution to load an XML schema
together will all its imported, included and redefined schemas. Until now
I have two versions to load schemas. One loads a schema fine when it is
located in an Eclipse project (with relative path name). It can also load
the schema from the file system when given with absolute path.
XSDResourceImpl xsdSchemaResource = new XSDResourceImpl();
xsdSchemaResource.setURI(URI.createURI(schemaName));
InputStream stream =
getClass().getClassLoader().getResourceAsStream(schemaName);
if (stream == null)
stream = new FileInputStream(schemaName);
if (stream != null)
try
xsdSchemaResource.load(stream, null);
schemas.add(xsdSchemaResource.getSchema());
catch(Exception e)
The second one can load schemas from the file system when I specify the
file:// protocol.
URI uri = URI.createURI(schemaLocation);
ResourceSet resourceSet = new ResourceSetImpl();
XSDResourceImpl xsdResource =
(XSDResourceImpl)resourceSet.getResource(uri, true);
schemas.add(xsdResource.getSchema());
My problem is now: the second version also loads all included etc. schemas
so I have the full hierarchy (which is the final goal for me). But it does
only so when given an absolute file (or another valid URI I suppose,
haven't tried). It cannot load schemas from the resource of an Eclipse
project. The first version in contrast does not load included schemas, but
only loads the main file.
So my question is: How can I make a combined version so that regardless of
the actual location of the schema (URL, local file, resouce file -> maybe
in jar) the main schema file and all those, which are referenced by it (or
recursively by the others) are loaded successfully?
I already looked at the traceLoading sample code, which uses an URI map,
however this does not help for resource files. I would need stream support
for a generic solution, but I have not found any stream reference in the
documentation.
Mike
www.soft-gems.net
Re: Schema locations [message #42727 is a reply to message #42696] |
Thu, 29 April 2004 12:09 |
Mike,
For relative locations in a document to resolve, the URI of the document must
be an absolute URI. Have a look at XSDMainTest in org.eclipse.xsd.test to
see how it makes sure an input "path" is turned into an absolute URI.
For loading from a "class loader resource", use the URL returned by
getClass().getClassLoader().getResource(...) as the URI of the schema
resource. This should give you an absolute URI against which the relative
schemaLocation URIs can be resolved. Hopefully its a jar: scheme because zip:
doesn't work, I don't think. If it's zip:, please let me know.
Mike Lischke wrote:
> Hi group,
> if (stream == null)
> if (stream != null)
> try
> catch(Exception e)
> file:// protocol.
> documentation.
> Mike
> www.soft-gems.net
Re: Schema locations [message #42758 is a reply to message #42727] |
Thu, 29 April 2004 13:18 |
Since my include schema files can again include other schema files all
with relative file names, it seems I have to set up some URL mapping. Is
this correct?
This does suprisingly not work, simply because getResource() returns an
invalid file URL. It looks like:
file:D:/projects/.....
so the double slash is missing after the protocol and hence
URIConverterImpl.createInputStream does not find the file. As I can't
imagine that this is a bug I supposed there must be something missing on
my side. But what?
Yes, it will be a jar once I have finished development. Until then it is
just a file in one of my Eclipse projects.
Thank you for your help Ed.
Mike
www.soft-gems.net
Re: Schema locations [message #42789 is a reply to message #42758] |
Thu, 29 April 2004 14:03 |
Mike,
No you shouldn't need to do anything fancy like a URI map. As long as the URI of
the resource is a proper hierarchical absolute URI, relative locations will resolve
properly and find the right absolute resources. For a URI to be hierarchical,
according to the RFC (see javadoc for our URI class), the scheme must be followed
by a "/" (and to be absolute there must be a scheme.). So this file:D: thing is
bogus. You should "massage" the URL you get to not be bogus and then all should
work well...
> this correct?
> my side. But what?
> Mike
> www.soft-gems.net
Re: Schema locations [message #42883 is a reply to message #42789] |
Fri, 30 April 2004 06:57 |
> work well...
Yep, works great. Thanks!
Mike
www.soft-gems.net
Re: Schema locations [message #54045 is a reply to message #42696] |
Thu, 14 October 2004 04:40 |
Originally posted by: wtrichards.bigpond.com
Mike,
I saw that you have been discussing xsd on the news group. I am new to =
the Schema Infoset and an having some problems opening a file from a =
file. I have the follwoing method and continuelly get exceptions when =
trying to be the Resource. I was wounder if you have the time could you =
look at my method and provide some guidence.
private static XSDSchema loadXSDSchema(File xsdFile) {
String schemaName = xsdFile.getPath();
try {
URI uri = URI.createURI(schemaName);
XSDSchema resultSchema = xsdResource.getSchema();
} catch (Exception e) {
e.printStackTrace();
return null;
the exception is:
java.lang.RuntimeException: Cannot create a resource for =
'E:\DublinCore1.xsd'; a registered resource factory is needed
at =
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceS=
etImpl.java:282)
at =
schemaHandler.schemaDocumentHandler.loadXSDSchema(schemaDocu mentHandler.j=
ava:26)
at =
schemaHandler.schemaDocumentHandler.getGlobalElements(schema DocumentHandl=
er.java:35)
at xmlProcessing.xmlUI$1.widgetSelected(xmlUI.java:171)
=org.eclipse.swt.widgets.TypedListener.handleEvent(TypedList ener.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2772)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2431)
at xmlProcessing.xmlUI.main(xmlUI.java:257)
Any help would be appreciated.
Wayne
Mike Lischke wrote:
> Hi group,
> if (stream == null)
> if (stream != null)
> try
> catch(Exception e)
> file:// protocol.
> documentation.
> Mike
> www.soft-gems.net
Re: Schema locations [message #54072 is a reply to message #54045] |
Thu, 14 October 2004 10:43 |
--------------070403080103000103000208
Wayne,
A file system path is not a URI and the "\" character is not treated as
"/" in a URI. If you have a file path, use URI.createFileURI to convert
it to a proper URI. E.g., E:\DublinCore1.xsd should be
file:/E:/DublinCore.xsd
Wayne wrote:
>Mike,
> try {
> return null;
>the exception is:
>at =
>etImpl.java:282)
>at =
>ava:26)
>at =
>er.java:35)
>at
>Regards
>Wayne
>Mike Lischke wrote:
>>Hi group,
>> if (stream == null)
>> if (stream != null)
>> try
>> catch(Exception e)
>>file:// protocol.
>>documentation.
>>Mike
>>www.soft-gems.net
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Wayne,<br>
<br>
"/" in a URI.
Re: Schema locations [message #55925 is a reply to message #54072] |
Mon, 06 December 2004 11:58 |
Originally posted by: ooi.de.ibm.com
Hi!
I've tried using the URI.createFileURI instead of URI.createURI and i got
the following exception:
'file:/C:/workspace/eCute4ODI/import/wsrf-WS-ResourcePropert ies-1.2-draft-01.xsd';
what could be the problem?
Ed Merks wrote:
> Wayne,
> A file system path is not a URI and the "" character is not treated as
> it to a proper URI. E.g., E:DublinCore1.xsd should be
> Wayne wrote:
>>Mike,
>> try {
>> return null;
>>the exception is:
>>'E:DublinCore1.xsd'; a registered resource factory is needed
>>at =
>>etImpl.java:282)
>>at =
>>ava:26)
>>at =
>>er.java:35)
>>at
>>Regards
>>Wayne
>>Mike Lischke wrote:
>>>Hi group,
>>> if (stream == null)
>>> if (stream != null)
>>> try
>>> catch(Exception e)
>>>file:// protocol.
>>>documentation.
>>>Mike
>>>www.soft-gems.net
Re: Schema locations [message #55941 is a reply to message #55925] |
Mon, 06 December 2004 12:20 |
--------------000708030101030107000501
HT,
I think you get this not matter how you create the URI since it sounds
like you are running standalone and still need to do:
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put
("xsd", new XSDResourceFactoryImpl());
HT Ooi wrote:
> Hi!
> got the following exception:
> Ed Merks wrote:
>> Wayne,
>> as "/" in a URI. If you have a file path, use URI.createFileURI to
>> convert it to a proper URI. E.g., E:DublinCore1.xsd should be
>> Wayne wrote:
>>> Mike,
>>> to =
>>> you =
>>> try {
>>> return null;
>>> the exception is:
>>> at =
>>> etImpl.java:282)
>>> at =
>>> ava:26)
>>> at =
>>> er.java:35)
>>> at
>>> Regards
>>> Wayne
>>> Mike Lischke wrote:
>>>> Hi group,
>>>> schema
>>>> Until now
>>>> it is
>>>> also load
>>>> if (stream == null)
>>>> if (stream != null)
>>>> try
>>>> catch(Exception e)
>>>> the
>>>> file:// protocol.
>>>> schemas
>>>> it does
>>>> schemas, but
>>>> regardless of
>>>> maybe
>>>> it (or
>>>> map,
>>>> support
>>>> in the
>>>> documentation.
>>>> Mike
>>>> www.soft-gems.net
<html>
<head>
</head>
HT,<br>
<br>
like you are running standalone and still need to do:<br>
<blockquote> resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put <br>
Re: Schema locations [message #57821 is a reply to message #55941] |
Thu, 17 February 2005 09:42 |
Originally posted by: johan.naudts.ing.be
I am currently facing a similar problem, but ONLY when running inside a
Web application server (WebSphere v5.1 in this case). This is a summary
the Exception I'm getting:
'wsjar:file:/E:/Wta/Workspace/WEB WTA BROWSER
TEST/WebContent/WEB-INF/lib/xsd.resources.jar!/org/eclipse/x sd/plugin.properties/cache/www.w3.org/2001/MagicXMLSchema.xs d';
[17/02/05 9:34:07:692 CET] 59cceede SystemErr R at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:343)
org.eclipse.xsd.impl.XSDSchemaImpl.getMagicSchemaForSchema(X SDSchemaImpl.java:534)
org.eclipse.xsd.impl.XSDSchemaImpl.getSchemaForSchema(XSDSch emaImpl.java:611)
org.eclipse.xsd.impl.XSDSchemaImpl.createSchema(XSDSchemaImp l.java:420)
org.eclipse.xsd.util.XSDResourceImpl.handleSchemaElement(XSD ResourceImpl.java:518)
org.eclipse.xsd.util.XSDResourceImpl.findSchemas(XSDResource Impl.java:484)
[17/02/05 9:34:07:708 CET] 59cceede SystemErr R at
org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:413)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:884)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:741)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:247)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:262)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:346)
test.XsdOnlineContentParser.loadSchemaUsingResourceSet(XsdOn lineContentParser.java:109)
at org.eclipse.xsd.impl.XSDSchemaImpl.patch(XSDSchemaImpl.java: 1475)
org.eclipse.xsd.impl.XSDSchemaImpl.changeAttribute(XSDSchema Impl.java:2234)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDCon creteComponentImpl.java:1202)
org.eclipse.xsd.impl.XSDSchemaImpl.setSchemaLocation(XSDSche maImpl.java:827)
at org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:471)
test.XsdOnlineContentParser.getSigningEnvelopeFields(XsdOnli neContentParser.java:54)
at org.apache.jsp._TestXsdParser._jspService(_TestXsdParser.jav a:80)
com.ibm.ws.webcontainer.jsp.runtime.HttpJspBase.service(Http JspBase.java:89)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
com.ibm.ws.webcontainer.jsp.servlet.JspServlet$JspServletWra pper.service(JspServlet.java:344)
com.ibm.ws.webcontainer.jsp.servlet.JspServlet.serviceJspFil e(JspServlet.java:662)
com.ibm.ws.webcontainer.jsp.servlet.JspServlet.service(JspSe rvlet.java:760)
com.ibm.ws.webcontainer.servlet.StrictServletInstance.doServ ice(StrictServletInstance.java:110)
com.ibm.ws.webcontainer.servlet.StrictLifecycleServlet._serv ice(StrictLifecycleServlet.java:174)
com.ibm.ws.webcontainer.servlet.IdleServletState.service(Str ictLifecycleServlet.java:313)
com.ibm.ws.webcontainer.servlet.StrictLifecycleServlet.servi ce(StrictLifecycleServlet.java:116)
com.ibm.ws.webcontainer.servlet.ServletInstance.service(Serv letInstance.java:283)
com.ibm.ws.webcontainer.servlet.ValidServletReferenceState.d ispatch(ValidServletReferenceState.java:42)
com.ibm.ws.webcontainer.servlet.ServletInstanceReference.dis patch(ServletInstanceReference.java:40)
com.ibm.ws.webcontainer.webapp.WebAppRequestDispatcher.handl eWebAppDispatch(WebAppRequestDispatcher.java:974)
com.ibm.ws.webcontainer.webapp.WebAppRequestDispatcher.dispa tch(WebAppRequestDispatcher.java:555)
com.ibm.ws.webcontainer.webapp.WebAppRequestDispatcher.forwa rd(WebAppRequestDispatcher.java:200)
com.ibm.ws.webcontainer.srt.WebAppInvoker.doForward(WebAppIn voker.java:119)
com.ibm.ws.webcontainer.srt.WebAppInvoker.handleInvocationHo ok(WebAppInvoker.java:276)
com.ibm.ws.webcontainer.cache.invocation.CachedInvocation.ha ndleInvocation(CachedInvocation.java:71)
com.ibm.ws.webcontainer.srp.ServletRequestProcessor.dispatch ByURI(ServletRequestProcessor.java:182)
com.ibm.ws.webcontainer.oselistener.OSEListenerDispatcher.se rvice(OSEListener.java:334)
com.ibm.ws.webcontainer.http.HttpConnection.handleRequest(Ht tpConnection.java:56)
com.ibm.ws.http.HttpConnection.readAndHandleRequest(HttpConn ection.java:618)
at com.ibm.ws.http.HttpConnection.run(HttpConnection.java:439)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:593)
This is an excerpt from my code:
// Register resource factory first
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "xsd",
// Create a resource set and load the main schema file into it.
resourceSet.getLoadOptions().put(XSDResourceImpl.XSD_TRACK_L OCATION,
Boolean.TRUE);
URI uri = URI.createURI(schemaURL);
Resource res = resourceSet.getResource(uri, true);
XSDResourceImpl xsdSchemaResource = (XSDResourceImpl)res;
The schemaURL = "file:/E:/Wta/Workspace/WEB WTA BROWSER TEST/XSD
Files/IngSigEnvSchema.xsd"
But again: when running standalone with exactly the same code, I don't
have this problem, so it seems to me that, inside of a servlet/JSP
container, XSD has difficulties locating some necessary files?
Can anyone help?
Thanks!
Johan
Ed Merks wrote:
> HT,
> HT Ooi wrote:
>> Hi!
>> Ed Merks wrote:
>>> Wayne,
>>> Wayne wrote:
>>>> Mike,
>>>> to =
>>>> you =
>>>> try {
>>>> return null;
>>>> the exception is:
>>>> at =
>>>> etImpl.java:282)
>>>> at =
>>>> ava:26)
>>>> at =
>>>> er.java:35)
>>>> at
>>>> Regards
>>>> Wayne
>>>> Mike Lischke wrote:
>>>>> Hi group,
>>>>> schema
>>>>> Until now
>>>>> it is
>>>>> also load
>>>>> if (stream == null)
>>>>> if (stream != null)
>>>>> try
>>>>> catch(Exception e)
>>>>> the
>>>>> file:// protocol.
>>>>> schemas
>>>>> it does
>>>>> schemas, but
>>>>> regardless of
>>>>> maybe
>>>>> it (or
>>>>> map,
>>>>> support
>>>>> in the
>>>>> documentation.
>>>>> Mike
>>>>> www.soft-gems.net
Re: Schema locations [message #57849 is a reply to message #57821] |
Thu, 17 February 2005 11:48 |
--------------090006050408040801080308
Johan,
Only "zip" and "jar" are recognized as archive schemes by
org.eclipse.emf.common.util.URI by default but some JRE sometimes use
other schemes in their class loaders, such as "wsjar". If you define
the system property "org.eclipse.emf.common.util.URI.archiveSchemes" to
be "jar zip *wsjar*" it should work correctly because of this code in
the URI class:
// Static initializer for archiveSchemes.
static
Set set = new HashSet();
String propertyValue =
System.getProperty("org.eclipse.emf.common.util.URI.archiveSchemes ");
if (propertyValue == null)
set.add(SCHEME_JAR);
set.add(SCHEME_ZIP);
else
for (StringTokenizer t = new StringTokenizer(propertyValue);
t.hasMoreTokens(); )
set.add(t.nextToken().toLowerCase());
archiveSchemes = Collections.unmodifiableSet(set);
Johan Naudts wrote:
> a Web application server (WebSphere v5.1 in this case). This is a
> summary the Exception I'm getting:
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Boolean.TRUE);
> Can anyone help?
> Thanks!
> Johan
> Ed Merks wrote:
>> HT,
>> sounds like you are running standalone and still need to do:
>> HT Ooi wrote:
>>> Hi!
>>> i got the following exception:
>>> Ed Merks wrote:
>>>> Wayne,
>>>> Wayne wrote:
>>>>> Mike,
>>>>> new to =
>>>>> a =
>>>>> when =
>>>>> could you =
>>>>> try {
>>>>> return null;
>>>>> the exception is:
>>>>> at =
>>>>> etImpl.java:282)
>>>>> at =
>>>>> ava:26)
>>>>> at =
>>>>> er.java:35)
>>>>> at
>>>>> at
>>>>> Regards
>>>>> Wayne
>>>>> Mike Lischke wrote:
>>>>>> Hi group,
>>>>>> schema
>>>>>> Until now
>>>>>> it is
>>>>>> also load
>>>>>> if (stream == null)
>>>>>> if (stream != null)
>>>>>> try
>>>>>> catch(Exception e)
>>>>>> specify the
>>>>>> file:// protocol.
>>>>>> etc. schemas
>>>>>> But it does
>>>>>> Eclipse
>>>>>> schemas, but
>>>>>> regardless of
>>>>>> -> maybe
>>>>>> by it (or
>>>>>> URI map,
>>>>>> stream support
>>>>>> in the
>>>>>> documentation.
>>>>>> Mike
>>>>>> www.soft-gems.net
<html>
<head>
<title></title>
</head>
Johan,<br>
<br>
Re: Schema locations [message #57929 is a reply to message #57849] |
Mon, 21 February 2005 13:25 |
Dear Ed,
that seems to solve it BUT.... now I get a NullPointerException, caused by
a ClassCastException:
[21/02/05 14:21:08:761 CET] 1e50aa55 SystemErr R
[21/02/05 14:21:08:776 CET] 1e50aa55 SystemErr R at
org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl.handleNewB aseTypeDefinition(XSDComplexTypeDefinitionImpl.java:2035)
org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl.handleReco nciliation(XSDComplexTypeDefinitionImpl.java:2296)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.reconcileConte nts(XSDConcreteComponentImpl.java:1018)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.reconcile(XSDC oncreteComponentImpl.java:952)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.elementChanged (XSDConcreteComponentImpl.java:399)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.adoptContent(X SDConcreteComponentImpl.java:1348)
org.eclipse.xsd.impl.XSDSchemaImpl.adoptContent(XSDSchemaImp l.java:1725)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDCon creteComponentImpl.java:1125)
org.eclipse.emf.common.notify.impl.NotificationChainImpl.dis patch(NotificationChainImpl.java:115)
org.eclipse.emf.common.notify.impl.NotificationChainImpl.dis patch(NotificationChainImpl.java:103)
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java(Compiled
Code))
org.eclipse.emf.common.util.BasicEList.add(BasicEList.java(C ompiled Code))
org.eclipse.xsd.impl.XSDConcreteComponentImpl.setListContent AndOrder(XSDConcreteComponentImpl.java:2075)
org.eclipse.xsd.impl.XSDSchemaImpl.handleReconciliation(XSDS chemaImpl.java:1947)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.changeAttribut e(XSDConcreteComponentImpl.java:1232)
org.eclipse.xsd.impl.XSDSchemaImpl.changeAttribute(XSDSchema Impl.java:2245)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDCon creteComponentImpl.java:1205)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.setElementGen( XSDConcreteComponentImpl.java:2797)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.setElement(XSD ConcreteComponentImpl.java:2829)
org.eclipse.xsd.impl.XSDSchemaImpl.setElement(XSDSchemaImpl. java:2368)
org.eclipse.xsd.impl.XSDSchemaImpl.createSchema(XSDSchemaImp l.java:442)
org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:348)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:881)
[21/02/05 14:21:08:792 CET] 1e50aa55 SystemErr R at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:755)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:220)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:286)
com.ing.web.security.wta.browser.onlinecontent.xsd.XsdOnline ContentParser.loadSchemaUsingResourceSet(XsdOnlineContentPar ser.java:112)
com.ing.web.security.wta.browser.onlinecontent.xsd.XsdOnline ContentParser.getOnlineContentFields(XsdOnlineContentParser. java:61)
com.ing.web.security.wta.browser.onlinecontent.xsd.OnlineCon tentFactory.getOnlineContentFields(OnlineContentFactory.java :54)
com.ing.web.security.wta.browser.service.OnlineContentServic e.lookupOnlineContentFields(OnlineContentService.java:64)
com.ing.web.security.wta.browser.action.OnlineContentBrowser Action.displaySearchFields(OnlineContentBrowserAction.java:7 2)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:79)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:41)
java.lang.reflect.Method.invoke(Method.java:386)
org.apache.struts.actions.DispatchAction.dispatchMethod(Disp atchAction.java:280)
org.apache.struts.actions.LookupDispatchAction.execute(Looku pDispatchAction.java:252)
org.apache.struts.action.RequestProcessor.processActionPerfo rm(RequestProcessor.java:484)
org.apache.struts.action.RequestProcessor.process(RequestPro cessor.java:274)
org.apache.struts.action.ActionServlet.process(ActionServlet .java:1482)
org.apache.struts.action.ActionServlet.doPost(ActionServlet. java:525)
javax.servlet.http.HttpServlet.service(HttpServlet.java:760)
[21/02/05 14:21:08:808 CET] 1e50aa55 SystemErr R at
com.ibm.ws.webcontainer.cache.invocation.CacheableInvocation Context.invoke(CacheableInvocationContext.java:114)
com.ibm.ws.webcontainer.srp.ServletRequestProcessor.dispatch ByURI(ServletRequestProcessor.java:186)
java.lang.ClassCastException:
org.eclipse.emf.ecore.xmi.impl.XMIResourceImpl
org.eclipse.xsd.impl.XSDSchemaImpl.getSchemaInstance(XSDSche maImpl.java:713)
org.eclipse.xsd.impl.XSDSchemaImpl.resolveSchema(XSDSchemaIm pl.java:2040)
org.eclipse.xsd.impl.XSDSchemaImpl.patch(XSDSchemaImpl.java: 1485)
org.eclipse.xsd.impl.XSDSchemaImpl.changeAttribute(XSDSchema Impl.java:2241)
org.eclipse.xsd.impl.XSDSchemaImpl.setSchemaLocation(XSDSche maImpl.java:842)
org.eclipse.xsd.util.XSDResourceImpl.attached(XSDResourceImp l.java:410)
org.eclipse.emf.ecore.resource.impl.ResourceImpl$ContentsELi st.inverseAdd(ResourceImpl.java:326)
Code))
org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:374)
[21/02/05 14:21:08:823 CET] 1e50aa55 SystemErr R at
Any ideas?
Johan
Ed Merks wrote:
> Johan,
> the URI class:
> static
> else
> Johan Naudts wrote:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Boolean.TRUE);
>> Can anyone help?
>> Thanks!
>> Johan
>> Ed Merks wrote:
>>> HT,
>>> HT Ooi wrote:
>>>> Hi!
>>>> Ed Merks wrote:
>>>>> Wayne,
>>>>> Wayne wrote:
>>>>>> Mike,
>>>>>> new to =
>>>>>> a =
>>>>>> when =
>>>>>> could you =
>>>>>> try {
>>>>>> return null;
>>>>>> the exception is:
>>>>>> at =
>>>>>> etImpl.java:282)
>>>>>> at =
>>>>>> ava:26)
>>>>>> at =
>>>>>> er.java:35)
>>>>>> at
>>>>>> at
>>>>>> Regards
>>>>>> Wayne
>>>>>> Mike Lischke wrote:
>>>>>>> Hi group,
>>>>>>> schema
>>>>>>> Until now
>>>>>>> it is
>>>>>>> also load
>>>>>>> if (stream == null)
>>>>>>> if (stream != null)
>>>>>>> try
>>>>>>> catch(Exception e)
>>>>>>> specify the
>>>>>>> file:// protocol.
>>>>>>> etc. schemas
>>>>>>> But it does
>>>>>>> Eclipse
>>>>>>> schemas, but
>>>>>>> regardless of
>>>>>>> -> maybe
>>>>>>> by it (or
>>>>>>> URI map,
>>>>>>> stream support
>>>>>>> in the
>>>>>>> documentation.
>>>>>>> Mike
>>>>>>> www.soft-gems.net
Re: Schema locations [message #57956 is a reply to message #57929] |
Mon, 21 February 2005 14:47 |
Johan,
The first exception looks like what would happen if the global schema
for schema can't be loaded and the second exception looks like the
global schema was loaded with an XMIResourceImpl instead of an
XSDResourceImpl and hence failed to load. Both these problems are
likely caused by the use of a scheme other than jar: or zip: in the
classpath.
Johan Naudts wrote:
> Dear Ed,
> caused by a ClassCastException:
> Code))
> Code))
> Code))
> Code))
> Any ideas?
> Thanks
> Johan
> Ed Merks wrote:
>> Johan,
>> to be "jar zip *wsjar*" it should work correctly because of this code
>> in the URI class:
>> static
>> else
>> Johan Naudts wrote:
>>> Hi,
>>> inside a Web application server (WebSphere v5.1 in this case). This
>>> is a summary the Exception I'm getting:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Boolean.TRUE);
>>> don't have this problem, so it seems to me that, inside of a
>>> servlet/JSP container, XSD has difficulties locating some necessary
>>> files?
>>> Can anyone help?
>>> Thanks!
>>> Johan
>>> Ed Merks wrote:
>>>> HT,
>>>> HT Ooi wrote:
>>>>> Hi!
>>>>> and i got the following exception:
>>>>> Ed Merks wrote:
>>>>>> Wayne,
>>>>>> treated as "/" in a URI. If you have a file path, use
>>>>>> URI.createFileURI to convert it to a proper URI. E.g.,
>>>>>> E:DublinCore1.xsd should be file:/E:/DublinCore.xsd
>>>>>> Wayne wrote:
>>>>>>> Mike,
>>>>>>> new to =
>>>>>>> from a =
>>>>>>> when =
>>>>>>> could you =
>>>>>>> try {
>>>>>>> return null;
>>>>>>> the exception is:
>>>>>>> at =
>>>>>>> etImpl.java:282)
>>>>>>> at =
>>>>>>> ava:26)
>>>>>>> at =
>>>>>>> er.java:35)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> Regards
>>>>>>> Wayne
>>>>>>> Mike Lischke wrote:
>>>>>>>> Hi group,
>>>>>>>> XML schema
>>>>>>>> Until now
>>>>>>>> when it is
>>>>>>>> also load
>>>>>>>> if (stream == null)
>>>>>>>> if (stream != null)
>>>>>>>> try
>>>>>>>> catch(Exception e)
>>>>>>>> specify the
>>>>>>>> file:// protocol.
>>>>>>>> etc. schemas
>>>>>>>> But it does
>>>>>>>> suppose,
>>>>>>>> Eclipse
>>>>>>>> schemas, but
>>>>>>>> regardless of
>>>>>>>> file -> maybe
>>>>>>>> URI map,
>>>>>>>> stream support
>>>>>>>> reference in the
>>>>>>>> documentation.
>>>>>>>> Mike
>>>>>>>> www.soft-gems.net
Re: Schema locations [message #58108 is a reply to message #57956] |
Thu, 24 February 2005 08:05 |
Dear Ed,
if I unzip xsd.resources.jar and put the directory structure in my
classpath, it works fine. So it looks as if WebSphere can't seem to solve
some resources when zipped. Could that be the reason?
thanks
Johan
Ed Merks wrote:
> Johan,
> classpath.
> Johan Naudts wrote:
>> Dear Ed,
>> Code))
>> Code))
>> Code))
>> Code))
>> Any ideas?
>> Thanks
>> Johan
>> Ed Merks wrote:
>>> Johan,
>>> in the URI class:
>>> static
>>> else
>>> Johan Naudts wrote:
>>>> Hi,
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Boolean.TRUE);
>>>> files?
>>>> Can anyone help?
>>>> Thanks!
>>>> Johan
>>>> Ed Merks wrote:
>>>>> HT,
>>>>> HT Ooi wrote:
>>>>>> Hi!
>>>>>> Ed Merks wrote:
>>>>>>> Wayne,
>>>>>>> Wayne wrote:
>>>>>>>> Mike,
>>>>>>>> new to =
>>>>>>>> from a =
>>>>>>>> when =
>>>>>>>> could you =
>>>>>>>> try {
>>>>>>>> return null;
>>>>>>>> the exception is:
>>>>>>>> at =
>>>>>>>> etImpl.java:282)
>>>>>>>> at =
>>>>>>>> ava:26)
>>>>>>>> at =
>>>>>>>> er.java:35)
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> Regards
>>>>>>>> Wayne
>>>>>>>> Mike Lischke wrote:
>>>>>>>>> Hi group,
>>>>>>>>> XML schema
>>>>>>>>> Until now
>>>>>>>>> when it is
>>>>>>>>> also load
>>>>>>>>> if (stream == null)
>>>>>>>>> if (stream != null)
>>>>>>>>> try
>>>>>>>>> catch(Exception e)
>>>>>>>>> specify the
>>>>>>>>> file:// protocol.
>>>>>>>>> etc. schemas
>>>>>>>>> But it does
>>>>>>>>> suppose,
>>>>>>>>> Eclipse
>>>>>>>>> schemas, but
>>>>>>>>> regardless of
>>>>>>>>> file -> maybe
>>>>>>>>> URI map,
>>>>>>>>> stream support
>>>>>>>>> reference in the
>>>>>>>>> documentation.
>>>>>>>>> Mike
>>>>>>>>> www.soft-gems.net
Re: Schema locations [message #58182 is a reply to message #58108] |
Thu, 24 February 2005 11:05 |
--------------010902070605020909020208
Johan,
I believe it's still caused by WebSphere using wsjar for the things on
the classpath and the xsd.resources.jar will be on the classpath. You
earlier showed this trace:
If wsjar is not configured to be recognized as an archive scheme, this
URI will be treated as opaque. (The RFC http://www.ietf.org/rfc/rfc2396.txt
defines this term; a URI is opaque if the schema is not followed by a
/.) An opaque URI has no file extension so the .xsd in the name is not
recognized and the XSDResourceFactory is not used, resulting in either
no factory for standalone or an XMIResourceFactory for Eclipse/headless
being used.
Are you sure you've set the system property to configure the archive
schemes? All symptoms still seem to indicate you've not...
Johan Naudts wrote:
> Dear Ed,
> solve some resources when zipped. Could that be the reason?
> thanks
> Johan
> Ed Merks wrote:
>> Johan,
>> classpath.
>> Johan Naudts wrote:
>>> Dear Ed,
>>> Code))
>>> Code))
>>> Code))
>>> Code))
>>> Any ideas?
>>> Thanks
>>> Johan
>>> Ed Merks wrote:
>>>> Johan,
>>>> use other schemes in their class loaders, such as "wsjar". If you
>>>> define the system property
>>>> "org.eclipse.emf.common.util.URI.archiveSchemes" to be "jar zip
>>>> *wsjar*" it should work correctly because of this code in the URI
>>>> class:
>>>> static
>>>> else
>>>> Johan Naudts wrote:
>>>>> Hi,
>>>>> This is a summary the Exception I'm getting:
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> it.
>>>>> Boolean.TRUE);
>>>>> necessary files?
>>>>> Can anyone help?
>>>>> Thanks!
>>>>> Johan
>>>>> Ed Merks wrote:
>>>>>> HT,
>>>>>> HT Ooi wrote:
>>>>>>> Hi!
>>>>>>> Ed Merks wrote:
>>>>>>>> Wayne,
>>>>>>>> Wayne wrote:
>>>>>>>>> Mike,
>>>>>>>>> am new to =
>>>>>>>>> from a =
>>>>>>>>> exceptions when =
>>>>>>>>> could you =
>>>>>>>>> try {
>>>>>>>>> return null;
>>>>>>>>> the exception is:
>>>>>>>>> at =
>>>>>>>>> etImpl.java:282)
>>>>>>>>> at =
>>>>>>>>> ava:26)
>>>>>>>>> at =
>>>>>>>>> er.java:35)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> Regards
>>>>>>>>> Wayne
>>>>>>>>> Mike Lischke wrote:
>>>>>>>>>> Hi group,
>>>>>>>>>> XML schema
>>>>>>>>>> schemas. Until now
>>>>>>>>>> when it is
>>>>>>>>>> can also load
>>>>>>>>>> if (stream == null)
>>>>>>>>>> if (stream != null)
>>>>>>>>>> try
>>>>>>>>>> catch(Exception e)
>>>>>>>>>> specify the
>>>>>>>>>> file:// protocol.
>>>>>>>>>> etc. schemas
>>>>>>>>>> me). But it does
>>>>>>>>>> suppose,
>>>>>>>>>> an Eclipse
>>>>>>>>>> schemas, but
>>>>>>>>>> regardless of
>>>>>>>>>> file -> maybe
>>>>>>>>>> an URI map,
>>>>>>>>>> stream support
>>&g
Re: Schema locations [message #58258 is a reply to message #58182] |
Fri, 25 February 2005 13:07 |
Ed,
I am sure I set the system property in the WebSphere server configuration.
It will be passed as a "-D" parameter at startup. Apparently it doesn't
change anything. Is there any way I could set this parameter
programmatically instead of passing it as a system property?
Johan
Ed Merks wrote:
> Johan,
> being used.
> Johan Naudts wrote:
>> Dear Ed,
>> thanks
>> Johan
>> Ed Merks wrote:
>>> Johan,
>>> classpath.
>>> Johan Naudts wrote:
>>>> Dear Ed,
>>>> Code))
>>>> Code))
>>>> Code))
>>>> Code))
>>>> Any ideas?
>>>> Thanks
>>>> Johan
>>>> Ed Merks wrote:
>>>>> Johan,
>>>>> class:
>>>>> static
>>>>> else
>>>>> Johan Naudts wrote:
>>>>>> Hi,
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> it.
>>>>>> Boolean.TRUE);
>>>>>> necessary files?
>>>>>> Can anyone help?
>>>>>> Thanks!
>>>>>> Johan
>>>>>> Ed Merks wrote:
>>>>>>> HT,
>>>>>>> HT Ooi wrote:
>>>>>>>> Hi!
>>>>>>>> Ed Merks wrote:
>>>>>>>>> Wayne,
>>>>>>>>> Wayne wrote:
>>>>>>>>>> Mike,
>>>>>>>>>> am new to =
>>>>>>>>>> from a =
>>>>>>>>>> exceptions when =
>>>>>>>>>> could you =
>>>>>>>>>> try {
>>>>>>>>>> return null;
>>>>>>>>>> the exception is:
>>>>>>>>>> at =
>>>>>>>>>> etImpl.java:282)
>>>>>>>>>> at =
>>>>>>>>>> ava:26)
>>>>>>>>>> at =
>>>>>>>>>> er.java:35)
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> Regards
>>>>>>>>>> Wayne
>>>>>>>>>> Mike Lischke wrote:
>>>>>>>>>>> Hi group,
>>>>>>>>>>> XML schema
>>>>>>>>>>> schemas. Until now
>>>>>>>>>>> when it is
Re: Schema locations [message #58310 is a reply to message #58258] |
Fri, 25 February 2005 17:32 |
--------------020804030907080609060000
Johan,
Setting a breakpoint in the URI code that does this will help, if that's
possible to do
static
else
You should be able to set this with System.setProperty. You should
double check that the property is indeed set to the right value.
Obviously a typo in the property name will ruin everything. Maybe it's
as simple as needing to put quotes around the space separated schemes.
in the startup parameter.
Johan Naudts wrote:
> Ed,
> configuration. It will be passed as a "-D" parameter at startup.
> Apparently it doesn't change anything. Is there any way I could set
> this parameter programmatically instead of passing it as a system
> property?
> Johan
> Ed Merks wrote:
>> Johan,
>> on the classpath and the xsd.resources.jar will be on the classpath.
>> You earlier showed this trace:
>> this URI will be treated as opaque. (The RFC
>> not recognized and the XSDResourceFactory is not used, resulting in
>> either no factory for standalone or an XMIResourceFactory for
>> Eclipse/headless being used.
>> Johan Naudts wrote:
>>> Dear Ed,
>>> thanks
>>> Johan
>>> Ed Merks wrote:
>>>> Johan,
>>>> schema for schema can't be loaded and the second exception looks
>>>> like the global schema was loaded with an XMIResourceImpl instead
>>>> of an XSDResourceImpl and hence failed to load. Both these
>>>> problems are likely caused by the use of a scheme other than jar:
>>>> or zip: in the classpath.
>>>> Johan Naudts wrote:
>>>>> Dear Ed,
>>>>> Code))
>>>>> Code))
>>>>> Code))
>>>>> Code))
>>>>> Any ideas?
>>>>> Thanks
>>>>> Johan
>>>>> Ed Merks wrote:
>>>>>> Johan,
>>>>>> you define the system property
>>>>>> class:
>>>>>> static
>>>>>> else
>>>>>> Johan Naudts wrote:
>>>>>>> Hi,
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
Re: Schema locations [message #58340 is a reply to message #58310] |
Mon, 28 February 2005 13:39 |
Ed,
I cannot seem to locate this code in version 1.x of EMF. If I try to run
WebSphere with EMF version 2.x, I run into NoSuchMethodErrors:
"java.lang.NoSuchMethodError: org.eclipse.xsd.impl.XSDPackageImpl: method
initEClas(Lorg/eclipse/emf/ecore/EClass;Ljava/lang/Class;Lja va/lang/String;ZZZ)Lorg/eclipse/emf/ecore/EClass;
not found at
org.eclipse.xsd.impl.XSDPackageImpl.initializePackageContent s(XSDPackageImpl.java:4248)... "
This is probably because of conflicts with my current WSAD: I'm using WSAD
version 5.1.1, which corresponds to Eclipse 2.1.2.
Still, this doesn't explain why it works fine when I unzip
xsd.resources.jar???
Help :-)
Ed Merks wrote:
> Johan,
> possible to do
> static
> else
> Johan Naudts wrote:
>> Ed,
>> property?
>> Johan
>> Ed Merks wrote:
>>> Johan,
>>> Johan Naudts wrote:
>>>> Dear Ed,
>>>> thanks
>>>> Johan
>>>> Ed Merks wrote:
>>>>> Johan,
>>>>> Johan Naudts wrote:
>>>>>> Dear Ed,
>>>>>> Code))
>>>>>> Code))
>>>>>> Code))
>>>>>> Code))
>>>>>> Any ideas?
>>>>>> Thanks
>>>>>> Johan
>>>>>> Ed Merks wrote:
>>>>>>> Johan,
>>>>>>> class:
>>>>>>> static
>>>>>>> else
>>>>>>> Johan Naudts wrote:
>>>>>>>> Hi,
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
Re: Schema locations [message #58376 is a reply to message #58340] |
Mon, 28 February 2005 22:32 |
Johan,
Sorry, I assumed you were using the latest and you can't just switch
without affecting WebSphere itself. The only work around with the
older EMF is to unzip the jar. In this case, the URI does not need to
use jar:/wsjar:, since the files aren't in a jar and the whole problem
is avoided. It might work to patch in the newer
org.eclipse.emf.common.util.URI.class into the older build version's jar
so that you can use the system property approach...
Johan Naudts wrote:
> Ed,
> run WebSphere with EMF version 2.x, I run into NoSuchMethodErrors:
> method
> not found at
> WSAD version 5.1.1, which corresponds to Eclipse 2.1.2.
> Help :-)
> Ed Merks wrote:
>> Johan,
>> that's possible to do
>> static
>> else
>> it's as simple as needing to put quotes around the space separated
>> schemes. in the startup parameter.
>> Johan Naudts wrote:
>>> Ed,
>>> property?
>>> Johan
>>> Ed Merks wrote:
>>>> Johan,
>>>> classpath. You earlier showed this trace:
>>>> a /.) An opaque URI has no file extension so the .xsd in the name
>>>> is not recognized and the XSDResourceFactory is not used, resulting
>>>> in either no factory for standalone or an XMIResourceFactory for
>>>> archive schemes? All symptoms still seem to indicate you've not...
>>>> Johan Naudts wrote:
>>>>> Dear Ed,
>>>>> to solve some resources when zipped. Could that be the reason?
>>>>> thanks
>>>>> Johan
>>>>> Ed Merks wrote:
>>>>>> Johan,
>>>>>> Johan Naudts wrote:
>>>>>>> Dear Ed,
>>>>>>> Code))
>>>>>>> Code))
>>>>>>> Code))
>>>>>>> Code))
>>>>>>> Any ideas?
>>>>>>> Thanks
>>>>>>> Johan
>>>>>>> Ed Merks wrote:
>>>>>>>> Johan,
>>>>>>>> sometimes use other schemes in their class loaders, such as
>>>>>>>> "wsjar". If you define the system property
>>>>>>>> URI class:
>>>>>>>> static
>>>>>>>> else
>>>>>>>> Johan Naudts wrote:
>>>>>>>>> Hi,
>>>>&g
Re: Schema locations [message #586297 is a reply to message #42696] |
Ed Merks Messages: 33142 Registered: July 2009 |
Mike,
Mike Lischke wrote:
> Hi group,
> if (stream == null)
> if (stream != null)
> try
> catch(Exception e)
> file:// protocol.
> documentation.
> Mike
> www.soft-gems.net
Ed Merks
Re: Schema locations [message #586330 is a reply to message #42758] |
Mike,
work well...
> this correct?
> my side. But what?
> Mike
> www.soft-gems.net
Ed Merks
Re: Schema locations [message #592103 is a reply to message #42696] |
Wayne Messages: 5 Registered: July 2009 |
Junior Member |
Mike,
try {
return null;
the exception is:
at =
etImpl.java:282)
at =
ava:26)
at =
er.java:35)
Wayne
Mike Lischke wrote:
> Hi group,
> if (stream == null)
> if (stream != null)
> try
> catch(Exception e)
> file:// protocol.
> documentation.
> Mike
> www.soft-gems.net
Re: Schema locations [message #592116 is a reply to message #54045] |
Wayne,
Wayne wrote:
>Mike,
> try {
> return null;
>the exception is:
>at =
>etImpl.java:282)
>at =
>ava:26)
>at =
>er.java:35)
>at
>Regards
>Wayne
>Mike Lischke wrote:
>>Hi group,
>> if (stream == null)
>> if (stream != null)
>> try
>> catch(Exception e)
>>file:// protocol.
>>documentation.
>>Mike
>>www.soft-gems.net
<html>
<head>
<title></title>
</head>
Wayne,<br>
<br>
"/" in a URI.
Ed Merks
Re: Schema locations [message #593037 is a reply to message #54072] |
Hi!
Ed Merks wrote:
> Wayne,
> Wayne wrote:
>>Mike,
>> try {
>> return null;
>>the exception is:
>>at =
>>etImpl.java:282)
>>at =
>>ava:26)
>>at =
>>er.java:35)
>>at
>>Regards
>>Wayne
>>Mike Lischke wrote:
>>>Hi group,
>>> if (stream == null)
>>> if (stream != null)
>>> try
>>> catch(Exception e)
>>>file:// protocol.
>>>documentation.
>>>Mike
>>>www.soft-gems.net
Re: Schema locations [message #593050 is a reply to message #55925] |
HT,
HT Ooi wrote:
> Hi!
> Ed Merks wrote:
>> Wayne,
>> Wayne wrote:
>>> Mike,
>>> to =
>>> you =
>>> try {
>>> return null;
>>> the exception is:
>>> at =
>>> etImpl.java:282)
>>> at =
>>> ava:26)
>>> at =
>>> er.java:35)
>>> at
>>> Regards
>>> Wayne
>>> Mike Lischke wrote:
>>>> Hi group,
>>>> schema
>>>> Until now
>>>> it is
>>>> also load
>>>> if (stream == null)
>>>> if (stream != null)
>>>> try
>>>> catch(Exception e)
>>>> the
>>>> file:// protocol.
>>>> schemas
>>>> it does
>>>> schemas, but
>>>> regardless of
>>>> maybe
>>>> it (or
>>>> map,
>>>> support
>>>> in the
>>>> documentation.
>>>> Mike
>>>> www.soft-gems.net
<html>
<head>
</head>
HT,<br>
<br>
Ed Merks
Re: Schema locations [message #594059 is a reply to message #55941] |
Boolean.TRUE);
Can anyone help?
Thanks!
Johan
Ed Merks wrote:
> HT,
> HT Ooi wrote:
>> Hi!
>> Ed Merks wrote:
>>> Wayne,
>>> Wayne wrote:
>>>> Mike,
>>>> to =
>>>> you =
>>>> try {
>>>> return null;
>>>> the exception is:
>>>> at =
>>>> etImpl.java:282)
>>>> at =
>>>> ava:26)
>>>> at =
>>>> er.java:35)
>>>> at
>>>> Regards
>>>> Wayne
>>>> Mike Lischke wrote:
>>>>> Hi group,
>>>>> schema
>>>>> Until now
>>>>> it is
>>>>> also load
>>>>> if (stream == null)
>>>>> if (stream != null)
>>>>> try
>>>>> catch(Exception e)
>>>>> the
>>>>> file:// protocol.
>>>>> schemas
>>>>> it does
>>>>> schemas, but
>>>>> regardless of
>>>>> maybe
>>>>> it (or
>>>>> map,
>>>>> support
>>>>> in the
>>>>> documentation.
>>>>> Mike
>>>>> www.soft-gems.net
Re: Schema locations [message #594072 is a reply to message #57821] |
Johan,
the URI class:
static
else
Johan Naudts wrote:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Boolean.TRUE);
> Can anyone help?
> Thanks!
> Johan
> Ed Merks wrote:
>> HT,
>> HT Ooi wrote:
>>> Hi!
>>> Ed Merks wrote:
>>>> Wayne,
>>>> Wayne wrote:
>>>>> Mike,
>>>>> new to =
>>>>> a =
>>>>> when =
>>>>> could you =
>>>>> try {
>>>>> return null;
>>>>> the exception is:
>>>>> at =
>>>>> etImpl.java:282)
>>>>> at =
>>>>> ava:26)
>>>>> at =
>>>>> er.java:35)
>>>>> at
>>>>> at
>>>>> Regards
>>>>> Wayne
>>>>> Mike Lischke wrote:
>>>>>> Hi group,
>>>>>> schema
>>>>>> Until now
>>>>>> it is
>>>>>> also load
>>>>>> if (stream == null)
>>>>>> if (stream != null)
>>>>>> try
>>>>>> catch(Exception e)
>>>>>> specify the
>>>>>> file:// protocol.
>>>>>> etc. schemas
>>>>>> But it does
>>>>>> Eclipse
>>>>>> schemas, but
>>>>>> regardless of
>>>>>> -> maybe
>>>>>> by it (or
>>>>>> URI map,
>>>>>> stream support
>>>>>> in the
>>>>>> documentation.
>>>>>> Mike
>>>>>> www.soft-gems.net
<html>
<head>
<title></title>
</head>
Johan,<br>
<br>
Ed Merks
Re: Schema locations [message #594132 is a reply to message #57849] |
Dear Ed,
Code))
Code))
Any ideas?
Johan
Ed Merks wrote:
> Johan,
> the URI class:
> static
> else
> Johan Naudts wrote:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Boolean.TRUE);
>> Can anyone help?
>> Thanks!
>> Johan
>> Ed Merks wrote:
>>> HT,
>>> HT Ooi wrote:
>>>> Hi!
>>>> Ed Merks wrote:
>>>>> Wayne,
>>>>> Wayne wrote:
>>>>>> Mike,
>>>>>> new to =
>>>>>> a =
>>>>>> when =
>>>>>> could you =
>>>>>> try {
>>>>>> return null;
>>>>>> the exception is:
>>>>>> at =
>>>>>> etImpl.java:282)
>>>>>> at =
>>>>>> ava:26)
>>>>>> at =
>>>>>> er.java:35)
>>>>>> at
>>>>>> at
>>>>>> Regards
>>>>>> Wayne
>>>>>> Mike Lischke wrote:
>>>>>>> Hi group,
>>>>>>> schema
>>>>>>> Until now
>>>>>>> it is
>>>>>>> also load
>>>>>>> if (stream == null)
>>>>>>> if (stream != null)
>>>>>>> try
>>>>>>> catch(Exception e)
>>>>>>> specify the
>>>>>>> file:// protocol.
>>>>>>> etc. schemas
>>>>>>> But it does
>>>>>>> Eclipse
>>>>>>> schemas, but
>>>>>>> regardless of
>>>>>>> -> maybe
>>>>>>> by it (or
>>>>>>> URI map,
>>>>>>> stream support
>>>>>>> in the
>>>>>>> documentation.
>>>>>>> Mike
>>>>>>> www.soft-gems.net
Re: Schema locations [message #594150 is a reply to message #57929] |
Johan,
classpath.
Johan Naudts wrote:
> Dear Ed,
> Code))
> Code))
> Code))
> Code))
> Any ideas?
> Thanks
> Johan
> Ed Merks wrote:
>> Johan,
>> in the URI class:
>> static
>> else
>> Johan Naudts wrote:
>>> Hi,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Boolean.TRUE);
>>> files?
>>> Can anyone help?
>>> Thanks!
>>> Johan
>>> Ed Merks wrote:
>>>> HT,
>>>> HT Ooi wrote:
>>>>> Hi!
>>>>> Ed Merks wrote:
>>>>>> Wayne,
>>>>>> Wayne wrote:
>>>>>>> Mike,
>>>>>>> new to =
>>>>>>> from a =
>>>>>>> when =
>>>>>>> could you =
>>>>>>> try {
>>>>>>> return null;
>>>>>>> the exception is:
>>>>>>> at =
>>>>>>> etImpl.java:282)
>>>>>>> at =
>>>>>>> ava:26)
>>>>>>> at =
>>>>>>> er.java:35)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> Regards
>>>>>>> Wayne
>>>>>>> Mike Lischke wrote:
>>>>>>>> Hi group,
>>>>>>>> XML schema
>>>>>>>> Until now
>>>>>>>> when it is
>>>>>>>> also load
>>>>>>>> if (stream == null)
>>>>>>>> if (stream != null)
>>>>>>>> try
>>>>>>>> catch(Exception e)
>>>>>>>> specify the
>>>>>>>> file:// protocol.
>>>>>>>> etc. schemas
>>>>>>>> But it does
>>>>>>>> suppose,
>>>>>>>> Eclipse
>>>>>>>> schemas, but
>>>>>>>> regardless of
>>>>>>>> file -> maybe
>>>>>>>> URI map,
>>>>>>>> stream support
>>>>>>>> reference in the
>>>>>>>> documentation.
>>>>>>>> Mike
>>>>>>>> www.soft-gems.net
Ed Merks
Re: Schema locations [message #594221 is a reply to message #57956] |
Dear Ed,
thanks
Johan
Ed Merks wrote:
> Johan,
> classpath.
> Johan Naudts wrote:
>> Dear Ed,
>> Code))
>> Code))
>> Code))
>> Code))
>> Any ideas?
>> Thanks
>> Johan
>> Ed Merks wrote:
>>> Johan,
>>> in the URI class:
>>> static
>>> else
>>> Johan Naudts wrote:
>>>> Hi,
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Boolean.TRUE);
>>>> files?
>>>> Can anyone help?
>>>> Thanks!
>>>> Johan
>>>> Ed Merks wrote:
>>>>> HT,
>>>>> HT Ooi wrote:
>>>>>> Hi!
>>>>>> Ed Merks wrote:
>>>>>>> Wayne,
>>>>>>> Wayne wrote:
>>>>>>>> Mike,
>>>>>>>> new to =
>>>>>>>> from a =
>>>>>>>> when =
>>>>>>>> could you =
>>>>>>>> try {
>>>>>>>> return null;
>>>>>>>> the exception is:
>>>>>>>> at =
>>>>>>>> etImpl.java:282)
>>>>>>>> at =
>>>>>>>> ava:26)
>>>>>>>> at =
>>>>>>>> er.java:35)
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> Regards
>>>>>>>> Wayne
>>>>>>>> Mike Lischke wrote:
>>>>>>>>> Hi group,
>>>>>>>>> XML schema
>>>>>>>>> Until now
>>>>>>>>> when it is
>>>>>>>>> also load
>>>>>>>>> if (stream == null)
>>>>>>>>> if (stream != null)
>>>>>>>>> try
>>>>>>>>> catch(Exception e)
>>>>>>>>> specify the
>>>>>>>>> file:// protocol.
>>>>>>>>> etc. schemas
>>>>>>>>> But it does
>>>>>>>>> suppose,
>>>>>>>>> Eclipse
>>>>>>>>> schemas, but
>>>>>>>>> regardless of
>>>>>>>>> file -> maybe
>>>>>>>>> URI map,
>>>>>>>>> stream support
>>>>>>>>> reference in the
>>>>>>>>> documentation.
>>>>>>>>> Mike
>>>>>>>>> www.soft-gems.net
Re: Schema locations [message #594252 is a reply to message #58108] |
Johan,
being used.
Johan Naudts wrote:
> Dear Ed,
> thanks
> Johan
> Ed Merks wrote:
>> Johan,
>> classpath.
>> Johan Naudts wrote:
>>> Dear Ed,
>>> Code))
>>> Code))
>>> Code))
>>> Code))
>>> Any ideas?
>>> Thanks
>>> Johan
>>> Ed Merks wrote:
>>>> Johan,
>>>> class:
>>>> static
>>>> else
>>>> Johan Naudts wrote:
>>>>> Hi,
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> it.
>>>>> Boolean.TRUE);
>>>>> necessary files?
>>>>> Can anyone help?
>>>>> Thanks!
>>>>> Johan
>>>>> Ed Merks wrote:
>>>>>> HT,
>>>>>> HT Ooi wrote:
>>>>>>> Hi!
>>>>>>> Ed Merks wrote:
>>>>>>>> Wayne,
>>>>>>>> Wayne wrote:
>>>>>>>>> Mike,
>>>>>>>>> am new to =
>>>>>>>>> from a =
>>>>>>>>> exceptions when =
>>>>>>>>> could you =
>>>>>>>>> try {
>>>>>>>>> return null;
>>>>>>>>> the exception is:
>>>>>>>>> at =
>>>>>>>>> etImpl.java:282)
>>>>>>>>> at =
>>>>>>>>> ava:26)
>>>>>>>>> at =
>>>>>>>>> er.java:35)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> Regards
>>>>>>>>> Wayne
>>>>>>>>> Mike Lischke wrote:
>>>>>>>>>> Hi group,
>>>>>>>>>> XML schema
>>>>>>>>>> schemas. Until now
>>>>>>>>>> when it is
>>>>>>>>>> can also load
>>>>>>>>>> if (stream == null)
>>>>>>>>>> if (stream != null)
>>>>>>>>>> try
>>>>>>>>>> catch(Exception e)
>>>>>>>>>> specify the
>>>>>>>>>> file:// protocol.
>>>>>>>>>> etc. schemas
>>>>>>>>>> me). But it does
>>>>>>>>>> suppose,
>>>>>>>>>> an Eclipse
>>>>>>>>>> schemas, but
>>>>>>>>>> regardless of
>>>>>>>>>> file -> maybe
>>>>>>>>>> an URI map,
>>>>>>>>>> stream support
Ed Merks
Re: Schema locations [message #594298 is a reply to message #58182] |
Ed,
Johan
Ed Merks wrote:
> Johan,
> being used.
> Johan Naudts wrote:
>> Dear Ed,
>> thanks
>> Johan
>> Ed Merks wrote:
>>> Johan,
>>> classpath.
>>> Johan Naudts wrote:
>>>> Dear Ed,
>>>> Code))
>>>> Code))
>>>> Code))
>>>> Code))
>>>> Any ideas?
>>>> Thanks
>>>> Johan
>>>> Ed Merks wrote:
>>>>> Johan,
>>>>> class:
>>>>> static
>>>>> else
>>>>> Johan Naudts wrote:
>>>>>> Hi,
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> it.
>>>>>> Boolean.TRUE);
>>>>>> necessary files?
>>>>>> Can anyone help?
>>>>>> Thanks!
>>>>>> Johan
>>>>>> Ed Merks wrote:
>>>>>>> HT,
>>>>>>> HT Ooi wrote:
>>>>>>>> Hi!
>>>>>>>> Ed Merks wrote:
>>>>>>>>> Wayne,
>>>>>>>>> Wayne wrote:
>>>>>>>>>> Mike,
>>>>>>>>>> am new to =
>>>>>>>>>> from a =
>>>>>>>>>> exceptions when =
>>>>>>>>>> could you =
>>>>>>>>>> try {
>>>>>>>>>> return null;
>>>>>>>>>> the exception is:
>>>>>>>>>> at =
>>>>>>>>>> etImpl.java:282)
>>>>>>>>>> at =
>>>>>>>>>> ava:26)
>>>>>>>>>> at =
>>>>>>>>>> er.java:35)
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> Regards
>>>>>>>>>> Wayne
>>>>>>>>>> Mike Lischke wrote:
>>>>>>>>>>> Hi group,
>>>>>>>>>>> XML schema
>>>>>>>>>>> schemas. Until now
>>>>>>>>>>> when it is
Re: Schema locations [message #594317 is a reply to message #58258] |
Johan,
possible to do
static
else
Johan Naudts wrote:
> Ed,
> property?
> Johan
> Ed Merks wrote:
>> Johan,
>> Johan Naudts wrote:
>>> Dear Ed,
>>> thanks
>>> Johan
>>> Ed Merks wrote:
>>>> Johan,
>>>> Johan Naudts wrote:
>>>>> Dear Ed,
>>>>> Code))
>>>>> Code))
>>>>> Code))
>>>>> Code))
>>>>> Any ideas?
>>>>> Thanks
>>>>> Johan
>>>>> Ed Merks wrote:
>>>>>> Johan,
>>>>>> class:
>>>>>> static
>>>>>> else
>>>>>> Johan Naudts wrote:
>>>>>>> Hi,
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
Ed Merks
Re: Schema locations [message #594334 is a reply to message #58310] |
Ed,
not found at
Help :-)
Ed Merks wrote:
> Johan,
> possible to do
> static
> else
> Johan Naudts wrote:
>> Ed,
>> property?
>> Johan
>> Ed Merks wrote:
>>> Johan,
>>> Johan Naudts wrote:
>>>> Dear Ed,
>>>> thanks
>>>> Johan
>>>> Ed Merks wrote:
>>>>> Johan,
>>>>> Johan Naudts wrote:
>>>>>> Dear Ed,
>>>>>> Code))
>>>>>> Code))
>>>>>> Code))
>>>>>> Code))
>>>>>> Any ideas?
>>>>>> Thanks
>>>>>> Johan
>>>>>> Ed Merks wrote:
>>>>>>> Johan,
>>>>>>> class:
>>>>>>> static
>>>>>>> else
>>>>>>> Johan Naudts wrote:
>>>>>>>> Hi,
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
Re: Schema locations [message #594349 is a reply to message #58340] |
Johan,
Johan Naudts wrote:
> Ed,
> method
> not found at
> Help :-)
> Ed Merks wrote:
>> Johan,
>> static
>> else
>> Johan Naudts wrote:
>>> Ed,
>>> property?
>>> Johan
>>> Ed Merks wrote:
>>>> Johan,
>>>> Johan Naudts wrote:
>>>>> Dear Ed,
>>>>> thanks
>>>>> Johan
>>>>> Ed Merks wrote:
>>>>>> Johan,
>>>>>> Johan Naudts wrote:
>>>>>>> Dear Ed,
>>>>>>> Code))
>>>>>>> Code))
>>>>>>> Code))
>>>>>>> Code))
>>>>>>> Any ideas?
>>>>>>> Thanks
>>>>>>> Johan
>>>>>>> Ed Merks wrote:
>>>>>>>> Johan,
>>>>>>>> URI class:
>>>>>>>> static
>>>>>>>> else
>>>>>>>> Johan Naudts wrote:
>>>>>>>>> Hi,
Ed Merks
Current Time: Fri Apr 26 19:07:45 GMT 2024
Powered by FUDForum. Page generated in 0.08228 seconds
