Home » Modeling » EMF » [Teneo] Invalid Hibernate Mappings for subclasses w/ ID Fields (bugzilla 176821)
Re: [Teneo] Invalid Hibernate Mappings for subclasses w/ ID Fields (bugzilla 176 [message #423407 is a reply to message #423406] |
Tue, 30 September 2008 04:10 |
Hi Andrew,
Okay, I will change it so that an ID efeature in a subtype is ignored (and a warning is logged).
Can you enter a new bugzilla or reopen the old one for this?
gr. Martin
Andrew H wrote:
> Hi Martin
> There are a few problems with this
> 1/ The models have come from industry standard schemas. We are trying to
> avoid any manual changes to the models at this stage. At this stage we
> are relying on purely automatic and essentially cosmetic refactoring of
> the model (e.g. breaking it up into separate packages and moving classes
> around a bit, but no changes to the actual classes themselves). The
> reasons for this is that the model is so large it will take us a while
> to understand it well enough to consider altering it and secondly we
> will always need to maintain compatibility with it so the more we alter
> it the more we will need custom transformations to import / export to
> the standard.
> 2/ The base types don't have id fields in this case. Teneo is generating
> the eId fields for these.
> 3/ Setting PersistenceOptions.ID_FEATURE_AS_PRIMARY_KEY to false means
> that we will lose this feature for our own models. For our hand written
> models we will (and have) made use of id fields on our base classes. We
> like that teneo generates id elements for these.
> The problem really stems from two issues
> i/ The industry XSD's are using id's for an XML oriented technique for
> referring to elements that are not child elements of the current
> element. i.e. they are not considering the impact this has on an
> implementation model such as ecore and the ramifications for
> persistence. i.e. from the XSD point of view adding id fields to sub
> types is not an issue.
> ii/ Teneo has a mapping bug in this case. Even if it is something best
> avoided in an ecore model, its still the case that Teneo creates a
> hibernate mapping that does not conform to the hibernate XSD. Surely
> that should not happen. At the worst case it should throw an exception
> but I still think that generating a unique property is the best answer.
> Is this not possible / desirable?
> Another possible avenue for us is if we can customise the mapping from
> XSD such that the field remains an ID field in XML but is not an ID
> field in ecore. I'm not sure if this is possible?
> regards
> Andrew
> Martin Taal wrote:
>> Hi Andrew,
>> Would the following approach work in your case:
>> - Annote the id-fields in the supertypes/root of the hierarchy with
>> @Id, and
>> - set the option: PersistenceOptions.ID_FEATURE_AS_PRIMARY_KEY to false
>> gr. Martin
>> Andrew H wrote:
>>> I just tried adding a comment to
>>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=176821 but bugzilla
>>> seems to be broken. I get an error saying "A Legal Version was not set"
>>> So I'll post it as a news item instead for now
>>> The issue relates to teneo adding id and version fields to subclass
>>> elements which does not comply with the hibernate schema. The comment
>>> was
>>> This is still an issue for me. A large part of our ecore models
>>> originates from industry XSD's which have used ID fields in the
>>> schema on sub types. e.g. they might have a Date base type and an
>>> IdentifiedDate subtype that adds an ID field so they can create IDREF
>>> fields to point to them. i.e. they introduce ID fields in subtypes
>>> specifically so those subtypes can be the target of IDREF's
>>> elsewhere. I'm not sure why they subtyped for this reason.
>>> As these are ID fields in XSD they come into ecore as ID fields and
>>> cause this problem in teneo.
>>> Sure I would be inclined to avoid doing this in my own models but I
>>> don't have any control over these industry schema's
>>> Couldn't teneo have a rule that if an ID field appears on a subtype
>>> then simply add the field as a unique property rather than an ID field.
>>> e.g. <property name="id" lazy="false" insert="true" update="true"
>>> not-null="false" unique="true" type="java.lang.String">
>>> <column not-null="false" unique="false" name="`false`"/>
>>> </property>
>>> Turning ID fields off on the whole model with the option is not
>>> desirable either as in general I'd like it to use my ID fields as
>>> PK's when they are there on the base class.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Invalid Hibernate Mappings for subclasses w/ ID Fields (bugzilla 176 [message #423410 is a reply to message #423409] |
Tue, 30 September 2008 08:02 |
You also get this when entering a new bugzilla?
gr. Martin
Andrew H wrote:
> Thanks Martin
> Appreciate this.
> Unfortunately, I can't get bugzilla to work. I get
> Bugzilla has suffered an internal error. Please save this page and send
> it to webmaster@eclipse.org with details of what you were doing at the
> time this message appeared.
> URL: https://bugs.eclipse.org/bugs/post_bug.cgi
> A legal Version was not set.
> cheers
> Andrew
> Martin Taal wrote:
>> Hi Andrew,
>> (and a
> warning is logged).
>> gr. Martin
>> Andrew H wrote:
>>> Hi Martin
>>> to avoid any manual changes to the models at this stage. At this
>>> stage we are relying on purely automatic and essentially cosmetic
>>> refactoring of the model (e.g. breaking it up into separate packages
>>> and moving classes around a bit, but no changes to the actual classes
>>> themselves). The reasons for this is that the model is so large it
>>> will take us a while to understand it well enough to consider
>>> altering it and secondly we will always need to maintain
>>> compatibility with it so the more we alter it the more we will need
>>> custom transformations to import / export to the standard.
>>> generating the eId fields for these.
>>> means that we will lose this feature for our own models. For our hand
>>> written models we will (and have) made use of id fields on our base
>>> classes. We like that teneo generates id elements for these.
>>> for referring to elements that are not child elements of the current
>>> best avoided in an ecore model, its still the case that Teneo creates
>>> a hibernate mapping that does not conform to the hibernate XSD.
>>> Surely that should not happen. At the worst case it should throw an
>>> exception but I still think that generating a unique property is the
>>> best answer. Is this not possible / desirable?
>>> from XSD such that the field remains an ID field in XML but is not an
>>> ID field in ecore. I'm not sure if this is possible?
>>> regards
>>> Andrew
>>> Martin Taal wrote:
>>>> Hi Andrew,
>>>> @Id, and
>>>> gr. Martin
>>>>> set"
>>>>> comment was
>>>>> IDREF fields to point to them. i.e. they introduce ID fields in
>>>>> subtypes specifically so those subtypes can be the target of
>>>>> IDREF's elsewhere. I'm not sure why they subtyped for this reason.
>>>>> field.
>>>>> </property>
The Netherlands
Re: [Teneo] Invalid Hibernate Mappings for subclasses w/ ID Fields (bugzilla 176 [message #423544 is a reply to message #423410] |
Wed, 01 October 2008 23:57 |
Andrew H Messages: 117 Registered: July 2009 |
Strange, I replied to this yesterday but it seems to have been lost.
I was able to create a new bugzilla when I did it from scratch rather than
trying to clone the other issue. Issue is
https://bugs.eclipse.org/bugs/show_bug.cgi?id=249246
Note, however, that after I filed this I progressed my persistence code
further and realised that the ID fields that originate from the XSD's are
not suitable as primary keys in the database. They are only intended to be
unique within a single document.
So in the end I used the option you suggested to turn off generation of
primary key fields for these fields.
Consequently, getting a fix for this is no longer a priority for us.
Apologies for the noise. Let me know if you want me to shut the issue down.
I'd be interested in Ed and others thoughts on ID fields. EMF seems to
default XSD ID fields to ID fields in EMF and Teneo then defaults to
setting these as the primary keys. I'm not clear on whether turning this
off in teneo is the right approach or whether I should look to turn it off
in EMF. i.e. are ID fields in EMF supposed to be effectively primary keys
for that class? If so then the mapping from XSD ID is questionable
cheers
Andrew
> gr. Martin
> Andrew H wrote:
>> Thanks Martin
>> Appreciate this.
>> cheers
>> Andrew
>> Martin Taal wrote:
>>> Hi Andrew,
>>> (and a
>> warning is logged).
>>> gr. Martin
>>> Andrew H wrote:
>>>> Hi Martin
>>>> regards
>>>> Andrew
>>>> Martin Taal wrote:
>>>>> Hi Andrew,
>>>>> @Id, and
>>>>> gr. Martin
>>>>>> set"
>>>>>> comment was
>>>>>> field.
>>>>>> </property>
Re: [Teneo] Invalid Hibernate Mappings for subclasses w/ ID Fields (bugzilla 176 [message #423558 is a reply to message #423544] |
Thu, 02 October 2008 09:00 |
Hi Andrew,
Thanks for reporting back. I will keep the bugzilla for now because it can make sense to be a bit
more lenient when the subtype has an ID field.
gr. Martin
> than trying to clone the other issue. Issue is
> are not suitable as primary keys in the database. They are only intended
> to be unique within a single document.
> off in EMF. i.e. are ID fields in EMF supposed to be effectively primary
> keys for that class? If so then the mapping from XSD ID is questionable
> cheers
> Andrew
>> gr. Martin
>> Andrew H wrote:
>>> Thanks Martin
>>> Appreciate this.
>>> send it to webmaster@eclipse.org with details of what you were doing
>>> at the time this message appeared.
>>> cheers
>>> Andrew
>>> Martin Taal wrote:
>>>> Hi Andrew,
>>>> ignored (and a
>>> warning is logged).
>>>> gr. Martin
>>>> Andrew H wrote:
>>>>> Hi Martin
>>>>> trying to avoid any manual changes to the models at this stage. At
>>>>> this stage we are relying on purely automatic and essentially
>>>>> cosmetic refactoring of the model (e.g. breaking it up into
>>>>> separate packages and moving classes around a bit, but no changes
>>>>> to the actual classes themselves). The reasons for this is that the
>>>>> model is so large it will take us a while to understand it well
>>>>> enough to consider altering it and secondly we will always need to
>>>>> maintain compatibility with it so the more we alter it the more we
>>>>> will need custom transformations to import / export to the standard.
>>>>> hand written models we will (and have) made use of id fields on our
>>>>> base classes. We like that teneo generates id elements for these.
>>>>> current element. i.e. they are not considering the impact this has
>>>>> on an implementation model such as ecore and the ramifications for
>>>>> sub types is not an issue.
>>>>> creates a hibernate mapping that does not conform to the hibernate
>>>>> XSD. Surely that should not happen. At the worst case it should
>>>>> throw an exception but I still think that generating a unique
>>>>> property is the best answer. Is this not possible / desirable?
>>>>> an ID field in ecore. I'm not sure if this is possible?
>>>>> regards
>>>>> Andrew
>>>>> Martin Taal wrote:
>>>>>> Hi Andrew,
>>>>>> with @Id, and
>>>>>> false
>>>>>> gr. Martin
>>>>>>> not set"
>>>>>>> subclass elements which does not comply with the hibernate
>>>>>>> schema. The comment was
>>>>>>> and cause this problem in teneo.
>>>>>>> I don't have any control over these industry schema's
>>>>>>> subtype then simply add the field as a unique property rather
>>>>>>> than an ID field.
>>>>>>> </property>
The Netherlands
Re: [Teneo] Invalid Hibernate Mappings for subclasses w/ ID Fields (bugzilla 176 [message #423611 is a reply to message #423558] |
Thu, 02 October 2008 23:50 |
Thanks Martin
I agree its best not to have cases where it produces mappings that don't
comply to the schema.
Martin Taal wrote:
> Hi Andrew,
> gr. Martin
>> cheers
>> Andrew
>>> gr. Martin
>>> Andrew H wrote:
>>>> Thanks Martin
>>>> Appreciate this.
>>>> cheers
>>>> Andrew
>>>> Martin Taal wrote:
>>>>> Hi Andrew,
>>>>> ignored (and a
>>>> warning is logged).
>>>>> gr. Martin
>>>>> Andrew H wrote:
>>>>>> Hi Martin
>>>>>> regards
>>>>>> Andrew
>>>>>> Martin Taal wrote:
>>>>>>> Hi Andrew,
>>>>>>> with @Id, and
>>>>>>> false
>>>>>>> gr. Martin
>>>>>>>> not set"
>>>>>>>> than an ID field.
>>>>>>>> </property>
Current Time: Fri Apr 26 09:11:38 GMT 2024
Powered by FUDForum. Page generated in 0.04118 seconds
