Re: Mapping EObjects to DOM objects already in memory [message #423312 is a reply to message #423311] |
Fri, 26 September 2008 22:22 |
Ed Merks Messages: 33142 Registered: July 2009 |
--------------040203010905050604080509
Cameron ,
Comments below.
Cameron Bateman wrote:
> Is there any support in EMF to "load" EObjects from XML Nodes already
> in memory?
Like this?
* Loads the resource from the DOM node, either an Element or
Document, using the specified options.
* <p>
* This method assumes that no namespace fixup needs to be done.
* To process comments and CDATA section nodes, please set
XMLResource.OPTION_USE_LEXICAL_HANDLER option to Boolean.TRUE.
* </p>
* @param node DOM Element or Document node.
* @param options the load options.
* @see #save(Document, Map, DOMHandler)
* @since 2.1.0
void load(Node node, Map<?, ?> options) throws IOException;
> Specifically, I'd like to exploit the "kind" and "name"
> ExtendedMetaData to bind an EObject instance to a DOM Element instance
> already in memory. XMLResourceImpl looks like it could do this but
> always seems to assume that it has to deserialize and parse the DOM
> first. (Actually it would be nice if I could generalize through the
> Resource interface to abstract away whether the DOM needs to be loaded
> or not to a config option).
> What I'm looking for is something similar to what the WTP "EMF
> Translator" stuff does, except rather than have any EObject instances
> hold state, I want to make all their structural features "volatile"
> and have them read and write directly from/to an exisiting DOM node
> that they are declarative bound to through the ExtendedMetaData.
There's nothing existing that reads/writes directly from/to a DOM...
It's an interesting idea though...
> Cameron
<html>
<head>
http-equiv="Content-Type">
</head>
Cameron ,<br>
<br>
Comments below.<br>
<br>
<blockquote
cite="mid:fbb1c53c275175af8161174a93bd2eb4$1@www.eclipse.org"
type="cite">Is there any support in EMF to "load" EObjects from XML
Nodes already in memory?
<br>
</blockquote>
Like this?<br>
<blockquote>
Ed Merks
Re: Mapping EObjects to DOM objects already in memory [message #423474 is a reply to message #423312] |
Tue, 30 September 2008 19:47 |
Cameron Bateman Messages: 481 Registered: July 2009 |
I'm looking more deeply into this and have a few more questions if you
time:
1) ExtendedMetaData.getName() says that it returns the original meta-data
name used to annotate something in the ecore model, but that it may have
been translated to a Java-safe model in the package. I see this for
example with an element called "short-name" which receives a
short-name_._type in the ecore annotation. How do I map this to the
package value, which in this case is simply "short-name"?
2) Is there a doc somewhere that explains the meaning of some of the
special values used in the extended metadata annotations? For example,
"name" often receives ":mixed" on a mixed content; what does the ":"
indicate, that it's using a default namespace prefix? Conversely, when I
deserialize a the TreeExample model (the one from your XML binding
tutorial), XMLHandler.handleMixedText will use a feature key id of
"XMLTypePackage.Literals.XML_TYPE_DOCUMENT_ROOT__TEXT" to store node TEXT
in a mixed FeatureMap, even though the original model did not specify its
use explicitly. Also, "#" seems to be used to indicate a group reference.
Is there a breakdown of this meta-data somewhere?
Cameron
Re: Mapping EObjects to DOM objects already in memory [message #423475 is a reply to message #423474] |
Tue, 30 September 2008 19:59 |
--------------020906020404030901030403
Cameron,
Comments below.
> time:
> meta-data name used to annotate something in the ecore model, but that
> it may have been translated to a Java-safe model in the package. I
> see this for example with an element called "short-name" which
> receives a short-name_._type in the ecore annotation.
Probably you mean an anonymous type on an element declaration named
"short-name", right?
> How do I map this to the package value, which in this case is simply
> "short-name"?
There are methods like getType and getElement that go in the reverse
direction. (I don't think I have enough context to give an exact answer.
> example, "name" often receives ":mixed" on a mixed content; what does
> the ":" indicate, that it's using a default namespace prefix?
This document describes the details:
XML Schema to Ecore Mapping
< http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf>
The idea behind these feature names is that real names must be
non-colonized names (NCNames) so when we have to make up names for
features that don't correspond to actual elements or attributes, we use
a ":" in them to ensure they can't collide with those.
> Conversely, when I deserialize a the TreeExample model (the one from
> your XML binding tutorial), XMLHandler.handleMixedText will use a
> feature key id of
> TEXT in a mixed FeatureMap, even though the original model did not
> specify its use explicitly.
Yes, these features are special to represent content that isn't
feature-based. I.e., mixed text, cdata, comments, and processing
instructions. These features are allowed only in the feature map
corresponding to the mixed content of a complex type with mixed="true".
> Also, "#" seems to be used to indicate a group reference. Is there a
ExtendedMetaData does all the encoding and decoding of this data, so
best to look at the APIs instead of the syntax and if you need to know
the later see the document that describes the mapping...
> Cameron
<html>
<head>
</head>
Cameron,<br>
<br>
Comments below.<br>
<br>
<blockquote
cite="mid:d1c18ddac49da33413f94ed92608be8e$1@www.eclipse.org"
type="cite">
<blockquote type="cite">There's nothing existing that reads/writes
Ed Merks
FUDForum. Page generated in 0.03465 seconds
