Home » Modeling » EMF » [Databinding] Creating a ComboViewer for an EReference
[Databinding] Creating a ComboViewer for an EReference [message #423309] |
Fri, 26 September 2008 19:48 |
Originally posted by: jconlon.apache.org
I'm trying to create a ComboViewer for an arbitrary EReference but I'm
stumped on how to set up the ComboViewer with the EMF databinding.
//The main problem is I don't know how to create the initial
//IObservableList for the comboViewer
IObservableList comboViewerChoices = ??;
//After that I think it flows like this...
ObservableListContentProvider contentProvider = new
ObservableListContentProvider();
IObservableMap[] attributeMaps =
EMFObservables.observeMaps(
contentProvider.getKnownElements(),
new EStructuralFeature[]
{ eReference.getEOpposite() });
comboViewer.setContentProvider(contentProvider);
comboViewer.setLabelProvider(
new ObservableMapLabelProvider(
attributeMaps));
comboViewer.setInput(comboViewerChoices);
//Then to set up the selection...
dataBindingContext.bindValue(
ViewersObservables.observeSingleSelection(comboViewer),
EMFEditObservables.observeValue(
AdapterFactoryEditingDomain
.getEditingDomainFor(eObject),
eObject, eReference),
tToMStrategy, // TargetToModel
mToTStrategy);// ModelToTarget
any ideas, would be appreciated,
John
Re: [Databinding] Creating a ComboViewer for an EReference [message #423324 is a reply to message #423309] |
Sat, 27 September 2008 15:08 |
Ed Merks Messages: 33142 Registered: July 2009 |
John,
Hopefully Tom or someone else will see your question because I just
don't have enough experience...
> attributeMaps));
> John
Ed Merks
Re: [Databinding] Creating a ComboViewer for an EReference [message #423330 is a reply to message #423309] |
Sun, 28 September 2008 15:27 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
Hi John,
This has to be an ObservableList (EMFObservable#observeList(),
EMFObservable#observeDetailList(), WritableList()).
The question is whether you need this?
Do you expect that:
- the content is modified (elements removed/added)
- the attribute of an element is modified
Please take into consideration that an
ObservableListContentProvider/EMFObservables.observeMaps is quite heavy
if you have a big number of elements because a Listener is added for
every map-element for every attribute.
Tom
> attributeMaps));
> John
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: [Databinding] Creating a ComboViewer for an EReference [message #423348 is a reply to message #423338] |
Mon, 29 September 2008 11:36 |
--------------020108040700050208030308
Boris,
ItemPropertyDescriptor.getReachableObjectsOfType is a static utility
that does this type of thing. Basically walking the entire reachable
collection of EObjects for things of a suitable type. As you say, often
it's filtered to satisfy some constraints...
Boris Bokowski wrote:
> "John E. Conlon" <jconlon@apache.org> wrote in message
> news:gbje9m$5b3$1@build.eclipse.org...
> If all you have is an object eReference of type EReference, then the list of
> choices would consist of all instances of the EClass returned from
> eReference.getEReferenceType(). I couldn't find a method like
> EClass.getAllInstances() and doubt that such a thing exists, so I guess you
> will have to parameterize your solution so that a list of choices can be
> provided depending on the concrete case. Sometimes, any instance will do
> (e.g., pick any country); but you could also have constraints that narrow
> down the choices (e.g., pick one of the official languages of the previously
> chosen country).
> Boris
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
<title></title>
</head>
Boris,<br>
<br>
often it's filtered to satisfy some constraints...<br>
<br>
<br>
<blockquote cite="mid:gbppku$qov$1@build.eclipse.org" type="cite">
<pre wrap="">"John E. Conlon" <a class="moz-txt-link-rfc2396E" href="mailto:jconlon@apache.org"><jconlon@apache.org></a> wrote in message
<a class="moz-txt-link-freetext" href="news:gbje9m$5b3$1@build.eclipse.org">news:gbje9m$5b3$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">I'm trying to create a ComboViewer for an arbitrary EReference but I'm
</pre>
</blockquote>
<pre wrap=""><!---->
chosen country).
Boris
</pre>
</blockquote>
</body>
</html>
--------------020108040700050208030308--
Ed Merks
Re: [Databinding] Creating a ComboViewer for an EReference [message #423373 is a reply to message #423330] |
Mon, 29 September 2008 15:31 |
Hi Tom,
Thanks for pointing this out.
I expect that ...
ObservableMap map = EMFObservables.observeMap(cp.getKnownElements(),
eReference.getEOpposite());
ObservableMapLabelProvider lp = new ObservableMapLabelProvider(map);
is pretty much equivalent to EMFObservables.observeMaps and also
heavywieght.
thanks,
John
Tom Schindl wrote:
> Hi John,
> Do you expect that:
> Tom
>> attributeMaps));
>> John
Re: [Databinding] Creating a ComboViewer for an EReference [message #423375 is a reply to message #423348] |
Mon, 29 September 2008 15:59 |
Ed, Boris
Currently I am using propertyDescriptor.getChoiceOfValues(object) to
build the list.
<snip>
List<Object> choices = new ArrayList<Object>();
for (Object object2 : propertyDescriptor.getChoiceOfValues(object)) {
//Viewers dont like nulls
if (object2 != null) {
choices.add(object2);
if (choices.isEmpty()) {
return;
comboViewer.setContentProvider(new ArrayContentProvider());
comboViewer.setLabelProvider(new
AdapterFactoryLabelProvider(adapterFactory));
comboViewer.setInput(choices.toArray());
</snip>
Would ItemPropertyDescriptor.getReachableObjectsOfType have been better?
Although I can create a list, and could turn it into an ObservableList,
I couldn't get it to work with the databinding contentProvider and
labelProvider so...
I took the more traditional path and refactored so as not to require an
ObservableList after all for the input to the comboViewer's list of
choices. (Still curious how this could be done with databinding though.)
But I do still use databinding to bind the combo selection to the model
element like:
eObject,
eStructuralFeature),
tToMStrategy,
mToTStrategy
Now my remaining question has to do with how I can create the selection
list and bindings to enable unsetting of the eObject's reference?
Is there a consensus how to do this?
thanks,
John
Ed Merks wrote:
> Boris,
>>> I'm stumped on how to set up the ComboViewer with the EMF databinding.
>> list of choices would consist of all instances of the EClass returned
>> from eReference.getEReferenceType(). I couldn't find a method like
>> guess you will have to parameterize your solution so that a list of
>> choices can be provided depending on the concrete case. Sometimes, any
>> instance will do (e.g., pick any country); but you could also have
>> constraints that narrow down the choices (e.g., pick one of the
>> official languages of the previously chosen country).
>> Boris
Re: [Databinding] Creating a ComboViewer for an EReference [message #423376 is a reply to message #423375] |
Mon, 29 September 2008 16:08 |
John,
Comments below.
> Ed, Boris
> build the list.
> <snip>
> return;
> </snip>
No, because that's exactly how it's implemented already. :-P
> ObservableList, I couldn't get it to work with the databinding
> contentProvider and labelProvider so...
Don't you just build the list each time instead of trying to maintain it
dynamically?
> an ObservableList after all for the input to the comboViewer's list of
> model element like:
> eObject,
> tToMStrategy,
> mToTStrategy
> selection list and bindings to enable unsetting of the eObject's
> reference?
We alway just add null to the list, but for unsettable features, that's
not really sufficient, so we rely on the Restore default value button to
actually do the eUnset.
I suppose another special value...
> thanks,
> John
> Ed Merks wrote:
>> Boris,
>>> returned from eReference.getEReferenceType(). I couldn't find a
>>> method like EClass.getAllInstances() and doubt that such a thing
>>> exists, so I guess you will have to parameterize your solution so
>>> that a list of choices can be provided depending on the concrete
>>> case. Sometimes, any instance will do (e.g., pick any country); but
>>> you could also have constraints that narrow down the choices (e.g.,
>>> pick one of the official languages of the previously chosen country).
>>> Boris
Ed Merks
Re: [Databinding] Creating a ComboViewer for an EReference [message #423389 is a reply to message #423376] |
Mon, 29 September 2008 18:35 |
Ed,
See inline...
Ed Merks wrote:
> John,
> Comments below.
>> Ed, Boris
>> build the list.
>> <snip>
>> return;
>> </snip>
> dynamically?
Right, the comboViewer and list is being created each time so there is
no need for an ongoing observation.
>> model element like:
>> eObject,
>> tToMStrategy,
>> mToTStrategy
>> reference?
So if the attribute/EReference was unsettable=true, and if the 'Default
Literal Value' was not specified pressing the Restore default value
button in the properties view, will set the value to 'unset'?
if the attribute/EReference was unsettable=false, and if the 'Default
Literal Value' was not specified will pressing the Restore default value
button in the properties view, set the (attribute/reference) value to null?
to be handled in the UpdateValueStrategy?
So...
When building the choices list for the comboViewer, I can't use a null,
so I will have to designate an object to act as a null in the
comboViewer choice lists. A blank String seems to work good.
EMFUpdateValueStrategy currently is only detecting Strings and
EAttributes as fromType and toType args in the
IConverter createConverter(Object fromType, Object toType).
Since I am dealing with EReferences here, I will have to subclass
EMFUpdateValueStrategy and override createConverter detecting and
converting EReferences and String.
Sound right?
thanks for the help,
John
>> thanks,
>> John
>> Ed Merks wrote:
>>> Boris,
>>>> Boris
Re: [Databinding] Creating a ComboViewer for an EReference [message #423391 is a reply to message #423389] |
Mon, 29 September 2008 19:10 |
John,
Comments below.
> Ed,
> See inline...
> Ed Merks wrote:
>> John,
>> Comments below.
>>> Ed, Boris
>>> build the list.
>>> <snip>
>>> return;
>>> </snip>
>>> better?
>> it dynamically?
>>> of choices. (Still curious how this could be done with databinding
>>> though.)
>>> model element like:
>>> eObject,
>>> tToMStrategy,
>>> mToTStrategy
>>> reference?
>> that's not really sufficient, so we rely on the Restore default value
>> button to actually do the eUnset.
> 'Default Literal Value' was not specified pressing the Restore default
> value button in the properties view, will set the value to 'unset'?
> value button in the properties view, set the (attribute/reference)
> value to null?
It always uses the unset value and always calls eUnset. That always has
the effective of changing the value back to the default value, whatever
it may be and always results in the feature being unset afterwards (so
in the unsettable case, results in the set-state being toggled back to
false).
> So...
> null, so I will have to designate an object to act as a null in the
> Sound right?
Sounds a bit sucky hey. It's like some standard placeholder values to
denote null and unset would be handy... Surely this null issue can't be
unique to EMF. I wonder how that's normally handled. I've asked before
for the case of a string value, what's the "standard way" of
distinguishing null from the zero length string. This must be a totally
common issue, even for entry fields...
> John
>>> thanks,
>>> John
>>> Ed Merks wrote:
>>>> Boris,
>>>> utility that does this type of thing. Basically walking the entire
>>>> reachable collection of EObjects for things of a suitable type. As
>>>> you say, often it's filtered to satisfy some constraints...
>>>>>> but I'm stumped on how to set up the ComboViewer with the EMF
>>>>>> databinding.
>>>>> the list of choices would consist of all instances of the EClass
>>>>> but you could also have constraints that narrow down the choices
>>>>> (e.g., pick one of the official languages of the previously chosen
>>>>> country).
>>>>> Boris
Ed Merks
Re: [Databinding] Creating a ComboViewer for an EReference [message #423400 is a reply to message #423391] |
Mon, 29 September 2008 21:39 |
Ed,
Agree.
How about SQL use of null:
http://java.sun.com/j2se/1.4.2/docs/api/java/sql/Types.html# NULL
John
Ed Merks wrote:
> John,
> Comments below.
>> Ed,
>> See inline...
>> Ed Merks wrote:
>>> John,
>>> Comments below.
>>>> Ed, Boris
>>>> build the list.
>>>> <snip>
>>>> return;
>>>> </snip>
>>>> better?
>>> it dynamically?
>>>> though.)
>>>> model element like:
>>>> eObject,
>>>> tToMStrategy,
>>>> mToTStrategy
>>>> reference?
>> value to null?
> false).
>> So...
>> Sound right?
>> John
>>>> thanks,
>>>> John
>>>> Ed Merks wrote:
>>>>> Boris,
>>>>>>> databinding.
>>>>>> country).
>>>>>> Boris
Re: [Databinding] Creating a ComboViewer for an EReference [message #423401 is a reply to message #423400] |
Mon, 29 September 2008 21:53 |
John,
I guess like that, but that's an int. Probably some public static final
instance of EObject would be better. I'd still like to hear from Boris
and Tom about "standard" data binding techniques for dealing with null
verses empty string and more generally for how to deal with unsettable
values. In DOM, for example, you can use getAttributeNS to get an Attr
and you can check getSpecified to see if that was literally present in
the XML or if it's the default value specified in the XML Schema. Round
tripping the literal DOM requires preserving this state information in
addition to the value (just as it does for EMF's unsettable attributes)...
> Ed,
> Agree.
>> be unique to EMF. I wonder how that's normally handled. I've asked
>> before for the case of a string value, what's the "standard way" of
>> totally common issue, even for entry fields...
> John
> Ed Merks wrote:
>> John,
>> Comments below.
>>> Ed,
>>> See inline...
>>> Ed Merks wrote:
>>>> John,
>>>> Comments below.
>>>>> Ed, Boris
>>>>> to build the list.
>>>>> <snip>
>>>>> return;
>>>>> </snip>
>>>>> better?
>>>> maintain it dynamically?
>>> is no need for an ongoing observation.
>>>>> require an ObservableList after all for the input to the
>>>>> comboViewer's list of choices. (Still curious how this could be
>>>>> model element like:
>>>>> eObject,
>>>>> tToMStrategy,
>>>>> mToTStrategy
>>>>> reference?
>>>> value button to actually do the eUnset.
>>> default value button in the properties view, will set the value to
>>> 'unset'?
>>> 'Default Literal Value' was not specified will pressing the Restore
>>> default value button in the properties view, set the
>> has the effective of changing the value back to the default value,
>> whatever it may be and always results in the feature being unset
>> afterwards (so in the unsettable case, results in the set-state being
>> toggled back to false).
>>> So...
>>> Sound right?
>> to denote null and unset would be handy... Surely this null issue
>> can't be unique to EMF. I wonder how that's normally handled. I've
>> asked before for the case of a string value, what's the "standard
>> way" of distinguishing null from the zero length string. This must
>> be a totally common issue, even for entry fields...
>>> John
>>>>> thanks,
>>>>> John
>>>>> Ed Merks wrote:
>>>>>> Boris,
>>>>>> entire reachable collection of EObjects for things of a suitable
>>>>>> type. As you say, often it's filtered to satisfy some
>>>>>> constraints...
>>>>>>>> databinding.
>>>>>>> so that a list of choices can be provided depending on the
>>>>>>> concrete case. Sometimes, any instance will do (e.g., pick any
>>>>>>> country); but you could also have constraints that narrow down
>>>>>>> Boris
Ed Merks
Re: [Databinding] Creating a ComboViewer for an EReference [message #423402 is a reply to message #423401] |
Mon, 29 September 2008 22:05 |
I think the main issue is that JFace-Viewers don't allow NULL values and
that's why one needs to use the Null-Pattern to identify a NULL value.
I don't think that databinding can know if "" has to be interpreted as
NULL or as an empty-String. This is the task of the converter working
between UI and Model because it differs from situation to situation.
I haven't read through the whole thread and only answered Ed's question
on "" vs NULL so if there's more you need to point me to it.
Tom
Ed Merks schrieb:
> John,
>> Ed,
>> Agree.
>> John
>> Ed Merks wrote:
>>> John,
>>> Comments below.
>>>> Ed,
>>>> See inline...
>>>> Ed Merks wrote:
>>>>> John,
>>>>> Comments below.
>>>>>> Ed, Boris
>>>>>> to build the list.
>>>>>> <snip>
>>>>>> return;
>>>>>> </snip>
>>>>>> better?
>>>>>> model element like:
>>>>>> eObject,
>>>>>> tToMStrategy,
>>>>>> mToTStrategy
>>>>>> reference?
>>>> 'unset'?
>>>> So...
>>>> Sound right?
>>>> John
>>>>>> thanks,
>>>>>> John
>>>>>> Ed Merks wrote:
>>>>>>> Boris,
>>>>>>> constraints...
>>>>>>>>> databinding.
>>>>>>>> Boris
Re: [Databinding] Creating a ComboViewer for an EReference [message #423403 is a reply to message #423402] |
Mon, 29 September 2008 23:18 |
--------------000302070005020309070704
Tom,
Comments below.
Tom Schindl wrote:
Yet all types except primitives allow now, so that's a shortcoming.
Worst of all, is if you need both, rather than either or...
What about when you need both. This is a common problem...
I know you're busy. :-P
Consider that a string-valued attribute can support null, "", and
"xyz". How can I support all these without doing something special.
Generally all String-valued features need things.
Consider if a stirng-valued attribute supports not only null, "", and
"xyz" but has to distinguish one additional state, that of explicitly
being null, "", "xyz" or implicitly having that value because it's the
default. I.e., in DOM <x a="foo"/> and <x/>, where <xsd:attribute
name="a" default="foo"/>, will both produce x.getA().equals("foo"), but
one is explicit and the other is implicit. At least this is implicit
default verses explicit value is subtle and one could argue needs extra
"affordances" in the UI, but the null verses "" is an issue pretty much
for every String-valued feature...
> Tom
> Ed Merks schrieb:
>> John,
>>> Ed,
>>> Agree.
>>> John
>>> Ed Merks wrote:
>>>> John,
>>>> Comments below.
>>>>> Ed,
>>>>> See inline...
>>>>> Ed Merks wrote:
>>>>>> John,
>>>>>> Comments below.
>>>>>>> Ed, Boris
>>>>>>> to build the list.
>>>>>>> <snip>
>>>>>>> return;
>>>>>>> </snip>
>>>>>>> better?
>>>>>>> model element like:
>>>>>>> eObject,
>>>>>>> tToMStrategy,
>>>>>>> mToTStrategy
>>>>>>> reference?
>>>>> 'unset'?
>>>>> So...
>>>>> Sound right?
>>>>> John
>>>>>>> thanks,
>>>>>>> John
>>>>>>> Ed Merks wrote:
>>>>>>>> Boris,
>>>>>>>> constraints...
>>>>>>>>>> databinding.
>>>>>>>>> Boris
<html>
<head>
</head>
Tom,<br>
<br>
Comments below.<br>
<br>
Tom Schindl wrote:
<blockquote cite="mid:gbrjen$ba7$1@build.eclipse.org" type="cite">
<pre wrap="">Hi,
</pre>
</blockquote>
Yet all types except primitives allow now, so that's a shortcoming.<br>
<pre wrap="">
NULL or as an empty-String.</pre>
</blockquote>
Worst of all, is if you need both, rather than either or...<br>
<pre wrap=""> This is the task of the converter working
</pre>
</blockquote>
What about when you need both. This is a common problem...<br>
<pre wrap="">
</pre>
</blockquote>
I know you're busy. :-P<br>
<br>
Generally all String-valued features need things.<br>
<br>
<xsd:attribute name="a" default="foo"/>, will both produce
x.getA().equals("foo"), but one is explicit and the other is implicit.
At least this is implicit default verses explicit value is subtle and
one could argue needs extra "affordances" in the UI, but the null
verses "" is an issue pretty much for every String-valued feature...<br>
<pre wrap="">
Tom
Ed Merks schrieb:
</pre>
<pre wrap="">John,
</pre>
<pre wrap="">Ed,
</pre>
<pre wrap="">Sounds a bit sucky hey.
</pre>
</blockquote>
<pre wrap="">Agree.
</pre>
<pre wrap="">denote null and unset would be handy... Surely this null issue can't
</pre>
</blockquote>
<pre wrap="">How about SQL use of null:
<a class="moz-txt-link-freetext" href=" http://java.sun.com/j2se/1.4.2/docs/api/java/sql/Types.html# NULL"> http://java.sun.com/j2se/1.4.2/docs/api/java/sql/Types.html# NULL</a>
John
Ed Merks wrote:
</pre>
<pre wrap="">John,
Comments below.
</pre>
<pre wrap="">Ed,
See inline...
Ed Merks wrote:
</pre>
<pre wrap="">John,
Comments below.
</pre>
<pre wrap="">Ed, Boris
to build the list.
<snip>
return;
</snip>
better?
</pre>
</blockquote>
<pre wrap="">No, because that's exactly how it's implemented already. :-P
</pre>
<pre wrap="">Although I can create a list, and could turn it into an
</pre>
</blockquote>
<pre wrap="">Don't you just build the list each time instead of trying to
</pre>
</blockquote>
<pre wrap="">Right, the comboViewer and list is being created each time so there
</pre>
<pre wrap="">I took the more traditional path and refactored so as not to
model element like:
eObject,
tToMStrategy,
mToTStrategy
reference?
</pre>
</blockquote>
<pre wrap="">We alway just add null to the list, but for unsettable features,
</pre>
</blockquote>
<pre wrap="">So if the attribute/EReference was unsettable=true, and if the
'unset'?
</pre>
</blockquote>
<pre wrap="">It always uses the unset value and always calls eUnset. That always
</pre>
<pre wrap="">
</pre>
<pre wrap="">Is there a consensus how to do this?
</pre>
</blockquote>
<pre wrap="">I suppose another special value...
</pre>
</blockquote>
<pre wrap="">to be handled in the UpdateValueStrategy?
So...
Sound right?
</pre>
</blockquote>
<pre wrap="">Sounds a bit sucky hey. It's like some standard placeholder values
</pre>
<pre wrap="">thanks for the help,
John
</pre>
<pre wrap="">thanks,
John
Ed Merks wrote:
</pre>
<pre wrap="">Boris,
constraints...
</pre>
</pre>
databinding.
</pre>
</blockquote>
<pre wrap="">If all you have is an object eReference of type EReference, then
Boris
</pre>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</pre>
</blockquote>
</body>
</html>
--------------000302070005020309070704--
Ed Merks
Re: [Databinding] Creating a ComboViewer for an EReference [message #423404 is a reply to message #423403] |
Mon, 29 September 2008 23:41 |
Ed Merks schrieb:
> Tom,
> Comments below.
> Tom Schindl wrote:
>> Hi,
It's a question of how the internals of JFace-Viewers are working and we
can't change this (e.g. the viewer code creates a HashTable to quickly
find TableItem/TreeItems, doing sorting, ... )
As said if you bind it you'll need to pass a Converter to your
UpdateStrategy which knows what to do. EMF has all META-Data on board so
it could maybe internally make the appropriate decision what the
String-Value needs converted to. The main databinding modules e.g. when
we have a JavaBean doesn't provide us with this meta-data.
From Databinding point of view you need set a converter which knows to
do the right thing (as said maybe EMF can insert a default one in
EMFDatabindingContext#bind*() because it can query the Metadata available).
The question is how to display the values in the UI? If you use a
Text-Widget you are lost because it always has "" and doesn't allow to
us to have "null". So the only chance in case of Text is to have a
Context-Menu allowing to set the bound value to:
- null
- default
So it boils down to the question which UI element you want to use.
Tom
Re: [Databinding] Creating a ComboViewer for an EReference [message #423411 is a reply to message #423404] |
Tue, 30 September 2008 08:40 |
--------------010504010901040308040107
Tom,
Comments below.
Tom Schindl wrote:
> Ed Merks schrieb:
>> Tom,
>> Comments below.
>> Tom Schindl wrote:
>>> Hi,
Yes, just as a text widget don't directly represent null...
The problem ends up being one of encoding null. If one possible string
value has to represent the null value, then whatever string value that
is, you'd need some other way to represent that. And of course, given
that this is a ubiquitous issue, doing it in the same way everywhere is
a concern...
There's definitely potential for doing it "right" once in the framework...
> - null
> - default
That's an interesting idea I hadn't considered! It seems to me in the
past that someone suggested a specialized composite widget that included
some type of boolean indicator one could toggle. But with a popup
action and perhaps some type of font style/color feedback, that might
not be necessary.
Exactly. Which UI element to use and how to use it to convey the
details. It would be nice if the core data binding framework would help
with direct support for testing, controlling, and manipulating
isSet/getSpecified/isDefault on properties. The lack of such a concept
in Java beans leads to this being overlooked (e.g., it's next to
impossible to solve this well in the properties view) but in XML and EMF
the concept is important and I'd like to solve it well once and for
all. I'll try to get a chance to talk with you and Boris about possible
approaches. I'm happy to do any and all of the associated work to
arrive at a solution...
> Tom
<html>
<head>
</head>
Tom,<br>
<br>
Comments below.<br>
<br>
Tom Schindl wrote:
<blockquote cite="mid:gbrp38$co$1@build.eclipse.org" type="cite">
<pre wrap="">Ed Merks schrieb:
</pre>
<pre wrap="">Tom,
Comments below.
Tom Schindl wrote:
</pre>
<pre wrap="">Hi,
</pre>
</blockquote>
<pre wrap="">Yet all types except primitives allow now, so that's a shortcoming.
</pre>
</blockquote>
</pre>
</blockquote>
Yes, just as a text widget don't directly represent null...<br>
<pre wrap="">
</pre>
<pre wrap="">I don't think that databinding can know if "" has to be interpreted as
</pre>
</blockquote>
<pre wrap="">Worst of all, is if you need both, rather than either or...
</pre>
</blockquote>
</pre>
</blockquote>
a concern...<br>
<pre wrap="">
</pre>
</pre>
</blockquote>
<pre wrap="">What about when you need both. This is a common problem...
</pre>
</blockquote>
</pre>
</blockquote>
framework...<br>
<pre wrap="">
</pre>
<pre wrap="">I haven't read through the whole thread and only answered Ed's question
</pre>
</blockquote>
<pre wrap="">I know you're busy. :-P
</pre>
</blockquote>
- null
- default
</pre>
</blockquote>
included some type of boolean indicator one could toggle. But with a
popup action and perhaps some type of font style/color feedback, that
might not be necessary.<br>
<pre wrap="">
</pre>
</blockquote>
help with direct support for testing, controlling, and manipulating
EMF the concept is important and I'd like to solve it well once and for
possible approaches. I'm happy to do any and all of the associated
work to arrive at a solution...<br>
<pre wrap="">
Tom
</pre>
</blockquote>
</body>
</html>
--------------010504010901040308040107--
Ed Merks
Re: [Databinding] Creating a ComboViewer for an EReference [message #423415 is a reply to message #423411] |
Tue, 30 September 2008 09:12 |
I'm back from traveling to today in the evening and are available for
the rest of the week.
Tom
Ed Merks schrieb:
> Tom,
> Comments below.
> Tom Schindl wrote:
>> Ed Merks schrieb:
>>> Tom,
>>> Comments below.
>>> Tom Schindl wrote:
>>>> Hi,
> a concern...
>> - null
>> - default
> not be necessary.
>> Tom
Re: [Databinding] Creating a ComboViewer for an EReference [message #423427 is a reply to message #423411] |
Tue, 30 September 2008 13:40 |
Ed,
Now this is starting to sound very un-sucky B-)
John
Ed Merks wrote:
> Tom,
> Comments below.
> Tom Schindl wrote:
>> Ed Merks schrieb:
>>> Tom,
>>> Comments below.
>>> Tom Schindl wrote:
>>>> Hi,
>>>> and
> a concern...
>> available).
>> - null
>> - default
> not be necessary.
>> Tom
Re: [Databinding] Creating a ComboViewer for an EReference [message #423496 is a reply to message #423411] |
Wed, 01 October 2008 13:08 |
Hallvard Traetteberg Messages: 673 Registered: July 2009 Location: Trondheim, Norway |
Interesting thread, this is :-) These subtle issues are usually forgotten or
overlooked, but are of real importance!
I'm working on a UI modelling tool, which is scriptable using Javascript. In
this context values are wrapped, so I can use Javascript's 'undefined' or
similar. One problem is defining how such values are propagated, e.g. to clear
the selection and details view in a master-detail view. Another is, as already
identified, that the end-user cannot unset a value using the standard widgets.
>> - null
>> - default
> not be necessary.
Perhaps it would be possible to use some kind of "overlay" trick, e.g. a
combination of MouseListener, PaintListener (and drawing), tooltip, cursor, etc.
to create the context menu and state indicator outside the actual widget, so
that the widget needn't actually be changed? The menu would somehow set the
state of the Observable in addition to the widget itself.
Hallvard
Current Time: Fri Apr 26 16:25:01 GMT 2024
Powered by FUDForum. Page generated in 0.04304 seconds
