Home » Modeling » EMF » Format generated Code
Format generated Code [message #423253] |
Thu, 25 September 2008 14:22 |
Originally posted by: fdo.scodi.ch
Hello
In my workspace I have set the "Save Actions" which also formats the code
the way I want.
Now if I generate code from my genmodel, the output format is different as
the rest of my classes. Another problem is the modification of those
classes, as soon as I save my changes and want to commit to our svn
repository I have a whole lot of changes.
I started to modify the
org.eclipse.emf.codegen.ecore/templates/model/Class.javajet, but this
can't be the solution.
Is it some how possible to tell the generator to use my code formatting or
tell it to do a "save" after generation?
The genmodel does have a "Code Formatting" option, but that doesn't solve
the problem. It doesn't format the way I defined it in the preferences.
I appreciate any help!
Re: Format generated Code [message #423260 is a reply to message #423256] |
Thu, 25 September 2008 15:07 |
Well I have my own formatter, not the "Eclipse [built-in]". Does it take
the default provided by Eclipse or my selected "Active profile"? Probably
not my profile, for example the toString method:
// after my save
public String toString() {
if (eIsProxy()) {
return super.toString();
// after emf generation
if (eIsProxy())
The braces are missing.
Ahh, just found out that this is not a formatting but a "Code Style"
option, which is also applied during the "save process".
Well then, is it possible to apply this code style to the generated code?
I disabled the "Code Style" option and saved the class again, I still get
a different output, especially the javadoc comments.
I still think the default Eclipse formatting is used instead of my active
profile.
Ed Merks wrote:
> Flavio,
> Comments below.
> Flavio Donzé wrote:
>> Hello
>> code the way I want.
>> different as the rest of my classes. Another problem is the
>> modification of those classes, as soon as I save my changes and want
>> to commit to our svn repository I have a whole lot of changes.
>> formatting or tell it to do a "save" after generation?
>> solve the problem. It doesn't format the way I defined it in the
>> preferences.
> It invokes the regular Eclipse formatter which is based on your
> preferences. But I think save actions can include more than just
> formatting. Is it related to some type of cleanup action rather than
> just formatting?
Re: Format generated Code [message #423267 is a reply to message #423264] |
Thu, 25 September 2008 15:57 |
ok, thanks Ed!
I found out that the "Save actions" are almost equal to the "Clean up"
preferences.
Do you think this would be possible to invoke? That would solve the
problem.
Ed Merks wrote:
> Flavio,
> It should be using the project's options:
> public static Object createCodeFormatter(Map<?, ?> options,
> String workspacePath)
> if (options == null)
> IProject project =
> ResourcesPlugin.getWorkspace().getRoot().getProject(new
> Path(workspacePath).segment(0));
> if (project != null)
> IJavaProject javaProject = JavaCore.create(project);
> if (javaProject != null)
> options = javaProject.getOptions(true);
> return ToolFactory.createCodeFormatter(options);
> And if the project doesn't have local options, this should use the
> globally applicable ones.
> But what you describe is more than formatting. I'm not sure there is a
> programmatic way to invoke save actions.
>> take the default provided by Eclipse or my selected "Active profile"?
>> Probably not my profile, for example the toString method:
>> // after my save
>> if (eIsProxy()) {
>> if (eIsProxy())
>> get a different output, especially the javadoc comments.
>> active profile.
>> Ed Merks wrote:
>>> Flavio,
>>> Comments below.
>>> Flavio Donzé wrote:
>>>> Hello
>>>> this can't be the solution.
>>>> preferences.
>>> just formatting?
Re: Format generated Code [message #423269 is a reply to message #423267] |
Thu, 25 September 2008 16:03 |
Ed Merks Messages: 33141 Registered: July 2009 |
Flavio,
I don't know if there is a programmatic way to invoke that. If someone
could determine how to do it programatically, that we could look at how
to invoke that...
Flavio Donzé wrote:
> ok, thanks Ed!
> preferences.
> problem.
> Ed Merks wrote:
>> Flavio,
>> IProject project =
>> a programmatic way to invoke save actions.
>>> profile"? Probably not my profile, for example the toString method:
>>> // after my save
>>> if (eIsProxy()) {
>>> if (eIsProxy())
>>> code?
>>> still get a different output, especially the javadoc comments.
>>> active profile.
>>> Ed Merks wrote:
>>>> Flavio,
>>>> Comments below.
>>>> Flavio Donzé wrote:
>>>>> Hello
>>>>> the code the way I want.
>>>>> want to commit to our svn repository I have a whole lot of changes.
>>>>> doesn't solve the problem. It doesn't format the way I defined it
>>>>> in the preferences.
>>>> than just formatting?
Ed Merks
Re: Format generated Code [message #423270 is a reply to message #423269] |
Thu, 25 September 2008 16:04 |
Flavio,
I should point out that we have to be able to do it to an in memory copy
before we do the actual save; we're very careful not to save anything if
the disk version and the in-memory version are the same...
Ed Merks wrote:
> Flavio,
> someone could determine how to do it programatically, that we could
> look at how to invoke that...
> Flavio Donzé wrote:
>> ok, thanks Ed!
>> up" preferences.
>> problem.
>> Ed Merks wrote:
>>> Flavio,
>>> IProject project =
>>> is a programmatic way to invoke save actions.
>>>> // after my save
>>>> if (eIsProxy()) {
>>>> if (eIsProxy())
>>>> Style" option, which is also applied during the "save process".
>>>> code?
>>>> active profile.
>>>> Ed Merks wrote:
>>>>> Flavio,
>>>>> Comments below.
>>>>> Flavio Donzé wrote:
>>>>>> Hello
>>>>>> in the preferences.
Ed Merks
Current Time: Fri Apr 26 05:30:12 GMT 2024
Powered by FUDForum. Page generated in 0.03651 seconds
