Home » Modeling » EMF » Copyright text isn't regenerated
Copyright text isn't regenerated [message #422941] |
Fri, 19 September 2008 12:58 |
Originally posted by: NOSPAM-magnus.rundlof.saabgroup.com-NOSPAM
I have a large software component generated from Ecore models. In the
beginning of each file I want a copyright text. EMF supports this by setting
the following properties in the Generator Model
Copyright Fields = true
Copyright Text = "My copyright text"
This works fine the first time I generate, but if I would like to change the
text, say for example update the copyright year, it doesn't take effect. I
need to delete the file and regenerate for the new copyright text to show.
Why is this?
Also, out of curiosity, what's up with the $Id$ that is appended to the
copyright text?
Regards/
Magnus
Re: Copyright text isn't regenerated [message #422944 is a reply to message #422941] |
Fri, 19 September 2008 13:18 |
Originally posted by: cdamus.zeligsoft.com
Hi, Magnus,
See some replies in-line, below.
Christian
Magnus Rundlof wrote:
> Hi
> Why is this?
This is a known limitation. Other text that isn't regenerated includes
the plugin.xml and MANIFEST.MF.
> copyright text?
That's a keyword known to CVS, which the CVS server expands to record
timestamp, user ID, and other tractking information for the file.
If you are not using CVS, then you can define custom templates using
EMF's "dynamic templates" capability to override the HEADER.javajetinc,
HEADER.propertiesjetinc, etc. templates.
> Regards/
> Magnus
Re: Copyright text isn't regenerated [message #423046 is a reply to message #422944] |
Mon, 22 September 2008 07:23 |
Hi Christian, thanks for you reply
Known limitation? Does that mean that it will fixed in a near future?
Regards/
Magnus
"Christian W. Damus" <cdamus@zeligsoft.com> wrote in message
news:gb08r4$g8d$1@build.eclipse.org...
> Hi, Magnus,
> Cheers,
> Christian
>> Hi
>> setting the following properties in the Generator Model
>> the text, say for example update the copyright year, it doesn't take
>> effect. I need to delete the file and regenerate for the new copyright
>> text to show. Why is this?
>> copyright text?
> If you are not using CVS, then you can define custom templates using EMF's
>> Regards/
>> Magnus
Re: Copyright text isn't regenerated [message #423067 is a reply to message #423046] |
Mon, 22 September 2008 15:03 |
Ed Merks Messages: 33142 Registered: July 2009 |
--------------050406080802000603030504
Magnus,
I don't even think of it as a limitation. Copyright notices tend to
evolve over time. For example, most will include the year the file
itself was first created as well as the year of the most recent
modification. Simply overwriting the copyright notice doesn't seem like
a good idea.
> Regards/
> Magnus
>> Hi, Magnus,
>> Cheers,
>> Christian
>>> Hi
>>> copyright text?
>>> Regards/
>>> Magnus
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Magnus,<br>
<br>
like a good idea.<br>
<br>
<br>
<blockquote cite="mid:gb7h4p$aje$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Christian, thanks for you reply
Regards/
Magnus
"Christian W. Damus" <a class="moz-txt-link-rfc2396E" href="mailto:cdamus@zeligsoft.com"><cdamus@zeligsoft.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:gb08r4$g8d$1@build.eclipse.org">news:gb08r4$g8d$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Hi, Magnus,
Christian
</pre>
<pre wrap="">Hi
</pre>
</blockquote>
<pre wrap="">This is a known limitation. Other text that isn't regenerated includes
</pre>
<pre wrap="">Also, out of curiosity, what's up with the $Id$ that is appended to the
copyright text?
</pre>
</blockquote>
<pre wrap="">That's a keyword known to CVS, which the CVS server expands to record
</pre>
<pre wrap="">Regards/
Magnus
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------050406080802000603030504--
Ed Merks
Re: Copyright text isn't regenerated [message #423075 is a reply to message #423067] |
Mon, 22 September 2008 15:58 |
Hi, Ed,
Good point. Perhaps there's a GSoC project here: a smart copyright
merge that
- updates the date range to include the current year
- adds your employer to the copyright-holders list
- integrates with Mylyn to record the contributor name and bug ID
- formats all of this information tidily
:-D
cW
Ed Merks wrote:
> Magnus,
> a good idea.
>> Regards/
>> Magnus
>>> Hi, Magnus,
>>> Cheers,
>>> Christian
>>>> Hi
>>>> copyright text?
>>>> Regards/
>>>> Magnus
Re: Copyright text isn't regenerated [message #426345 is a reply to message #423067] |
Sun, 28 December 2008 16:18 |
Ed,
I'm also just stumbling about this "feature". I realized that I forgot
to configure the copyright header property in many genmodel files. Am I
really supposed to add the copyright text to all generated files
manually now?
Cheers
/Eike
Ed Merks schrieb:
> Magnus,
> like a good idea.
>> Regards/
>> Magnus
>>> Hi, Magnus,
>>> Cheers,
>>> Christian
>>>> Hi
>>>> copyright text?
>>>> Regards/
>>>> Magnus
Cheers
/Eike
http://www.esc-net.de
Re: Copyright text isn't regenerated [message #426346 is a reply to message #426345] |
Sun, 28 December 2008 17:21 |
Eike,
There are merge rules you could specialize along with dynamic templates:
<merge:pull
sourceGet="CompilationUnit/getHeader"
targetPut="CompilationUnit/setHeader"/>
Eike Stepper wrote:
> Ed,
> I really supposed to add the copyright text to all generated files
> manually now?
> Cheers
> /Eike
> http://thegordian.blogspot.com
> Ed Merks schrieb:
>> Magnus,
>> like a good idea.
>>> Regards/
>>> Magnus
>>>> Hi, Magnus,
>>>> Cheers,
>>>> Christian
>>>>> Hi
>>>>> the beginning of each file I want a copyright text. EMF supports
>>>>> this by setting the following properties in the Generator Model
>>>>> change the text, say for example update the copyright year, it
>>>>> doesn't take effect. I need to delete the file and regenerate for
>>>>> the new copyright text to show. Why is this?
>>>> includes the plugin.xml and MANIFEST.MF.
>>>>> to the copyright text?
>>>> record timestamp, user ID, and other tractking information for the
>>>> file.
>>>> using EMF's "dynamic templates" capability to override the
>>>> HEADER.javajetinc, HEADER.propertiesjetinc, etc. templates.
>>>>> Regards/
>>>>> Magnus
Ed Merks
Current Time: Fri Apr 26 07:22:07 GMT 2024
Powered by FUDForum. Page generated in 0.03355 seconds
