Home » Modeling » EMF » Persisting _all_ values?
Re: Persisting _all_ values? [message #422732 is a reply to message #422728] |
Mon, 15 September 2008 14:08 |
Ed Merks Messages: 33142 Registered: July 2009 |
--------------070100030609030208080809
Morten,
Comments below.
Morten MacFly wrote:
> Dear NG,
> I have another question:
> I am working with a generated editor out of an ECore model. When I save
> the work (in the runtime of the editor) it creates a XML file (just as
> setup in the genmodel) which is fine.
> Unfortunately the editor's "save routine" does not persist values which
> are set to it's default value.
> Can I (somehow) tell the persistence layer to save all values to the XML
> file, including those which are set to it's default values?
This will serialize the explicit default of the attributes (but not the
implicit default, i.e., the 0 for an int):
* Keep default content ( e.g. default attributes). This applies
to saving and converting contents to DOM.
* By default the default content is discarded.
* To save the default content, set this option to
<code>Boolean.TRUE</code>.
String OPTION_KEEP_DEFAULT_CONTENT = "KEEP_DEFAULT_CONTENT";
> In addition: How would I override the save routine if I wanted to do it
> all by myself?
> With regards, Morten.
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Morten,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:galod6$8ce$1@build.eclipse.org" type="cite">
<pre wrap="">Dear NG,
</pre>
</blockquote>
implicit default, i.e., the 0 for an int):<br>
<blockquote> /**<br>
* Keep default content ( e.g. default attributes). This applies to
saving and converting contents to DOM.<br>
* By default the default content is discarded.<br>
<code>Boolean.TRUE</code>.<br>
*/<br>
String OPTION_KEEP_DEFAULT_CONTENT = "KEEP_DEFAULT_CONTENT";<br>
</blockquote>
<br>
<pre wrap="">
all by myself?
</pre>
</blockquote>
</body>
</html>
--------------070100030609030208080809--
Ed Merks
Re: Persisting _all_ values? [message #422734 is a reply to message #422732] |
Mon, 15 September 2008 15:57 |
Morten MacFly Messages: 69 Registered: July 2009 |
Member |
Sorry Ed,
I understand what you are telling me but I don't get it to work. I
searched the forum / internet for help but no success.
I did the following: In the I did two overrides in the specialisation of
the XMLResourceImpl implementation of the editor this way:
public void doSave(OutputStream outputStream, Map<?, ?> options) throws
IOException {
this.getDefaultSaveOptions().put(XMLResource.OPTION_KEEP_DEF AULT_CONTENT,
Boolean.TRUE);
super.doSave(outputStream, options);
public void doSave(Writer writer, Map<?, ?> options) throws IOException {
Boolean.TRUE);
super.doSave(writer, options);
Notice I first tried tried directly:
options.put(XMLResource.OPTION_KEEP_DEFAULT_CONTENT, Boolean.TRUE);
....but this gave me the following error:
The method put(capture#3-of ?, capture#4-of ?) in the type
Map<capture#3-of ?,capture#4-of ?> is not applicable for the arguments
(String, Boolean)
Either way the XML serialisation does not change at all.
This might sound stupid, but what am I missing?
Re: Persisting _all_ values? [message #422741 is a reply to message #422734] |
Mon, 15 September 2008 17:58 |
--------------090701080900010208020501
Morten,
Comments below.
> Sorry Ed,
> @Override
> IOException {
> Boolean.TRUE);
It's expect you to modify the factory. Did you check to notice that
adding it to the default options at this point is already too late?
> @Override
> Boolean.TRUE);
> (String, Boolean)
Yes, you shouldn't modify the map the client passed in.
You should do this in your resource factory.
<html>
<head>
</head>
Morten,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:gam0l0$enm$1@build.eclipse.org" type="cite">
<pre wrap="">Ed Merks wrote:
</pre>
<blockquote type="cite">
<pre wrap=""> String OPTION_KEEP_DEFAULT_CONTENT = "KEEP_DEFAULT_CONTENT";
</pre>
</blockquote>
<pre wrap=""><!---->Sorry Ed,
IOException {
Boolean.TRUE);
</pre>
</blockquote>
adding it to the default options at this point is already too late?<br>
<pre wrap="">
Boolean.TRUE);
(String, Boolean)
</pre>
</blockquote>
Yes, you shouldn't modify the map the client passed in.<br>
<pre wrap="">
</pre>
</blockquote>
You should do this in your resource factory.<br>
<pre wrap="">
</pre>
</blockquote>
</body>
</html>
--------------090701080900010208020501--
Ed Merks
Current Time: Fri Apr 26 20:33:28 GMT 2024
Powered by FUDForum. Page generated in 0.03787 seconds
