Home » Modeling » EMF » [CDO] ExtendedLibrary sample with CDO ?
Re: [CDO] ExtendedLibrary sample with CDO ? [message #422674 is a reply to message #422670] |
Fri, 12 September 2008 14:59 |
Stéphane Fournier schrieb:
> Does anyone try to wire the Extended Library Editor (the one from EMF
> examples) with CDO server ?
> I'm not using the CDO session views.
> I made some changes ExtendedLibrary editor to connect it to a CDO
> server, open a session, get a transaction and create a cdo resource.
> Problems raise when I try to add a new library with a writer.
> All created objects seem to be transient. When debugging
> CDOObjectImpl.dynamicSet() method, and FSMUtil.isTransient(this)
> always answers true. Is it normal ?
I see you're using CDOObjectImpl but just to be sure: Did you regenerate
the Library model after migrating the genmodel to CDO?
Usually CDOObjects are TANSIENT as long as they're not attached to a
CDOTransaction. This is also true for CDOResource (which is a CDOObject,
too). How did you create the CDOResource?
The best way is transaction.createResource(path). If objects are then
attached to other objects that are already attached, the new objects
will also transition from TRANSIENT to NEW.
> When I commit the transaction, that fails with this message :
> [ERROR] SQL Exception: The statement was aborted because it would have
> caused a duplicate key value in a unique or primary key constraint or
> unique index identified by 'CDORESOURCE_IDX0' defined on 'CDORESOURCE'.
Looks as if a resource with that path (i.e. URI) is already stored in
the repository.
Either clear your database from previous attempts or use a different
resourcepath or call transaction.getOrCreateResource(path).
> Before I commit the transaction, I have no exception in eclipse log file.
> N.B : Extended Library editor runs with an editing domain which is an
> EMF Transactional one.
That's (IMHO) generally not a good idea!
Why do you add a second transactional layer on top of CDO?
Cheers
/Eike
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] ExtendedLibrary sample with CDO ? [message #422679 is a reply to message #422674] |
Fri, 12 September 2008 15:29 |
Stephane fournier Messages: 340 Registered: July 2009 |
Hi Eike,
Yes, I have generated the Extended Library model with changes in the
genmodel as mentionned in the "Preparing EMF Models for CDO" article.
To create a resource, I'm using transaction.createResource(path) method. I
have moved to getOrCreateResource() method.
Once, the resource is created, I add it to a resource set owned by a
transactional editing domain.
Now, at save time, I got this exception stack :
java.lang.IllegalStateException: Failing event COMMIT in state TRANSIENT
for CDOResource@oid1
(data= org.eclipse.emf.internal.cdo.protocol.CommitTransactionResul t @d8d767)
at
org.eclipse.net4j.util.fsm.FiniteStateMachine.process(Finite StateMachine.java:152)
at
org.eclipse.emf.internal.cdo.CDOStateMachine.commit(CDOState Machine.java:274)
at
org.eclipse.emf.internal.cdo.CDOTransactionImpl.postCommit(C DOTransactionImpl.java:475)
at
org.eclipse.emf.internal.cdo.CDOTransactionImpl.commit(CDOTr ansactionImpl.java:246)
at
org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl.save(CDOR esourceImpl.java:369)
My editor was already working with a transactional editing domain. I try
CDO to get a multi-user capability on my existing editor.
This editor is a GMF one that only works with a transational editing
domain.
My idea was to open a CDO transaction when the editor is opening. After
every save operation, I would like to commit the CDO transaction to really
flush data to the database.
Between save operations, my transactional editing domain listens to model
changes.
Stephane.
>> Hi,
> the repository.
> Cheers
> /Eike
Re: [CDO] ExtendedLibrary sample with CDO ? [message #422682 is a reply to message #422679] |
Fri, 12 September 2008 15:42 |
> Hi Eike,
> method. I have moved to getOrCreateResource() method. Once, the
Ah! That's not allowed! Because ResourceSet.resources is like a
containment reference it's like a detach from the CDOTransaction!
The best thing you can do is not using EMF Transaction (sorry
Christian!) on top of CDO.
The second best thing you could try is:
1) Get the ResourceSet out of the TransactionalEditingDomain
2) Call CDOSession.openTransaction(resourceSet) to reuse 1) instead of
creating a new resource set
> TRANSIENT for CDOResource@oid1
> at
> at
> at
> at
> at
> try CDO to get a multi-user capability on my existing editor. This
> editor is a GMF one that only works with a transational editing domain.
> After every save operation, I would like to commit the CDO transaction
> to really flush data to the database.
> model changes.
Many users already asked for compatibility with GMF so I'm very
interested in your results. Please give feedback! ;-)
Cheers
/Eike
> Stephane.
>>> Hi,
>>> EMF examples) with CDO server ?
>> regenerate the Library model after migrating the genmodel to CDO?
>> CDOObject, too). How did you create the CDOResource?
>>> have caused a duplicate key value in a unique or primary key
>>> constraint or unique index identified by 'CDORESOURCE_IDX0' defined
>>> on 'CDORESOURCE'.
>> the repository.
>>> file.
>>> an EMF Transactional one.
>> Cheers
>> /Eike
Cheers
/Eike
Re: [CDO] ExtendedLibrary sample with CDO ? [message #422685 is a reply to message #422682] |
Fri, 12 September 2008 16:11 |
Eike Stepper wrote:
I tried what you suggested at 2).
Now, I got the exception below. I'm using the embbeded derby store.
Indeed, after the resource creation a log mentionned that Legacy system is
not available. What does it mean ?
Ok, to give you feedbacks to run editor based on CDO and EMF Transaction,
if I succeed ;)
Stephane.
org.eclipse.emf.cdo.util.LegacySystemNotAvailableException: Legacy system
not available
at
org.eclipse.emf.internal.cdo.util.FSMUtil.checkLegacySystemA vailability(FSMUtil.java:82)
at
org.eclipse.emf.internal.cdo.CDOStore.handleContainmentAdd(C DOStore.java:562)
at org.eclipse.emf.internal.cdo.CDOStore.add(CDOStore.java:427)
at
org.eclipse.emf.internal.cdo.CDOObjectImpl$CDOStoreEList.del egateAdd(CDOObjectImpl.java:666)
at
org.eclipse.emf.common.util.DelegatingEList.addAllUnique(Del egatingEList.java:671)
at
org.eclipse.emf.common.notify.impl.DelegatingNotifyingListIm pl.doAddAllUnique(DelegatingNotifyingListImpl.java:495)
at
org.eclipse.emf.common.notify.impl.DelegatingNotifyingListIm pl.addAllUnique(DelegatingNotifyingListImpl.java:436)
at
org.eclipse.emf.common.notify.impl.DelegatingNotifyingListIm pl.addAllUnique(DelegatingNotifyingListImpl.java:396)
at
org.eclipse.emf.common.util.DelegatingEList.addAll(Delegatin gEList.java:593)
at org.eclipse.emf.edit.command.AddCommand.doExecute(AddCommand .java:403)
at
org.eclipse.emf.edit.command.AbstractOverrideableCommand.exe cute(AbstractOverrideableCommand.java:129)
at
org.eclipse.emf.common.command.CommandWrapper.execute(Comman dWrapper.java:180)
at
org.eclipse.emf.edit.command.CreateChildCommand.execute(Crea teChildCommand.java:263)
at
org.eclipse.emf.workspace.EMFCommandOperation.doExecute(EMFC ommandOperation.java:116)
at
org.eclipse.emf.workspace.AbstractEMFOperation.execute(Abstr actEMFOperation.java:137)
at
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:511)
at
com.thalesgroup.mde.tig.ef.internal.command.WorkspaceCommand StackImpl.doExecute(WorkspaceCommandStackImpl.java:125)
>> Hi Eike,
>> at
>> at
>> at
>> at
>> at
>> model changes.
> Cheers
> /Eike
>> Stephane.
>>>> Hi,
>>>> on 'CDORESOURCE'.
>>> the repository.
>>>> file.
>>> Cheers
>>> /Eike
Re: [CDO] ExtendedLibrary sample with CDO ? [message #422687 is a reply to message #422685] |
Fri, 12 September 2008 16:55 |
> system is not available. What does it mean ?
Usually an indication that you are trying to attach non-native objects
to a transaction (or a bug).
but from the stack trace I can see that you're not using a brand new CDO
source from HEAD.
Only yesterday we committed substantial changes. Can youplease re-test
with newest HEAD?
Cheers
/Eike
> Transaction, if I succeed ;)
> Stephane.
> system not available
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
>>> Hi Eike,
>> of creating a new resource set
>>> at
>>> at
>>> at
>>> at
>>> at
>>> transaction to really flush data to the database.
>>> model changes.
>> Cheers
>> /Eike
>>> Stephane.
>>>>> Hi,
>>>> a CDOTransaction. This is also true for CDOResource (which is a
>>>> then attached to other objects that are already attached, the new
>>>> objects will also transition from TRANSIENT to NEW.
>>>> in the repository.
>>>> different resourcepath or call transaction.getOrCreateResource(path).
>>>>> log file.
>>>> Cheers
>>>> /Eike
Cheers
/Eike
Re: [CDO] ExtendedLibrary sample with CDO ? [message #422696 is a reply to message #422687] |
Sat, 13 September 2008 19:53 |
Ok Eike,
I'll check-out the latest release immediately.
I will test that on next Monday.
Stephane.
> source from HEAD.
> with newest HEAD?
> Cheers
> /Eike
>> Stephane.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>>>> Hi Eike,
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> model changes.
>>> Cheers
>>> /Eike
>>>> Stephane.
>>>>>> Hi,
>>>>> in the repository.
>>>>>> log file.
>>>>> Cheers
>>>>> /Eike
Re: [CDO] ExtendedLibrary sample with CDO ? [message #422697 is a reply to message #422696] |
Sat, 13 September 2008 21:08 |
Comments below.
At home, I can use thunderbird to read newsgroup ouf :)
Stéphane Fournier wrote:
> Ok Eike, I'll check-out the latest release immediately.
> Stephane.
Hi Eike,
I checked out the latest release and I tested again. I got the exception
below.
What does it mean exactly "attach non-native objects"? EMF objects that
do not extend CDO objects ?
I'm sorry if the question is stupid, but to make sure I've correctly
understand.
Stephane.
Exception stack :
at
org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl$Persisten tContents.inverseAdd(CDOResourceImpl.java:567)
at
org.eclipse.emf.common.notify.impl.DelegatingNotifyingListIm pl.addAllUnique(DelegatingNotifyingListImpl.java:448)
at
at
at
at
at
at
at
at
at
at
com.thalesgroup.mde.tig.ef.command.TigCommandStack.doExecute (TigCommandStack.java:40)
at
org.eclipse.emf.transaction.impl.AbstractTransactionalComman dStack.execute(AbstractTransactionalCommandStack.java:164)
at
org.eclipse.emf.transaction.impl.AbstractTransactionalComman dStack.execute(AbstractTransactionalCommandStack.java:217)
at
org.eclipse.emf.edit.ui.action.StaticSelectionCommandAction. run(StaticSelectionCommandAction.java:232)
>> CDO source from HEAD.
>> with newest HEAD?
>> Cheers
>> /Eike
>>> Stephane.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>>>> Hi Eike,
>>>>> the genmodel as mentionned in the "Preparing EMF Models for CDO"
>>>>> article.
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> I try CDO to get a multi-user capability on my existing editor.
>>>>> editing domain.
>>>>> model changes.
>>>> Cheers
>>>> /Eike
>>>>> Stephane.
>>>>>>> Hi,
>>>>>> in the repository.
>>>>>>> log file.
>>>>>>> is an EMF Transactional one.
>>>>>> Cheers
>>>>>> /Eike
Re: [CDO] ExtendedLibrary sample with CDO ? [message #422720 is a reply to message #422699] |
Mon, 15 September 2008 08:46 |
Thanks folks for your support !
I missed the following point : to create the marker file (CDO.MF).
I can test again mixing CDO transactions and EMFT transactions.
Stephane.
Simon McDuff wrote:
> Hi Stephane,
> CDO do not support Legacy object anymore.
> I know Eike is currently working on a feature in EMF that will allow CDO to
> support easily legacy objects. In my opinion, it is a question of time
> (months. :-)).
> To be able to persist objects through CDO please follow this guideline:
http://wiki.eclipse.org/Preparing_EMF_Models_for_CDO#Modify_ an_Existing_GenModel
> You just need to modify your genmodel.
> Simon
> "Stéphane Fournier" <stephane.fournier@netcourrier.com> a écrit dans le
> message de news: gaha51$145$1@build.eclipse.org...
>> Comments below.
>>> Stephane.
>> Hi Eike,
>> below.
>> When you said :
>> Usually an indication that you are trying to attach non-native objects to
>> What does it mean exactly "attach non-native objects"? EMF objects that do
>> understand.
>> Stephane.
>> Exception stack :
>> not available
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>>>> source from HEAD.
>>>> with newest HEAD?
>>>> Cheers
>>>> /Eike
>>>>> Stephane.
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>>>> Hi Eike,
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> domain.
>>>>>>> model changes.
>>>>>> Cheers
>>>>>> /Eike
>>>>>>> Stephane.
>>>>>>>>> Hi,
>>>>>>>>> resource.
>>>>>>>>> on 'CDORESOURCE'.
>>>>>>>> in the repository.
>>>>>>>>> file.
>>>>>>>> Cheers
>>>>>>>> /Eike
Re: [CDO] ExtendedLibrary sample with CDO ? [message #422721 is a reply to message #422720] |
Mon, 15 September 2008 09:27 |
Gosh! People always used to criticize me for the lack of documentation
and now you don't read it! :P
> Stephane.
> Simon McDuff wrote:
>> Hi Stephane,
>> CDO to support easily legacy objects. In my opinion, it is a question
>> of time (months. :-)).
>> Simon
>> le message de news: gaha51$145$1@build.eclipse.org...
>>> Comments below.
>>>> Stephane.
>>> Hi Eike,
>>> exception below.
>>> objects to a transaction (or a bug).
>>> that do not extend CDO objects ?
>>> understand.
>>> Stephane.
>>> Exception stack :
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>>>> new CDO source from HEAD.
>>>>> re-test with newest HEAD?
>>>>> Cheers
>>>>> /Eike
>>>>>> Stephane.
>>>>>> Legacy system not available
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>>>> Hi Eike,
>>>>>>>> in the genmodel as mentionned in the "Preparing EMF Models for
>>>>>>>> CDO" article.
>>>>>>>> transaction.createResource(path) method. I have moved to
>>>>>>>> getOrCreateResource() method. Once, the resource is created, I
>>>>>>>> add it to a resource set owned by a transactional editing domain.
>>>>>>> instead of creating a new resource set
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> domain. I try CDO to get a multi-user capability on my existing
>>>>>>>> editor. This editor is a GMF one that only works with a
>>>>>>>> opening. After every save operation, I would like to commit the
>>>>>>>> CDO transaction to really flush data to the database.
>>>>>>>> listens to model changes.
>>>>>>> Cheers
>>>>>>> /Eike
>>>>>>>> Stephane.
>>>>>>>>>> Hi,
>>>>>>>>>> from EMF examples) with CDO server ?
>>>>>>>>>> CDO server, open a session, get a transaction and create a
>>>>>>>>>> cdo resource.
>>>>>>>>>> FSMUtil.isTransient(this) always answers true. Is it normal ?
>>>>>>>>> attached to a CDOTransaction. This is also true for
>>>>>>>>> CDOResource (which is a CDOObject, too). How did you create
>>>>>>>>> the CDOResource?
>>>>>>>>> are then attached to other objects that are already attached,
>>>>>>>>> the new objects will also transition from TRANSIENT to NEW.
>>>>>>>>>> would have caused a duplicate key value in a unique or
>>>>>>>>>> primary key constraint or unique index identified by
>>>>>>>>> stored in the repository.
>>>>>>>>>> eclipse log file.
>>>>>>>>>> which is an EMF Transactional one.
>>>>>>>>> Cheers
>>>>>>>>> /Eike
Cheers
/Eike
Current Time: Fri Sep 20 12:13:15 GMT 2024
Powered by FUDForum. Page generated in 0.04468 seconds
