Re: childCreationExtenders [message #422564 is a reply to message #422558] |
Tue, 09 September 2008 13:11 |
Ed Merks Messages: 33142 Registered: July 2009 |
Xavier,
Comments below.
Xavier Maysonnave wrote:
> I'm prototyping a child extension activation and deactivation
> mechanism on top of childCreationExtenders in EMF 2.4.
> To implement such behaviour I plan to use specialized
> ViewerFilterAction on our content provider.
> I would like to create a new MenuManager either in the general toolbar
> and in contextual popup menus filled with extended model name in our
> editor.
> Assume we have a generated editor for model A. model B and model C
> extends A. My MenuManager should contain the namespace name of such
> extensions in order to successfully activate and deactivate extensions.
> I'm trying to figure out how to retrieve the model owner (eg model B
> and model C) through the childCreationExtenders extension point. I
> don't want to extensively analyse model to build a dependency graph it
> will be too expensive.
> The 'IChildCreationExtender.Descriptor' doesn't expose such
> informations. My first approach was to read by myself this extension
> point to get the class implementation. From now on I can access the
> getDeclaringClass() of this implementation. Now I have a
> org.eclipse.emf.edit.itemProviderAdapterFactories extension point
> The ComposedAdapterFactory.Descriptor.Registry doesn't expose either
> its uri attribute so I need to read by myself the
> itemProviderAdapterFactories extension point to get uris.
> Is there a way to have a more efficient implementation ?
We don't really want to expose all the details of the underlying
implementation since the registry can also be used programmatically.
It's certainly possible for model A's editor to define extension points
specific to your editor that are then used by model B and model C to
augment editor A... It sounds like you're trying to generalize this
though. I'm not sure what specifically to suggest...
> Thanks
Ed Merks
FUDForum. Page generated in 0.02968 seconds
