Home » Modeling » EMF » How to create a prefix like fXxx or _xxx for fields in generated models?
How to create a prefix like fXxx or _xxx for fields in generated models? [message #421500] Thu, 07 August 2008 22:47 Go to next message
is there a way to specify a prefix or the name for the field generated?
Example (using emfatic syntax):
class MyClass {
attr int fooBar;
I want to specify the name of the fooBar
field to be _fooBar or fFooBar. Instead of
protected int fooBar = FOO_BAR_EDEFAULT;
I want
protected int _fooBar = FOO_BAR_EDEFAULT;
or
protected int fFooBar = FOO_BAR_EDEFAULT;
or
protected int fooBar_ = FOO_BAR_EDEFAULT;
Is thre a magic annotation like the @GenModel(documentation="my doc")
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=152481#c1)?
class MyClass {
@GenModel(filedName="fFooBar") // would be nice :-)
attr int fooBar;
Why? Because often without the escape it is all to easy
to accidentally assign to the fooBar variable in "@generated NO"
methods.
Another option I would like is to make members private to the
class.....
Michael
Michael Scharf
Wind River Systems GmbH
http://www.WindRiver.com
http://MichaelScharf.blogspot.com/
Re: How to create a prefix like fXxx or _xxx for fields in generated models? [message #421519 is a reply to message #421500] Fri, 08 August 2008 08:07 Go to previous messageGo to next message
Michael,
Comments below.
Michael Scharf wrote:
No the field name is computed directly from the feature name.
> class MyClass {
> attr int fooBar;
> I want
> or
> or
> class MyClass {
> attr int fooBar;
> methods.
I'm not keen on adding yet more complexity because you have a tendency
to assign variables without considering if that's a good idea.
> class.....
You'd still have the same problem in that class then. Some of the
generation patterns require access to the field in derived classes.
Feature requests arrive faster than the shrinking team can address them
so I'm not going to suggest a feature request for this, but if you feel
strongly about it, a patch to implement it will be considered.
> Michael
Re: How to create a prefix like fXxx or _xxx for fields in generated models? [message #421552 is a reply to message #421519] Fri, 08 August 2008 22:23 Go to previous message
Ed,
thanks for the quick reply. I was hoping, that there is
already a magic annotation that does the trick.
Maybe, I'll do a patch when it annoys me too much...
Michael
> Michael,
> Comments below.
>> class MyClass {
>> attr int fooBar;
>> I want
>> or
>> or
>> class MyClass {
>> attr int fooBar;
>> methods.
>> class.....
>> Michael
Michael Scharf
Previous Topic:Databinding and mixed/any type
Next Topic:[CDO] New packages
Current Time: Wed Nov 05 04:37:32 EST 2025
Powered by FUDForum. Page generated in 0.03852 seconds
