Home » Modeling » EMF » in memory XML representation
| in memory XML representation [message #420826] |
Fri, 11 July 2008 08:28  |
From salvo.nicola@gmail.com Fri Jul 11 13:26:12 2008
Subject: in memory XML representation
X-Evolution-PostTo:
nntp://exquisitus@news.eclipse.org:119/eclipse.tools.emf
In-Reply-To: <g56s8q$9f2$1@build.eclipse.org>
References: <g56s8q$9f2$1@build.eclipse.org>
Content-Type: text/plain
X-Evolution-Format: text/plain
X-Evolution-Account: 1215424214.5117.1@deepthought.gt4
X-Evolution-Transport:
smtp://salvo.nicola%40gmail.com;auth=PLAIN@smpt.gmail.com:587/;use_ssl=always
X-Evolution-Fcc: mbox:/home/rootto/.evolution/mail/local#Sent
X-Mailer: Evolution 2.22.2
Date: Fri, 11 Jul 2008 13:26:12 +0100
Message-Id: <1215779172.2758.18.camel@deepthought.gt4>
Mime-Version: 1.0
I'm back with another problem. I need to obtain a in memory
representation, of the workflow modelled with GMF/EMF in order to deploy
it on a server. Searching on the archive I found this:
http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg1 8706.html
that answer to my question building a org.w3c.dom.Document. I wrapped
the code in a subMenu action, and in the selectionChanged method, I get
the WorkflowTypeEditPart in order receive the editingDomain (am I
right?). This is the run method:
public void run(IAction action) {
DocumentBuilderFactory documentBuilderFactory =
DocumentBuilderFactory.newInstance();
documentBuilderFactory.setNamespaceAware(true);
DocumentBuilder documentBuilder;
try {
documentBuilder = documentBuilderFactory.newDocumentBuilder();
Document document = documentBuilder.newDocument();
ResourceSet resourceSet =
mySelectedElement.getEditingDomain().getResourceSet();
for(Resource resource:resourceSet.getResources()){
((XMLResource)resource).save (document, null, null);
TransformerFactory transformerFactory =
TransformerFactory.newInstance();
Transformer transformer = transformerFactory.newTransformer();
transformer.transform(new DOMSource(document), new
StreamResult(System.out));
and this it the error I receive:
org.w3c.dom.DOMException: HIERARCHY_REQUEST_ERR: An attempt was made to
insert a node where it is not permitted.
at org.apache.xerces.dom.CoreDocumentImpl.insertBefore(Unknown Source)
at org.apache.xerces.dom.NodeImpl.appendChild(Unknown Source)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:1139)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:1017)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementFeatur eMap(XMLSaveImpl.java:2417)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1480)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.writeTopObject(XM LSaveImpl.java:725)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveI mpl.java:588)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:206)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.save(XMLResou rceImpl.java:282)
gsoc.ogsdai.custom.actions.DeployWorkflowAction.run(DeployWo rkflowAction.java:74)
I suppose is something wrong with the ResourceSet (debugging I notice
that the exception is raised after few iterations), but I don't know how
to solve the problem. Any help would be more than appreciated :)
Cheers
Nicola
| Re: in memory XML representation [message #420829 is a reply to message #420826] |
Fri, 11 July 2008 09:07   |
Nicola,
If you just tried to save to an string writer and checked the result, is
it well formed XML?
currentNode =
currentNode.appendChild(document.createElementNS(nameInfo.ge tNamespaceURI(),
nameInfo.getQualifiedName()));
Given the above line, I'm suspicious that there aren't perhaps two
features set on the document root and hence it's trying to create two
root elements...
> From: Nicola Salvo <salvo.nicola@gmail.com>
> X-Evolution-PostTo:
> X-Mailer: Evolution 2.22.2 Date: Fri, 11 Jul 2008 13:26:12 +0100
> Mime-Version: 1.0
> Hello,
> try {
> insert a node where it is not permitted. at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Cheers
> Nicola
| Re: in memory XML representation [message #420830 is a reply to message #420829] |
Fri, 11 July 2008 10:06   |
Hello Ed,
thanks for the hint! I solved the problem following your hint. The
resourceSet contains two resources thus in the second iteration the
Document class was complaining. I solved changing the code in this way:
for(Resource resource: resourceSet.getResources()){
if(resource instanceof ModelResourceImpl)
Even if I struggled for a while with GMF/EMF for a while, some concepts
are still mysterious:)
Again thank you!
Ed Merks wrote:
> Nicola,
> it well formed XML?
> currentNode =
> root elements...
>> X-Evolution-PostTo:
>> Mime-Version: 1.0
>> Hello,
>> try {
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Cheers
>> Nicola
| Re: in memory XML representation [message #420831 is a reply to message #420830] |
Fri, 11 July 2008 10:39  |
Nicola,
Oh, I see the problem now. You might and do end up calling this for
multiple resources so you really ought to have a break statement or not
be doing it in a loop.
Nicola Salvo wrote:
> Hello Ed,
> concepts are still mysterious:) Again thank you!
> Ed Merks wrote:
>> Nicola,
>> is it well formed XML?
>> currentNode =
>> root elements...
>>> X-Evolution-PostTo:
>>> Mime-Version: 1.0
>>> Hello,
>>> deploy
>>> try {
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> how
>>> Cheers
>>> Nicola
Current Time: Thu Nov 06 21:59:31 EST 2025
Powered by FUDForum. Page generated in 0.03245 seconds
