Home » Modeling » EMF » new attribute to a class on my model
new attribute to a class on my model [message #417976] Tue, 01 April 2008 05:17 Go to next message
I've just added a new attribute to a class and this attribute doesn't
appear in the editor when I'm editing a model file.
What can be the cause ?
(I watched the generated class and the attribute is correctly defined)
(I removed the read only directive on my folders before the code generation)
Alexandre
Re: new attribute to a class on my model [message #417982 is a reply to message #417976] Tue, 01 April 2008 07:16 Go to previous messageGo to next message
It's really strange the attribute is correctly generated in the emf class :
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated
public String getDeleteCommand() {
return deleteCommand;
* @generated
public void setDeleteCommand(String newDeleteCommand) {
String oldDeleteCommand = deleteCommand;
deleteCommand = newDeleteCommand;
if (eNotificationRequired())
eNotify(new ENotificationImpl(this, Notification.SET,
UIModelPackage.RENDERER_INFO__DELETE_COMMAND, oldDeleteCommand,
deleteCommand));
but it's never called
Cheers
Alexandre
Re: new attribute to a class on my model [message #417984 is a reply to message #417982] Tue, 01 April 2008 07:21 Go to previous messageGo to next message
Alexandre,
Where are you looking for it in the generated editor? Are the
GenFeature properties for this feature set such that it will appear as a
property in the properties view?
> class :
> * @generated
> * @generated
> deleteCommand));
> Cheers
> Alexandre
Re: new attribute to a class on my model [message #417986 is a reply to message #417984] Tue, 01 April 2008 07:37 Go to previous messageGo to next message
Hi Ed,
In fact everything was fine during the generation but it's missed only
the feature definition of the attribute in the plugin.properties file.
Re: new attribute to a class on my model [message #417987 is a reply to message #417986] Tue, 01 April 2008 07:42 Go to previous messageGo to next message
Alexandre,
So do you still have a question? (Was that file read-only perhaps?)
> Hi Ed,
> Thanks
Re: new attribute to a class on my model [message #417996 is a reply to message #417987] Tue, 01 April 2008 11:05 Go to previous message
Ed,
No evertything is fine now it was as you said the read-only feature that
cause the problem.
Alexandre
Previous Topic:Serialization with id attribute
Next Topic:XML schema import and EEnums
Current Time: Wed Nov 05 07:46:46 EST 2025
Powered by FUDForum. Page generated in 0.26276 seconds
