Home » Modeling » EMF » Serialization with id attribute
Serialization with id attribute [message #417975] Tue, 01 April 2008 04:23 Go to next message
Originally posted by: messineo.rosario.gmail.com
this post is a reply to a previous one that I haven't found more, why?
I've extended the XMIResourceImpl in my project and overrided two methods
in the following way:
protected boolean useIDAttributes() {
return false;
protected boolean useUUIDs() {
return true;
but when I use the Model Editor it doesn't serialize using id attribute
with a random sequence.
Have I to change other things?
Rosario
Re: Serialization with id attribute [message #417983 is a reply to message #417975] Tue, 01 April 2008 07:19 Go to previous messageGo to next message
Rosario,
Comments below.
Rosario wrote:
> methods in the following way:
> @Override
> return false;
> @Override
> return true;
> attribute with a random sequence.
Is the model editor actually using your resource factory to create the
above resource implementation?
I did explain that you should register it; in fact, I explained how you
could modify the GenPackage's Resource Type property so that an
implementation and registration would be generated for it, but I'm not
sure you've done that...
> Thanks
> Rosario
Re: Serialization with id attribute [message #417991 is a reply to message #417983] Tue, 01 April 2008 10:05 Go to previous messageGo to next message
I've add the following extension point and now it works fine.
<extension
point="org.eclipse.emf.ecore.extension_parser">
<parser
class="spatel.util.XXXResourceFactoryImpl"
type="*">
</parser>
</extension>
Rosario
Re: Serialization with id attribute [message #417993 is a reply to message #417991] Tue, 01 April 2008 10:39 Go to previous message
Rosario,
It's likely you'll kill the rest of the environment by making your
factory the default one for all extensions. :-(
Rosario wrote:
> <extension
> <parser
> type="*">
> </parser>
> </extension>
> Thanks
> Rosario
Previous Topic:Workbench event loop stuck after EMF bulk update
Next Topic:new attribute to a class on my model
Current Time: Wed Nov 05 04:37:43 EST 2025
Powered by FUDForum. Page generated in 0.04744 seconds
