Home » Modeling » EMF » Unable to View contents in EMF Editor
Re: Unable to View contents in EMF Editor [message #417333 is a reply to message #417331] |
Wed, 05 March 2008 16:01 |
Kamesh Sampath Messages: 213 Registered: July 2009 |
Thanks Ed. I am able to rectify it .. Also i do have a one more question on
the Selection ,
I am using the MultipageSelectionProvider for the Editor , in my tree when i
click on the node and add a child or sibling my Selection still remains on
the Node from which I initiated the Command , my question is how do I move
the selection to the newly added element ???
This works fine with the Generated editor , my doubt is that am making a
mess with the Selection with my dissected EMF editor ???
Thoughts please ...
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:fqmfqi$du0$2@build.eclipse.org...
> Kamesh,
> The generated editor's handleContentOutlineSelection shows how to do that
> doesn't it?
> Kamesh Sampath wrote:
>> Hi Ed,
>> I debugged the issue , the issue was with the ContentOutlineSelection.
>> Its not able to provide the proper selection element since there was a
>> bug in the code that I wrote..
>> I also gave a treeviwer.refresh() after setting the input ..
>> I have one quick question, how to make the Tree listen to the
>> ContentOutlineSelection by just navigating to the Selected Element in the
>> Outline view , I dont need it to go to its children , just stay at the
>> same element selected by the Outline.
Re: Unable to View contents in EMF Editor [message #417335 is a reply to message #417333] |
Wed, 05 March 2008 16:13 |
Ed Merks Messages: 33142 Registered: July 2009 |
--------------070604040008000608000209
Kamesh,
The generated editor's setCurrentView method handles updating the
selection and listening to the current view to forward its selection.
So I guess you need to hook up your MultipageSelectionProvider thing so
that it serves the same kind of purpose...
> the Selection ,
> Thoughts please ...
>> Kamesh,
>> doesn't it?
>>> Hi Ed,
<html>
<head>
</head>
Kamesh,<br>
<br>
that it serves the same kind of purpose...<br>
<br>
<br>
<blockquote cite="mid:fqmg51$hjj$1@build.eclipse.org" type="cite">
<pre wrap="">Thanks Ed. I am able to rectify it .. Also i do have a one more question on
the Selection ,
Thoughts please ...
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:fqmfqi$du0$2@build.eclipse.org">news:fqmfqi$du0$2@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Kamesh,
doesn't it?
</pre>
<pre wrap="">Hi Ed,
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------070604040008000608000209--
Ed Merks
Re: Unable to View contents in EMF Editor [message #417337 is a reply to message #417335] |
Wed, 05 March 2008 17:25 |
------=_NextPart_000_000B_01C87F14.09C1FA00
charset="iso-8859-1"
Ed,
Thanks for your toughts ! The reason it was not working is that 1. As =
you said the currentViewer was not set and there by when the commands =
are fired the setSelectionToViewer method was not able to perform its =
task of setting the selection to recentlyAffectedObjects .
So I tried to set the CurrentViewer on pageChange where each page of my =
multipage editor part is associated with an StructuredViewer.
~Kamesh
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:fqmgs9$o5b$1@build.eclipse.org...
Kamesh,
The generated editor's setCurrentView method handles updating the =
selection and listening to the current view to forward its selection. =
So I guess you need to hook up your MultipageSelectionProvider thing so =
Kamesh Sampath wrote:=20
Thanks Ed. I am able to rectify it .. Also i do have a one more question =
on=20
the Selection ,
I am using the MultipageSelectionProvider for the Editor , in my tree =
when i=20
click on the node and add a child or sibling my Selection still remains =
on=20
the Node from which I initiated the Command , my question is how do I =
move=20
This works fine with the Generated editor , my doubt is that am making =
a=20
Thoughts please ...
"Ed Merks" <merks@ca.ibm.com> wrote in message=20
Kamesh,
The generated editor's handleContentOutlineSelection shows how to do =
that=20
doesn't it?
Hi Ed,
I debugged the issue , the issue was with the ContentOutlineSelection.=20
Its not able to provide the proper selection element since there was a=20
I have one quick question, how to make the Tree listen to the=20
ContentOutlineSelection by just navigating to the Selected Element in =
the=20
Outline view , I dont need it to go to its children , just stay at the=20
=20
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.6000.16608" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DVerdana size=3D2>Ed,</FONT></DIV>
<DIV><FONT face=3DVerdana size=3D2></FONT> </DIV>
<DIV><FONT face=3DVerdana size=3D2>Thanks for your toughts ! The reason =
it was not=20
working is that 1. As you said the currentViewer was not set and =
there by=20
when the commands are fired the setSelectionToViewer method was not able =
to=20
perform its task of setting the selection to recentlyAffectedObjects=20
..</FONT></DIV>
<DIV><FONT face=3DVerdana size=3D2>So I tried to set the CurrentViewer =
on pageChange=20
where each page of my multipage editor part is associated with an=20
StructuredViewer.</FONT></DIV>
<DIV><FONT face=3DVerdana size=3D2>~Kamesh</FONT></DIV>
<BLOCKQUOTE=20
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:fqmgs9$o5b$1@build.eclipse.org">news:fqmgs9$o5b$1@build.ecli=
pse.org</A>...</DIV>Kamesh,<BR><BR>The=20
selection and=20
listening to the current view to forward its selection. So I =
guess you=20
need to hook up your MultipageSelectionProvider thing so that it =
serves the=20
same kind of purpose...<BR><BR><BR>Kamesh Sampath wrote:=20
<BLOCKQUOTE cite=3Dmid:fqmg51$hjj$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">Thanks Ed. I am able to rectify it .. Also =
i do have a one more question on=20
the Selection ,
when i=20
on=20
move=20
a=20
Thoughts please ...
"Ed Merks" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:merks@ca.ibm.com"><merks@ca.ibm.com></A> wrote in =
message=20
<A class=3Dmoz-txt-link-freetext =
href=3D"news:fqmfqi$du0$2@build.eclipse.org">news:fqmfqi$du0$2@build.ecli=
pse.org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Kamesh,
that=20
doesn't it?
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hi Ed,
the=20
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_000B_01C87F14.09C1FA00--
Current Time: Fri Apr 26 08:15:31 GMT 2024
Powered by FUDForum. Page generated in 0.03921 seconds
