| AGR Remote Testing [message #42081] |
Wed, 23 November 2005 12:03  |
Originally posted by: AngelR.Rotronix.com
Hi Everyone,
Has anyone had any success running a GUI TestSuite Remotely? Is this
supported? If so, would someone please provide me to some docs.
Angel
| Re: AGR Remote Testing [message #44574 is a reply to message #42563] |
Fri, 02 December 2005 15:33  |
Ali Mehregani wrote:
> Hi Angel,
> Did you try defining a custom deployment file for your test suite? See
> http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI.html#2.2.1
> on how this can be accomplished. You will need to specify the path to
> startup.jar and the hostname in the location file that you will associate
> with your custom deployment file. The support for this will be much
> improved once https://bugs.eclipse.org/bugs/show_bug.cgi?id=109880 is
> implemented.
> Ali Mehregani
> "Angel Roman" <AngelR@Rotronix.com> wrote in message
> news:dm27ca$8dk$1@news.eclipse.org...
>> Hi Everyone,
>> Regards,
>> Angel
Hi Ali,
I've tried using the the deployment created in the tutorial with the
correct host name and startup.jar path. However, nothing transpired on
the deployment machine. I noticed that the CPU usage for the Agent
Controller increased when launching the test remotely on the target
machine. However, the test never completed. Should I expect to see a
session of eclipse running on the target machine? Nothing happened.
Thanks for your help so far.
Angel
FUDForum. Page generated in 0.02844 seconds
