Home » Modeling » EMF » OutOfMemoryError during EMF model code generation from XSD source
OutOfMemoryError during EMF model code generation from XSD source [message #416697] Wed, 13 February 2008 06:39 Go to next message
Hello everyone,
I am constantly getting an OutOfMemoryError (Java heap space) during EMF
model code generation from XSD sources.
Edit, editor and tests code can be generated, but when generating the
model code, EMF seems to run into an infinite loop, filling up the heap.
The progress bar shows no progress, until at some point the generation
aborts without any result. I tried allocating more memory to the JVM, but
to no avail.
This happens with more complex real-world XSDs with lots of
cross-references, like DocBook or SVG. The model code for the small sample
XSD from the library tutorial gets generated all right.
Sadly, I am new to EMF. If I am missing something important here, or if
there is more appropriate vocabulary to describe the problem, please give
me a hint.
I have found neither a matching problem report nor a solution in the
newsgroups and mailing lists. Is anyone else experiencing the same problem?
Thanks in advance!
I am using the following platform:
Ubuntu Feisty
Linux kernel version 2.6.20
Sun Java Platform, Standard Edition Development Kit 5.0
Eclipse Platform
Version: 3.3.1.1
Build id: M20071023-1652
Eclipse Modeling Framework (EMF)
Version: 2.3.1.v200709252135
Build id: 200709252135
Eclipse is started with the following parameters:
/eclipse -vmargs -Xmx2048M -XX:PermSize=512M
Here is the log entry:
!ENTRY org.eclipse.emf.codegen.ecore.ui 2 0 2008-02-12 19:44:57.787
!MESSAGE
!STACK 0
java.lang.reflect.InvocationTargetException
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:350)
org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:495)
org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel ActionBarContributor$GenerateAction.run(GenModelActionBarCon tributor.java:423)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1101)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3319)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
Caused by: java.lang.OutOfMemoryError: Java heap space
Root exception:
Re: OutOfMemoryError during EMF model code generation from XSD source [message #416700 is a reply to message #416697] Wed, 13 February 2008 09:13 Go to previous message
Hi Gerrit,
I am not aware of people having these problems. And I personally
generate the UML2 model (which is quite big) from time to time to make
sure we are not running into those problems.
Perhaps you could attach here the schema that is causing the problem.
Also you could try to set the Java's initial heap size of using the -Xms
argument (like -Xms256M). I am no expert on these things, but I am
noticing that your Xmx is quite high. Keep in mind that the heap should
be in memory all the time so, as a rule of thumb, it should not exceed
70% of your total memory. I am sorry if I am saying things that you
already know.
Marcelo
Gerrit wrote:
> Hello everyone,
> but to no avail.
> sample XSD from the library tutorial gets generated all right.
> give me a hint.
> Thanks in advance!
> Ubuntu Feisty
> Eclipse Platform
> Version: 3.3.1.1
> Eclipse Modeling Framework (EMF) Version: 2.3.1.v200709252135
> !MESSAGE !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Root exception:
Previous Topic:Changing EType of an EAttribute @ runtime
Next Topic:Deleting markers
Current Time: Mon Sep 15 06:18:14 EDT 2025
Powered by FUDForum. Page generated in 0.04339 seconds
