Home » Modeling » EMF » Deleting markers
Deleting markers [message #416688] |
Tue, 12 February 2008 11:19  |
I've been trying to play around with the MarkerUtil class provided by
EMF. I noticed that, when using the general validation example, the
error marker (cause by an empty library name) does not disappear after a
successful validation (library name no longer empty).
I've taken a look at the source code and well the MarkerUtil does not
provide anything else than methods for creating markers. When I saw the
name of that class I imagined it would provide something to handle the
validation status and take action accordingly:
- deleting a previously created marker if the validation was a success,
- creating a new marker if the validation failed.
I hope you will find this comment interesting.
Is there any way to add a few lines of code to the general validation
example to remove the markers after a successful validation?
I could simply get the current file under validation and call the
_deleteMarkers_ method with the proper list of arguments but that just
wouldn't feel right to do so..
Many thanks in advance,
Damien THIVOLLE
[Validation] Re: Deleting markers [message #416689 is a reply to message #416688] |
Tue, 12 February 2008 11:56   |
Hi, Damien,
Please use [Validation] in the subject for questions about the EMF
Validation Framework component. Thanks.
See some responses to your questions in-line, below.
HTH,
Christian
Damien Thivolle wrote:
> Hello,
I thought the the example first cleared the markers of the resource that is
being validated. Perhaps that has changed; the example might enhancement,
there, although working with markers isn't really a primary focus of the
example.
These may be useful enhancements. Note, however, that the reporting of "OK"
status messages in the results of validation is optional, so there are a
variety of cases to consider in determine the differences in the marker
states.
Contributions are welcome!
Yes. You can contribute a patch in the bugzilla database. :-)
Why not? I have seen plenty of applications take exactly this approach.
Re: [Validation] Re: Deleting markers [message #416691 is a reply to message #416689] |
Tue, 12 February 2008 12:40   |
Christian W. Damus a écrit :
> Hi, Damien,
Will do from now on :)
> HTH,
> Christian
>> Hello,
> example.
I've checked the current version on the cvs and it looks exactly like
the one I have so I guess it doesn't clear the markers anymore.
> states.
I will make some proposals tomorrow.
Because these markers were created by MarkerUtil, it would be normal, I
think, that this class also takes care of removing them when they are no
longer needed.
I guess it's possible implement some deleteMarkers method in MarkerUtil.
But at first glance it seemed to me that there should be handler
method in that class that would process the validation results and
update the markers accordingly. That's just a first glance thought, I
don't really know if that class is used for other purposes, etc.
Thanks for your answers,
Damien THIVOLLE | INRIA Rhone-Alpes / VASY
PHD Student | 655, Avenue de l'Europe
damien.thivolle@inria.fr | Montbonnot
http://www.inrialpes.fr/vasy | 38 334 Saint Ismier Cedex France
Re: [Validation] Re: Deleting markers [message #416704 is a reply to message #416691] |
Wed, 13 February 2008 09:30  |
Hi, Damien,
I see that you have raised bugzillae for these issues. Thanks! I look
forward to your contribution.
cW
>> Hi, Damien,
>> HTH,
>> Christian
>>> Hello,
>> is
>> enhancement, there, although working with markers isn't really a primary
>> focus of the example.
>>> success, - creating a new marker if the validation failed.
>> "OK" status messages in the results of validation is optional, so there
>> are a variety of cases to consider in determine the differences in the
>> marker states.
> longer needed.
> Best regards,
Current Time: Mon Sep 15 11:55:12 EDT 2025
Powered by FUDForum. Page generated in 0.25139 seconds
