Home » Modeling » EMF » xsd annotation to specify external interface?
Re: xsd annotation to specify external interface? [message #415091 is a reply to message #415089] |
Thu, 29 November 2007 09:49 |
No real name Messages: 121 Registered: July 2009 |
Hi Ed,
Thanks for the info the documentation.
Problem. I added "ecore:implements" to my schema, perform "reload" on
the genmodel and generated. The interface to implement does not appear
in the target code.
Here is how I use the annotation:
<xs:complexType name="SomeIdReferenceType"
ecore:name="SomeIdReference"
ecore:implements="com.abc.SomeElement">
<xs:simpleContent>
<xs:extension base="abc:IdReferenceType"/>
</xs:simpleContent>
</xs:complexType>
I get:
public interface SomeIdReference extends IdReference {
instead of:
public interface SomeIdReference extends IdReference,SomeElement {
-chris
Ed Merks wrote:
> Chris,
> No, I've not kept the mapping document up to date. It's in the book
> chapter for the next version of the book and we're asking the publishers
> to allow us to make some of these reference chapters available on the
> website.
> Chris Giblin wrote:
>> Thanks Ed!
>> Is "ecore:implements" sounds like just what I need. Is it documented
>> and I overlooked it?
>> Thanks, chris
>> Ed Merks wrote:
>>> Chris,
>>> You can define a complex type and specify ecore:instanceClass on it
>>> to specify the external interface it represents. You can also use
>>> ecore:implements to specify multiple inheritance (additional
>>> eSuperTypes) which could of course refer to another complex type with
>>> the ecore:instanceClass that specifies some external type. This
>>> isn't really an analog for @extends since that's purely a feature to
>>> drive JMerge so that one can avoid having the information about the
>>> inheritance in the model yet still have it in the generated code.
>>> Chris Giblin wrote:
>>>> Hi,
>>>> Is there an "ecore:.." annotation I can use in an XML schema to
>>>> indicate that the generated interface should extend a non-generated,
>>>> external interface? That is, is there an analog to "@extends"
>>>> annotation in Javadoc comment?
>>>> Thanks, chris
Re: xsd annotation to specify external interface? [message #415092 is a reply to message #415091] |
Thu, 29 November 2007 10:02 |
Ed Merks Messages: 33145 Registered: July 2009 |
--------------070006020801010509030408
Chris,
I guess I didn't describe it so well. :-P The value of the implements
must be a QName just like one that would work in base="...".
<xs:complexType name="SomeElement"
ecore:instanceClass="com.abc.SomeElement"/>
ecore:implements="abc:SomeElement">
The annotations even support generics:
Modeling Generics With XML Schema
< http://ed-merks.blogspot.com/2007/06/modeling-generics-with- xml-schema.html>
And it's even possible to express EOperations directly in the schemas,
including their body annotation. A good way to learn about them is
write a simple Ecore model and use the correspond GenModel to export to
an XML Schema. I've tried to ensure that Ecore -> XML Schema -> Ecore
is a round trip...
Chris Giblin wrote:
> Hi Ed,
> in the target code.
> <xs:simpleContent>
> </xs:simpleContent>
> </xs:complexType>
> I get:
> instead of:
> -chris
> Ed Merks wrote:
>> Chris,
>> publishers to allow us to make some of these reference chapters
>> available on the website.
>> Chris Giblin wrote:
>>> Thanks Ed!
>>> Thanks, chris
>>> Ed Merks wrote:
>>>> Chris,
>>>> with the ecore:instanceClass that specifies some external type.
>>>> This isn't really an analog for @extends since that's purely a
>>>> feature to drive JMerge so that one can avoid having the
>>>> information about the inheritance in the model yet still have it in
>>>> the generated code.
>>>> Chris Giblin wrote:
>>>>> Hi,
>>>>> non-generated, external interface? That is, is there an analog to
>>>>> "@extends" annotation in Javadoc comment?
>>>>> Thanks, chris
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Chris,<br>
<br>
must be a QName just like one that would work in base="...".<br>
<blockquote><xs:complexType name="SomeElement"
ecore:instanceClass="com.abc.SomeElement"/><br>
<br>
<br>
<br>
</blockquote>
The annotations even support generics:<br>
<blockquote><a
href=" http://ed-merks.blogspot.com/2007/06/modeling-generics-with- xml-schema.html">Modeling
Generics With XML Schema</a><br>
</blockquote>
Ecore is a round trip...<br>
<br>
<br>
Chris Giblin wrote:
<blockquote cite="mid:fim1v3$hh$1@build.eclipse.org" type="cite">Hi Ed,
<br>
<br>
<br>
in the target code.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<xs:simpleContent>
<br>
<br>
</xs:simpleContent>
<br>
</xs:complexType>
<br>
<br>
I get:
<br>
<br>
<br>
instead of:
<br>
<br>
<br>
<br>
<br>
<br>
-chris
<br>
Ed Merks wrote:
<br>
<blockquote type="cite">Chris,
<br>
<br>
<br>
<br>
<br>
Chris Giblin wrote:
<br>
<blockquote type="cite">Thanks Ed!
<br>
<br>
Thanks, chris
<br>
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
You can define a complex type and specify ecore:instanceClass on it to
the ecore:instanceClass that specifies some external type. This isn't
really an analog for @extends since that's purely a feature to drive
<br>
<br>
<br>
Chris Giblin wrote:
<br>
<blockquote type="cite">Hi,
<br>
<br>
<br>
<br>
Thanks, chris
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------070006020801010509030408--
Ed Merks
Current Time: Wed May 08 02:23:31 GMT 2024
Powered by FUDForum. Page generated in 0.03114 seconds
