Home » Eclipse Projects » Rich Client Platform (RCP) » Eclipse splash screen not showing for RCP application?
Eclipse splash screen not showing for RCP application? [message #414860] Thu, 10 March 2005 10:06 Go to next message
Originally posted by: npickard.ll.mit.edu
I have created an rcp application and "productized" it. I've exported the
application to folder, and it runs quite nicely -however, the splash
screen is not shown. I noticed this thread here:
http://dev.eclipse.org/newslists/news.eclipse.platform.rcp/m sg00632.html
which seems to suggest that you can only use the splash screen by calling
the eclipse.exe. Is this true? Out of interest, if I deleted my
config.ini file (see my settings at the bottom of this post) and called
the following:
eclipse.exe -vmargs -Dosgi.splashPath=platform:/base/plugins/myapp
-Declipse.product=myapp.appproduct
The splash screen worked with the application coming up! This would be
good, but I would really like to use the config.ini file.
I also read this thread:
but it appears I have all the correct settings-
from myappstart.bat file:
java -cp startup.jar org.eclipse.core.launcher.Main -application
myapp.myapp
and in my config.ini file:
osgi.splashLocation = platform:/base/plugins/myapp
here's my folder structure:
/myapp
|-startup.jar
|-myappstart.bat
|-configuration
| |-config.ini
|-plugins
|-myapp
| |-rest of myapp plugin
|-rest of plugins required....
Re: Eclipse splash screen not showing for RCP application? [message #414865 is a reply to message #414860] Thu, 10 March 2005 12:08 Go to previous messageGo to next message
Originally posted by: cervezas.no-spam-pikesoft.com
Have you tried using the Product Configuration File wizard or the new
product editor in Eclipse 3.1 M5? There is a nice product export feature
now that will generate a MyApp.exe native launcher with the splash.bmp you
provide. To be honest with you I never had much success with what you are
doing either until they rolled this out, so don't feel bad!
David
David Beers
Pikesoft Mobile Computing
www.pikesoft.com
"Nigel Pickard" <npickard@ll.mit.edu> wrote in message
news:d0pnpc$hca$1@www.eclipse.org...
> the following:
> myapp.myapp
> /myapp
> |-startup.jar
> |-myappstart.bat
> |-configuration
> | |-config.ini
> |-plugins
> |-myapp
Re: Eclipse splash screen not showing for RCP application? [message #414869 is a reply to message #414865] Thu, 10 March 2005 12:44 Go to previous messageGo to next message
Thanks David -I see that's a non-stable release, and I can't imagine it
would be welcomed where I work. Looks like I'll have to wait a little
longer as well as look at this at home!
> David
Re: Eclipse splash screen not showing for RCP application? [message #414878 is a reply to message #414869] Thu, 10 March 2005 20:15 Go to previous messageGo to next message
You can develop with 3.1 but still produce an RCP app for eclipse 3.0,
just change the target platform to point at a 3.0 install (preferences >
PDE > target platform).
PaScaL
>> you
>> are
>> David
Re: Eclipse splash screen not showing for RCP application? [message #414955 is a reply to message #414865] Mon, 14 March 2005 14:07 Go to previous messageGo to next message
Where's this export feature/product editor hidden ?
Can't find it in my 3.1M5 installation...
Re: Eclipse splash screen not showing for RCP application? [message #415376 is a reply to message #414955] Tue, 15 March 2005 08:36 Go to previous messageGo to next message
Ignore my message, I found it in den "New..." wizard.
Axel
Re: Eclipse splash screen not showing for RCP application? [message #415396 is a reply to message #414869] Tue, 15 March 2005 16:35 Go to previous messageGo to next message
That's too bad, you really miss out by not using the Milestone builds. Plus
it helps the developers to report problems in code they just wrote rather
than in code they wrote a year or more ago in the release build.
Ed Burnette
www.eclipsepowered.org
news:d0q113$b9r$1@www.eclipse.org...
Re: Eclipse splash screen not showing for RCP application? [message #416053 is a reply to message #414860] Thu, 17 March 2005 08:24 Go to previous message
Try using osgi.splashPath instead.
osgi.splashPath= platform:/base/plugins/myapp
Vadim Ilves.
Previous Topic:unattach all views from window
Next Topic:Classloading issue
Current Time: Wed Sep 24 21:07:35 EDT 2025
Powered by FUDForum. Page generated in 0.06531 seconds
