Home » Modeling » EMF » Super class references get lost when saving ecore models
Super class references get lost when saving ecore models [message #412221] Fri, 17 August 2007 10:28 Go to next message
Hi there,
after upgrading to EMF 2.3 I have some problems regarding inheritance
between EClasses in generated Ecore models.
Background: For developing my Ecore models, I'm using a graphical UML
editor based on the Eclipse UML2 plugin. This plugin comes with a
UML-to-Ecore converter, which I am using. After upgrading to the latest
releases, the generalizations from the UML models get (partly) lost when
translating the models into Ecore and saving the Ecore file.
I have debugged into the issue and built a test case that reproduces the
problem (see test code below).
In detail:
- the org.eclipse.uml2.uml.util.UMLUtil$UML2EcoreConverter uses the new
EMF generics feature
- super classes are set by wrapping them into an EGenericType object and
adding this wrapper to the eGenericSuperTypes collection of the subclass
- this means the eSuperTypes collection of the subclass is NOT
initialized yet
When saving the Ecore file, the following things happen:
- all features of an EClass are iterated and checked if they must be saved
- this sooner or later accesses the isSetESuperTypes and the
isSetEGenericSuperTypes methods
- both of them return false, because the eSuperTypes collection is a
derived feature which has not been initialized yet (its still null), and
because the eGenericSuperTypes collection (which is not null) returns
false for the isSet method (eType is null)
- therefore, the inheritance will not be saved in the resulting ecore file
Workaround:
- iterate through the resource and call getESuperTypes() on all EClasses
before saving them
So, the question now is:
What is broken? Is the UML-to-Ecore-Converter not implemented correctly?
Or is it a bug in the save mechanism of EMF?
thank you,
Peter
Here is the sample code:
public class EMFTest
public static void main(String[] args)
// create a package with two classes
EPackage p1 = EcoreFactory.eINSTANCE.createEPackage();
p1.setName("mypackage");
EClass c1 = EcoreFactory.eINSTANCE.createEClass();
c1.setName("MySuperClass");
p1.getEClassifiers().add(c1);
EClass c2 = EcoreFactory.eINSTANCE.createEClass();
c2.setName("MySubClass");
p1.getEClassifiers().add(c2);
// Variant 1:
// with this, the super class reference will not be saved
EGenericType g1 = EcoreFactory.eINSTANCE.createEGenericType();
g1.setEClassifier(c1);
c2.getEGenericSuperTypes().add(g1);
// Variant 2:
// this works fine
// c2.getESuperTypes().add(c1);
ResourceSet rs = new ResourceSetImpl();
rs.getResourceFactoryRegistry().getExtensionToFactoryMap().p ut(
Resource.Factory.Registry.DEFAULT_EXTENSION,
new XMIResourceFactoryImpl());
URI uri = URI.createFileURI(new
File("test/model.ecore").getAbsolutePath());
Resource r = rs.createResource(uri);
r.getContents().add(p1);
try
r.save(Collections.EMPTY_MAP);
catch (IOException e)
e.printStackTrace();
Re: Super class references get lost when saving ecore models [message #412224 is a reply to message #412221] Fri, 17 August 2007 10:45 Go to previous messageGo to next message
Peter,
Sounds like a bug. Please open a bugzilla and I'll investigate and fix
for next week's build.
Peter Hänsgen wrote:
> Hi there,
> latest releases, the generalizations from the UML models get (partly)
> lost when translating the models into Ecore and saving the Ecore file.
> the problem (see test code below).
> In detail:
> new EMF generics feature
> and adding this wrapper to the eGenericSuperTypes collection of the
> subclass
> initialized yet
> saved
> and because the eGenericSuperTypes collection (which is not null)
> returns false for the isSet method (eType is null)
> file
> Workaround:
> EClasses before saving them
> correctly? Or is it a bug in the save mechanism of EMF?
> thank you,
> Peter
> // Variant 1:
> EGenericType g1 =
> // Variant 2:
> // this works fine
> try
Re: Super class references get lost when saving ecore models [message #412226 is a reply to message #412224] Fri, 17 August 2007 11:06 Go to previous message
Ed Merks wrote:
> Peter,
done.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=200373
Previous Topic:Custom CellEditor for Properties view
Next Topic:Whitespace is not collapsed for objects generated from xs:Name and xs:NMTOKEN types
Current Time: Wed Nov 05 07:46:53 EST 2025
Powered by FUDForum. Page generated in 0.02929 seconds
