Home » Modeling » EMF » how to select next element after deleting one
how to select next element after deleting one [message #412188] Fri, 17 August 2007 05:52 Go to next message
Originally posted by: harald.loehnert.brueckner.com
how can I achieve, that after deleting an EObject (using Command-Stack
an DeleteCommand), the next object in the container is selected in the
editor. In case it was the last object, the "new" last object should be
selected.
Thanks for any help.
Harald.
Re: how to select next element after deleting one [message #412201 is a reply to message #412188] Fri, 17 August 2007 07:49 Go to previous message
Harald,
Whatever is returned by the command's getAffectedObjects will be
selected after the command execution completes. Keep in mind that this
means you'll likely want to change what's returned after an undo and
again after a redo.
Harald Löhnert wrote:
> be selected.
> Harald.
Previous Topic:JMerge Support for Java5 Annotations
Next Topic:ant for JET?
Current Time: Wed Nov 05 07:47:00 EST 2025
Powered by FUDForum. Page generated in 0.04929 seconds
