Home » Modeling » EMF » Dynamically loading model specific code from within generated code.
Dynamically loading model specific code from within generated code. [message #412073] Thu, 16 August 2007 08:15 Go to next message
I am trying to do the followin:
In my Model there´s an EClass 'Service' that has an inherited name
(String) attribute, and a function 'query()' which returns an Object.
The implementation of query() is model specific (for every instance of
Service I want to write a different implementation for the query function.
Suppose I got a model instance with two Services with names
'modelinstance.RecipeOfTheDay' and another one 'modelinstance.MoonPhases'.
I now created a Datatype 'Query' which is an interface that only
contains the 'query()' method declaration.
I now set up a contract that for every Service in a Model instance which
must be fulfilled:
- there must be a (hand written) class that implements the Query interface.
- the fqn of that class must be:
'service.getName().toLowerCase().concat(".QueryImpl")
(for the example above the to handwritten classes fqns would be:
modelinstance.recipeoftheday.QueryImpl
modelinstance.moonphases.QueryImpl)
Now I insert code into the generated ServiceImpl class that dynamically
tries to load the respective hand-written query implementation as soon
as possible, and delegate all calls to service.query() to QueryImpl.query();
I now have problems finding the 'as soon as possible':
To me, as soon as possible is the point where a services name attribute
is set by the Resource model instantiation code (the model is loaded
from an xmi file).
So the first idea was to just modify the setName() function inside the
generated Class. Unfortunately the name attribute is inherited from a
superclass 'AbstractService'. Overwriting the setName() method in
ServiceImpl.java does not help, it seems the ResourceLoader calls
setName() for AbstractService.
Since this did not work i tried to observe the name Attribute with an
Adapter. I overwrote the ServiceImpl() constructor to automatically add
an Observer for the name Attribute, like this:
public ServiceImpl(){
super();
// inserted code
eAdapters.add(new NameObserver());
This doesn´t work, I get a NullPointerException.
The only thing that´s left is to load the model-specific delegation
class at the first call to the query() function.
Is this the only working possibility?
Of course I could also write some external code that initializes the
Query implementations from Outside, but this isn´t half as nice...
Thanks for your comments,
Felix
Re: Dynamically loading model specific code from within generated code. [message #412077 is a reply to message #412073] Thu, 16 August 2007 08:54 Go to previous messageGo to next message
Felix,
Comments below.
Felix Dorner wrote:
> function.
I suppose you could have made this an EClass with only an EOperation for
query and marked its isInterface to be true so that only the interface
is generated. Then Service could extend it...
> which must be fulfilled:
> interface.
If you did the above, then the class could be modeled and generated.
So you'll use reflection to find the class I suppose...
> dynamically tries to load the respective hand-written query
> implementation as soon as possible, and delegate all calls to
> attribute is set by the Resource model instantiation code (the model
> is loaded from an xmi file).
Why not wait until the first invocation?
If you override it, it definitely should call yours...
> add an Observer for the name Attribute, like this:
> super();
> // inserted code
I suppose you should use eAdapters() to ensure that the list is actually
created.
That does seem best in any case...
It seems to me it would maybe be nicer if all services were modeled
subclasses of query and then they could have their own persistent data
when they are serialized. But I might not understand the use case very
well.
> Felix
Re: Dynamically loading model specific code from within generated code. [message #412078 is a reply to message #412077] Thu, 16 August 2007 09:13 Go to previous message
Yeah thats true.
I consider this bad because I want to check that the above contract is
fulfilled as soon as possible, i.e. at model instantiation time.
Otherwise an instance may run for a long time (well - minutes in this
case...:-D) with a predictible runtime exception when the first
invocation occurs.
Hmm i´ll check that again.
> created.
Shame on me..
> well.
The use case above is a radical abstraction from what I am actually
doing. Anyway, if one could ever know before starting to design a model
how requirements will evolve... :-s
Thanks Ed for your (as always) fast response.
Previous Topic:Working with edges on nodes
Next Topic:Disallow deletion of a node in the tree
Current Time: Wed Nov 05 07:46:34 EST 2025
Powered by FUDForum. Page generated in 0.03513 seconds
