Home » Modeling » EMF » Reflectively modifying EObjects without notifications
Reflectively modifying EObjects without notifications [message #411427] Wed, 25 July 2007 14:21 Go to next message
I need to modify the instance state of EObjects reflectively and there
must not occur notifications or inverse updates. Is that somehow possible?
Cheers
/Eike
Re: Reflectively modifying EObjects without notifications [message #411428 is a reply to message #411427] Wed, 25 July 2007 14:25 Go to previous messageGo to next message
Eike Stepper schrieb:
> possible?
.... and that includes setting the direct containing resource.
for the container/containerFeatureID that seems already possible through
eBasicSetContainer(), right?
> Cheers
> /Eike
Re: Reflectively modifying EObjects without notifications [message #411431 is a reply to message #411428] Wed, 25 July 2007 15:37 Go to previous messageGo to next message
Eike,
You can turn notification off with Notifier.eSetDeliver(false). Doing
1/2 a bidirectional update seems tricky. Using
InternalEObject.eInverseAdd will help, but you don't have control over
the position. If what you're doing is store-based, I'm surprised you
need to do this kind of thing...
>> there must not occur notifications or inverse updates. Is that
>> somehow possible?
> through eBasicSetContainer(), right?
>> Cheers
>> /Eike
Re: Reflectively modifying EObjects without notifications [message #411436 is a reply to message #411431] Wed, 25 July 2007 16:46 Go to previous messageGo to next message
Ed Merks schrieb:
> Eike,
Since this can occur from a background thread I'm not sure if this is
the best solution but I'll keep that in mind.
> Doing 1/2 a bidirectional update seems tricky. Using
> the position.
For to-many features I have a different approach. I use basicAdd() and
basicRemove() methods from InternalEList. Do you think your idea is
better, maybe because of things like feature maps or so?
> If what you're doing is store-based, I'm surprised you need to do this
> kind of thing...
Good point. But I'm currently implementing a new feature. In addition to
models generated for CDO or loaded dynamically (in both cases a store is
used) I start to transparently support arbirtray generated models. And
even Ecore itself. The only things that make it a bit hard are:
1. I can't intercept the accessors before they are executed.
2. Transfering state from the framework to an EObject currently works
reflectively to circumvent the notification. (models generated with
Boolean Flags = true are especially painful)
Maybe I can go with simply suspending notifications via
eSetDeliver(false) as you suggested.
Ah, and setting the resource without inverse update is not nice:
private void transferResourceToTarget(BasicEObjectImpl target,
Resource.Internal resource)
Method method = ReflectUtil.getMethod(BasicEObjectImpl.class,
"eSetDirectResource", Resource.Internal.class);
try
ReflectUtil.invokeMethod(method, target, resource);
catch (InvocationTargetException ex)
throw WrappedException.wrap(ex);
But in general it works quite well. When I'm ready I'll send you a new
Team PSF ;-)
Cheers
/Eike
>>> Hi,
>>> somehow possible?
>>> Cheers
>>> /Eike
Re: Reflectively modifying EObjects without notifications [message #411437 is a reply to message #411436] Wed, 25 July 2007 17:08 Go to previous message
Eike,
Comments below.
Eike Stepper wrote:
> Ed Merks schrieb:
>> Eike,
Well, if there is a threading problem with this, there will be one with
accessing the actual data anyway I imagine.
>> over the position.
The generated eInverseAdd will call methods like that anyway. It's just
that eInverseAdd works for single or multi valued references.
FeatureMap would need more direct access as you are doing...
> to models generated for CDO or loaded dynamically (in both cases a
> store is used) I start to transparently support arbirtray generated
> models. And even Ecore itself. The only things that make it a bit hard
> are:
Many folks have wanted something like a read notification, but I think
this would just kill performance in general so it would need to be
optional and once it's optional, you can't generally rely on it anymore...
That does seem simplest...
> try
If I added the method to InternalEObject, I'd have to make it public and
that could be a source incompatibility for downstream clients...
> Team PSF ;-)
Sounds cool!
> Cheers
> /Eike
>>>> Hi,
>>>> somehow possible?
>>>> Cheers
>>>> /Eike
Previous Topic:Name-based hrefs
Next Topic:My model is not listed in Example EMF Model Creation Wizards (even though the model plugin was loade
Current Time: Fri Nov 07 15:31:12 EST 2025
Powered by FUDForum. Page generated in 0.04285 seconds
