Home » Modeling » EMF » Serializing a dynamic model instance with xsi:schemaLocation
| Serializing a dynamic model instance with xsi:schemaLocation [message #411303] |
Sat, 21 July 2007 04:28  |
I successfully generated a dynamic Ecore model from an XML Schema using
XSDEcoreBuilder, and created its instance using the generated EPackages,
by following the article below:
http://wiki.eclipse.org/index.php/Generating_Dynamic_Ecore_f rom_XML_Schema
How can I serialize the instance with xsi:schemaLocation?
I set OPTION_SCHEMA_LOCATION, but it didn't work. I also tried to set
"xSISchemaLocation" of the DynamicEObject "DocumentRoot" by the following
code, but xsi:schemaLocation did not appear.
EClass documentRootClass = (EClass)
ePackage.getEClassifier("DocumentRoot");
EObject documentRoot = EcoreUtil.create(documentRootClass);
EMap<String, String> map = (EMap<String, String>)
documentRoot.eGet(documentRootClass.getEStructuralFeature("xSISchemaLocation "));
map.put(ePackage.getNsURI(), "sample.xsd");
Do I have to serialize the Ecore model as .ecore file in advance?
Koji
| Re: Serializing a dynamic model instance with xsi:schemaLocation [message #411306 is a reply to message #411303] |
Sat, 21 July 2007 08:17   |
--------------030008080402010707030002
Koji,
Comments below.
Koji Hashimoto wrote:
> using XSDEcoreBuilder, and created its instance using the generated
> EPackages, by following the article below:
You've used this option for save not just load?
> I also tried to set "xSISchemaLocation" of the DynamicEObject
> "DocumentRoot" by the following code, but xsi:schemaLocation did not
> appear.
Using this would be simpler:
documentRoot.eGet(ExtendedMetaData.INSTANCE.getXSISchemaLoca tionMap(documentRoot.eClass()));
I would expect the above should definitely do the trick. It does when I
try it.
When an instance document is serialized, if the EPackage's nsURI is
different from the EPackage's eResource()'s URI and the
OPTION_SCHEMA_LOCATION is mapped to Boolean.TRUE, it will automatically
serialize an xsi:schemaLocation for the nsURI -> packageResourceURI mapping.
> Koji
<html>
<head>
http-equiv="Content-Type">
</head>
Koji,<br>
<br>
Comments below.<br>
<br>
<br>
<blockquote
cite="mid:3d5840065018a31634fac40ff206be64$1@www.eclipse.org"
type="cite">Hi,
<br>
<br>
<br>
<a class="moz-txt-link-freetext" href=" http://wiki.eclipse.org/index.php/Generating_Dynamic_Ecore_f rom_XML_Schema"> http://wiki.eclipse.org/index.php/Generating_Dynamic_Ecore_f rom_XML_Schema</a>
<br>
<br>
<br>
<br>
I set OPTION_SCHEMA_LOCATION, but it didn't work. </blockquote>
You've used this option for save not just load?<br>
<blockquote
type="cite">I also tried to set "xSISchemaLocation" of the
DynamicEObject "DocumentRoot" by the following code, but
<br>
<br>
<br>
<br>
<br>
</blockquote>
Using this would be simpler:<br>
<blockquote> documentRoot.eGet(ExtendedMetaData.INSTANCE.getXSISchemaLoca tionMap(documentRoot.eClass()));
</blockquote>
<blockquote
type="cite">map.put(ePackage.getNsURI(), "sample.xsd");
<br>
| Re: Serializing a dynamic model instance with xsi:schemaLocation [message #411309 is a reply to message #411306] |
Sun, 22 July 2007 08:16   |
Ed,
Thank you for your reply.
Yes, I have used OPTION_SCHEMA_LOCATION only for save.
eResource() of the EPackage generated dynamically from an XML Schema is
null. Therefore, I thought that the EPackage has to be saved as .ecore
file as stated in the EMF book.
Koji
Ed Merks wrote:
> Koji,
> Comments below.
>> appear.
> try it.
>> Thanks,
>> Koji
| Re: Serializing a dynamic model instance with xsi:schemaLocation [message #411310 is a reply to message #411309] |
Sun, 22 July 2007 09:38   |
Koji,
XSDEcoreBuilder.generateResources will generate resources for the Ecore
package's it creates and will set the URI of that resource to match the
package's nsURI. You could modify the resulting resources to set the
URI to be the original schema's location.
> Ed,
>> automatically serialize an xsi:schemaLocation for the nsURI ->
> is null. Therefore, I thought that the EPackage has to be saved as
> .ecore file as stated in the EMF book.
> Koji
> Ed Merks wrote:
>> Koji,
>> Comments below.
>>> Hi,
>>> appear.
>> when I try it.
>>> Thanks,
>>> Koji
| Re: Serializing a dynamic model instance with xsi:schemaLocation [message #411320 is a reply to message #411310] |
Mon, 23 July 2007 08:30   |
Ed,
XSDEcoreBuilder.generateResouces() solves my problem! Thank you for
your help!
I successfully serialized an instance document with xsi:schemaLocation
by the following experimental code:
XSDEcoreBuilder xsdEcoreBuilder = new XSDEcoreBuilder();
Collection<Resource> resources =
xsdEcoreBuilder.generateResources(schemaURI);
EPackage ePackage = null;
for (Resource resource : resources) {
if (resource instanceof XSDResourceImpl) {
// schemaURI = resource.getURI();
} else {
ePackage = (EPackage) resource.getContents().get(0);
EObject documentRoot = EcoreUtil.create((EClass) ePackage.getEClassifier("DocumentRoot"));
ResourceSet resourceSet = ePackage.eResource().getResourceSet();
Resource resource = resourceSet.createResource(URI.createURI("platform:/resource/project/sample.xml "));
resource.getContents().add(documentRoot);
ePackage.eResource().setURI(schemaURI);
Map<Object, Object> saveOptions = new HashMap<Object, Object>(1);
saveOptions.put(XMLResource.OPTION_SCHEMA_LOCATION, Boolean.TRUE);
resource.save(saveOptions);
By the way, the following article says "For these loaded Ecores to be
available, we need to register them to the global package registry.",
but I think this is incorrect. The snipet in the article registers
resourceSet's local package registry. Am I right?
Koji
Ed Merks wrote:
> Koji,
> > Ed,
> > Thanks,
> > Koji
> > Ed Merks wrote:
> >> Koji,
> >> Comments below.
> >>> Hi,
> >>> appear.
> >> when I try it.
> >>> Thanks,
> >>> Koji
| Re: Serializing a dynamic model instance with xsi:schemaLocation [message #411321 is a reply to message #411320] |
Mon, 23 July 2007 08:34  |
Koji,
Yes the article registers them in the local package registry of the
resource set, so I've modified it to not refer to the global one.
Thanks. :-)
> Ed,
> your help!
> } else {
> Koji
> Ed Merks wrote:
>> Koji,
>>> Ed,
>>> Thanks,
>>> Koji
>>> Ed Merks wrote:
>>>> Koji,
>>>> Comments below.
>>>>> Hi,
>>>>> appear.
>>>> when I try it.
>>>>> Thanks,
>>>>> Koji
Current Time: Tue Oct 28 03:59:23 EDT 2025
Powered by FUDForum. Page generated in 0.33127 seconds
