Home » Eclipse Projects » Rich Client Platform (RCP) » How to continuously update/refresh JFACE tableviewer
How to continuously update/refresh JFACE tableviewer [message #409748] |
Mon, 14 February 2005 13:57 |
Originally posted by: rathdeep.yahoo.com
Hi all,
I have created a table inside a JFACE tableviewer.
I want to dynamically update the contents of its columns.
Like one column with % of completion of a task. I increase the counter
from 1 to 10000 and i want to refresh its content after each increment.
I have code something like this
TableItem item = table.getItem();
for( int i=0;i<10000;i++)
item.setText(4,"%bytes sent" + i); /*
After each insert how to refresh view contents
tableViewer.refresh(table,true); //not working / presently view hangs
until int //i reaches 100000
Any pointers would of great help.
Re: How to continuously update/refresh JFACE tableviewer [message #409977 is a reply to message #409748] |
Tue, 15 February 2005 15:28 |
Raj Saini Messages: 53 Registered: July 2009 |
Member |
To update the contents of your tableViewer dynamically you will need to
write Content Provider and Label Provider for your table viewer. When
Data in yout content model changes, your content provider should update
the table coloums automatically.
For example:
tableViewer = new TableViewer(table);
tableViewer.setLabelProvider(new StockQuoteViewLabelProvider());
tableViewer.setContentProvider(new
StockQuoteContentProvider(tableViewer));
Example ContentProvider:
public class StockQuoteContentProvider implements
IStructuredContentProvider, ContentChangeListener
protected TableViewer tableViewer;
public StockQuoteContentProvider(TableViewer tableViewer)
this.tableViewer = tableViewer;
public Object[] getElements(Object inputElement)
return ((StockQuoteService)inputElement).getStockQuotes();
public void dispose()
//empty
public void inputChanged(Viewer viewer, Object oldInput, Object newInput)
if (newInput != null)
((StockQuoteService) newInput).addChangeListener(this);
if (oldInput != null)
((StockQuoteService) oldInput).removeChangeListener(this);
/* (non-Javadoc)
* @see
com.bttlindia.tradestart.quoteservice.ContentChangeListener# add(java.lang.Object)
public void add(final Object obj)
tableViewer.getTable().getDisplay().asyncExec(new Runnable ()
public void run ()
tableViewer.add(obj);
/* (non-Javadoc)
* @see
com.bttlindia.tradestart.quoteservice.ContentChangeListener# update(java.lang.Object)
public void update(final Object obj)
tableViewer.getTable().getDisplay().asyncExec(new Runnable()
public void run()
tableViewer.update(obj, null);
/* (non-Javadoc)
* @see
com.bttlindia.tradestart.quoteservice.ContentChangeListener# remove(java.lang.Object)
public void remove(Object obj)
tableViewer.remove(obj);
/* (non-Javadoc)
* @see
com.bttlindia.tradestart.quoteservice.ContentChangeListener# refresh()
public void refresh()
public void run()
tableViewer.refresh();
Example Label Provider:
public class StockQuoteViewLabelProvider extends LabelProvider implements
ITableLabelProvider
private Image upImage;
private Image equalImage;
private Image downImage;
public StockQuoteViewLabelProvider()
ImageDescriptor upImageDescriptor =
AbstractUIPlugin.imageDescriptorFromPlugin(StockQuotePlugin. PLUGIN_ID,
"icons/full/eview16/up.png");
upImage = upImageDescriptor.createImage();
ImageDescriptor equalImageDescriptor =
"icons/full/eview16/equal.png");
equalImage = equalImageDescriptor.createImage();
ImageDescriptor downImageDescriptor =
"icons/full/eview16/down.png");
downImage = downImageDescriptor.createImage();
public Image getColumnImage(Object element, int columnIndex)
if(columnIndex == 3)
if(((StockQuote)element).getLastPriceChange()< 0)
return downImage;
}else if(((StockQuote)element).getLastPriceChange() > 0)
return upImage;
return equalImage;
return null;
public String getColumnText(Object element, int columnIndex)
StockQuote quote = (StockQuote) element;
switch (columnIndex)
case 0:
return quote.getSymbol().trim();
case 1:
return quote.getName();
case 2:
return (new BigDecimal
(quote.getLastPrice())).setScale(3, BigDecimal.ROUND_HALF_UP).toString();
case 3:
return (new
BigDecimal(quote.getVarPercentage())).setScale(3,
case 4:
return (new Integer(quote.getBidQty())).toString();
case 5:
return (new
BigDecimal(quote.getBidPrice())).setScale(3,
case 6:
return (new
BigDecimal(quote.getAskPrice())).setScale(3,
case 7:
return (new Integer(quote.getAskQty())).toString();
case 8:
return (new
BigDecimal(quote.getOpenPrice())).setScale(3,
case 9:
return (new BigDecimal(quote.getDayHigh())).setScale(3,
case 10:
return (new BigDecimal(quote.getDayLow())).setScale(3,
case 11:
return (new
BigDecimal(quote.getClosePrice())).setScale(3,
case 12:
return new Long(quote.getVolume()).toString();
case 13:
Date transDate = quote.getLastTransactionTime();
SimpleDateFormat format = new SimpleDateFormat("HH:mm");
return format.format(transDate);
return "";
upImage.dispose();
upImage = null;
equalImage.dispose();
equalImage = null;
downImage.dispose();
downImage = null;
dc wrote:
> Hi all,
> I have created a table inside a JFACE tableviewer. I want to dynamically
Re: How to continuously update/refresh JFACE tableviewer [message #410030 is a reply to message #409977] |
Wed, 16 February 2005 12:10 |
Thanks Raj
Raj Saini wrote:
> For example:
> //empty
> /* (non-Javadoc)
> * @see
> public void run ()
> /* (non-Javadoc)
> * @see
> public void run()
> /* (non-Javadoc)
> * @see
> /* (non-Javadoc)
> * @see
> public void run()
> ITableLabelProvider
> return downImage;
> return upImage;
> return equalImage;
> return null;
> case 0:
> case 1:
> case 2:
> case 3:
> return (new
> case 4:
> case 5:
> return (new
> case 6:
> return (new
> case 7:
> case 8:
> return (new
> case 9:
> case 10:
> case 11:
> return (new
> case 12:
> case 13:
> return "";
> upImage.dispose();
> upImage = null;
> equalImage = null;
> downImage = null;
> dc wrote:
>> Hi all,
Re: How to continuously update/refresh JFACE tableviewer [message #1386865 is a reply to message #410030] |
Sat, 21 June 2014 23:29 |
Hello;
I need your help regarding the same topic here. I am recieving data from server and would like to display them syncroniously on a TableViewer. I am using this code snippet :
public void inputChanged(Viewer viewer, Object oldInput, Object newInput) {
final ArrayList<ProcessChain> finalInput = (ArrayList<ProcessChain>) newInput;
final PROCESSCHAINView processchainView = (PROCESSCHAINView) Activator.getDefault().getWorkbench().getActiveWorkbenchWindow().getActivePage().findView(PROCESSCHAINView.ID);
Display tableviewerDisplay = processchainView.getViewer().getTable().getDisplay();
if (finalInput != null)
Activator.getDefault().getWorkbench().getDisplay().syncExec(new Runnable() {
public void run() {
processchainView.getViewer().update(finalInput, null);
processchainView.getViewer().refresh();
The viewer is freezing and this is not doing what I want.
Could you please detail the provided solution .
[Updated on: Mon, 23 June 2014 13:25] by Moderator Report message to a moderator
Current Time: Fri Apr 26 10:24:48 GMT 2024
Powered by FUDForum. Page generated in 0.03058 seconds
