Home » Modeling » EMF » EMF model Search
EMF model Search [message #408481] Fri, 13 April 2007 04:56 Go to next message
I wanted to Know what are possible options to provide Search options for EMF model objects (Structural Search).
Or there are any EMF plugins which provides this options.
Please let me know, as we need to provide Search option for EMF editor
BG
Re: EMF model Search [message #408491 is a reply to message #408481] Fri, 13 April 2007 08:34 Go to previous messageGo to next message
Byre,
I noticed the Peter has a find and replace facility at his website:
http://www.eclipticalsoftware.com/. We really need to chat with Peter
after this release cycle to see how much of the cool stuff he's worked
on could be pulled into EMF...
There are also some folks interested in starting a new search component
for EMF: https://bugs.eclipse.org/bugs/show_bug.cgi?id=180492
Byre BG wrote:
> Hello,
> Regards
> BG
Re: EMF model Search [message #408499 is a reply to message #408491] Fri, 13 April 2007 09:53 Go to previous messageGo to next message
Originally posted by: lucas.bigeardel.anyware-tech.com
Byre,
An EMF Model Search EMF(T)component proposal will be posted soon.
For the moment, you can copy jars attached with bug 180492 in you
Eclipse 3.2+/EMF 2.2+ (/UML2 1+) install and it will contribute a new
tab in your Eclipse Search dialog (Ctrl+H).
This EMF search allows you to make Regex/textual queries on EMF elements
names, you can also discriminate query scope by selecting which
meta-elements you want your query to apply to and which resource scope
to find your ecore models into.
Jars : https://bugs.eclipse.org/bugs/attachment.cgi?id=62753
HTH,
- Lucas
Ed Merks a écrit :
> Byre,
> Byre BG wrote:
>> Hello,
>> Regards
>> BG
Re: EMF model Search [message #408511 is a reply to message #408491] Fri, 13 April 2007 14:11 Go to previous messageGo to next message
Hi, Byre,
OCL is also useful as a query language for EMF-based models, not just as a
constraint language. Especially using such constructs as
MyClass.allInstances() and Tuples to perform SQL-like "projection".
Check it out at http://www.eclipse.org/modeling/mdt/?project=ocl
Christian
Ed Merks wrote:
> Byre,
> Byre BG wrote:
>> Hello,
>> Regards
>> BG
Re: EMF model Search [message #408528 is a reply to message #408481] Mon, 16 April 2007 01:22 Go to previous message
Hello all,
Thanx for all you valuable suggestions. But the scenario of My Search requirement is different
1. We have created RCP application using EMF
2. We have modified the emf generated editor for our customisation similar to manifest editor
3. We have to provide the search option on the editor.
Let me know how to proceed here?.Do i need to create our own search option.What are the other possible options
Thanks in advance,
BG
Previous Topic:EMF 2.3.0 can't create simple model from annotated Java?
Next Topic:XML Representation of XMLResource object
Current Time: Tue Oct 28 18:02:59 EDT 2025
Powered by FUDForum. Page generated in 0.06117 seconds
