| JET settings bug ? [message #408397] |
Tue, 10 April 2007 13:05  |
I am writing a code generator based on the one provided by EMF in the
same manner than UML2 codegen does.
Indeed, I have some jet templates located under a template folder.
In my Class.javajet, I included Class.javajet from EMF codegen templates.
To be able to compile my templates, I have to set the "template
containers" variable in JET nature settings.
I try to enter something like that:
templates;@/platform:plugin/org.eclipse.emf.codegen.ecore/te mplates
But it raises an error : "no relative path uri or no hiearchical uri" (I
have no longer the right error message in mind...)
My workaround was to import the emf.codegen.ecore plugin and modify the
variable like that:
templates;@/org.eclipse.emf.codegen.ecore/templates
Does anyone meet the same problem ?
Is it mandatory to import the emf codegen plugin into the workspace to
access provided templates by EMF?
I'm a bit surprise that platform uri scheme is not supported.
Stephane.
| Re: JET settings bug ? [message #408402 is a reply to message #408401] |
Tue, 10 April 2007 13:57  |
Oups, I forgot one "/"
That one fails:
templates;@/platform:/plugin/org.eclipse.emf.codegen.ecore/t emplates
Stephane.
Stéphane Fournier wrote:
> Thank you Ed !
> Those solutions work :
> templates;@platform:/plugin/org.eclipse.emf.codegen.ecore/te mplates
> templates;@platform:plugin/org.eclipse.emf.codegen.ecore/tem plates
> That one fails:
> Stephane.
> Ed Merks wrote:
>> Stéphane,
>> Would this work better:
>> I.e., not putting a "/" in front of the platform? (Or at least
>> including the / after the "platform:".)
>> I'll look more closely if that doesn't do the trick...
>>> Hi,
>>> templates.
>>> (I have no longer the right error message in mind...)
>>> the variable like that:
>>> to access provided templates by EMF?
>>> Stephane.
FUDForum. Page generated in 0.07218 seconds
