Re: .genmodel that opened in 3.3M4 fails to open in 3.3M5 [message #408389 is a reply to message #408377] |
Tue, 10 April 2007 15:06 |
John Yotka Messages: 144 Registered: July 2009 |
Ed Merks wrote:
> John,
> For the enum problem, you must have an empty string as the instance type
> name. Please open a bugzilla and I'll change the code so that it's not
> possible via the GUI to set the instance type name to the empty string
> (which happens accidentally just from activating the cell editor). Use
> the property view's toolbar's "Restore Default Value" button to set it
> back to null.
> I could reproduce the bogus operation complaint as well, so please open
> a bugzilla for that too and well have a fix for it by Thursday's build.
> I'm looking into the cause now...
> John Yotka wrote:
>> Ed Merks wrote:
>>> John,
>>> Try opening the .ecore file directly and invoking "Validate" from the
>>> popup menu on the package. It sounds like there's an attribute of
>>> type "boolean" that has an empty string as its default value. I'll
>>> try to reproduce this problem tomorrow since such an program should
>>> just result in a validation diagnostic, not a failure to load the
>>> .genmodel...
>>> John Yotka wrote:
>>>> I'm working in GMF and upgraded from GMF M4 to GMF M5. A model
>>>> ..genmodel file that opened ok under eclipse 3.3M4 (EMF
>>>> 2.3.0.vv200612211251) now fails to open (EMF 2.3.0.v200703291501),
>>>> with the following error:
>>>> Unable to create editor ID
>>>> org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel EditorID:
>>>> Invalid boolean value: ''
>>>> org.eclipse.emf.ecore.xml.type.InvalidDatatypeValueException :
>>>> at
>>>> org.eclipse.emf.ecore.xml.type.impl.XMLTypeFactoryImpl.boole anValueOf(XMLTypeFactoryImpl.java:2886)
>>>> at
>>>> org.eclipse.emf.ecore.xml.type.impl.XMLTypeFactoryImpl.creat eBooleanObject(XMLTypeFactoryImpl.java:169)
>>>> at
>>>> org.eclipse.emf.ecore.xml.type.impl.XMLTypeFactoryImpl.creat eBooleanFromString(XMLTypeFactoryImpl.java:1958)
>>>> at
>>>> org.eclipse.emf.ecore.xml.type.impl.XMLTypeFactoryImpl.creat eFromString(XMLTypeFactoryImpl.java:1602)
>>>> at
>>>> org.eclipse.emf.ecore.impl.EStructuralFeatureImpl.getDefault Value(EStructuralFeatureImpl.java:134)
>>>> at
>>>> org.eclipse.emf.ecore.impl.EAttributeImpl.eIsSet(EAttributeI mpl.java:434)
>>>> at
>>>> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObj ectImpl.java:1225)
>>>> at
>>>> org.eclipse.emf.ecore.util.EObjectValidator.validate_DataVal ueConforms(EObjectValidator.java:432)
>>>> at
>>>> org.eclipse.emf.ecore.util.EObjectValidator.validate_EveryDa taValueConforms(EObjectValidator.java:420)
>>>> at
>>>> org.eclipse.emf.ecore.util.EcoreValidator.validateEAttribute (EcoreValidator.java:481)
>>>> at
>>>> org.eclipse.emf.ecore.util.EcoreValidator.validate(EcoreVali dator.java:365)
>>>> at
>>>> org.eclipse.emf.ecore.util.EObjectValidator.validate(EObject Validator.java:170)
>>>> at
>>>> org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:127)
>>>> at
>>>> org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:107)
>>>> at
>>>> org.eclipse.emf.ecore.util.Diagnostician.doValidateContents( Diagnostician.java:146)
>>>> at
>>>> org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:130)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:87)
>>>> at
>>>> org.eclipse.emf.codegen.ecore.genmodel.impl.GenModelImpl.dia gnose(GenModelImpl.java:2514)
>>>> at
>>>> org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel Editor.validate(GenModelEditor.java:1838)
>>>> at
>>>> org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel Editor.initialize(GenModelEditor.java:636)
>>>> at
>>>> org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel Editor.createPages(GenModelEditor.java:1147)
>>>> at
>>>> org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:278)
>>>> at
>>>> org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:662)
>>>> at
>>>> org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:421)
>>>> at
>>>> org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:586)
>>>> at
>>>> org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:257)
>>>> at
>>>> org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2598)
>>>> at
>>>> org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2524)
>>>> at
>>>> org.eclipse.ui.internal.WorkbenchPage.access$12(WorkbenchPag e.java:2516)
>>>> at
>>>> org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2501)
>>>> at
>>>> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
>>>> at
>>>> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2496)
>>>> at
>>>> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2480)
>>>> at
>>>> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2471)
>>>> at org.eclipse.ui.ide.IDE.openEditor(IDE.java:638)
>>>> at org.eclipse.ui.ide.IDE.openEditor(IDE.java:597)
>>>> at
>>>> org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:285)
>>>> at
>>>> org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:138)
>>>> at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:19 5)
>>>> at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:17 6)
>>>> at
>>>> org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:268)
>>>> at
>>>> org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:244)
>>>> at
>>>> org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:318)
>>>> at
>>>> org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 5.open(PackageExplorerPart.java:584)
>>>> at
>>>> org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:819)
>>>> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
>>>> at org.eclipse.core.runtime.Platform.run(Platform.java:850)
>>>> at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:52)
>>>> at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:15 3)
>>>> at
>>>> org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:817)
>>>> at
>>>> org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1078)
>>>> at
>>>> org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1177)
>>>> at
>>>> org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
>>>> at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:257)
>>>> at
>>>> org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:297)
>>>> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
>>>> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
>>>> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3490)
>>>> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3104)
>>>> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2264)
>>>> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2228)
>>>> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 03)
>>>> at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:457)
>>>> at
>>>> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
>>>> at
>>>> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:452)
>>>> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
>>>> at
>>>> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:101)
>>>> at
>>>> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:146)
>>>> at
>>>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
>>>> at
>>>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
>>>> at
>>>> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:354)
>>>> at
>>>> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:169)
>>>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>>> at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
>>>> at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
>>>> at java.lang.reflect.Method.invoke(Unknown Source)
>>>> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 476)
>>>> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:416)
>>>> at org.eclipse.equinox.launcher.Main.run(Main.java:1124)
>>>> at org.eclipse.equinox.launcher.Main.main(Main.java:1099)
>> Ed,
>> When I run the validation I get several errors.
>> 1) "The instance type name '' is not well formed"
>> I get this for 3 enumerated types - this seems strange in that I
>> don't see why I should have to set the Instance Name Type for an
>> enumerated type and when I do a restore to default value it has no
>> effect.
>> 2) There may not two operations 'added(Container) and
>> 'Added(Schematic)' with the same signature.
>> I don't understand this one in that Container and Schematic are
>> clearly different types, so the signature is different!
>> let me know if you want a copy of my .ecore and .genmodel
Ed,
I submitted the 2 bugs. Did you make any progress on the original
problem with the .genmodel? Is it related to the instance type name
problem?
Re: .genmodel that opened in 3.3M4 fails to open in 3.3M5 [message #408396 is a reply to message #408389] |
Tue, 10 April 2007 16:47 |
Ed Merks Messages: 33142 Registered: July 2009 |
John,
I've committed fixes for the two bugs you've opened and I've finally
been able to reproduce the other problem finally! Please open a
bugzilla for that problem as well. I already have a fix to avoid the
problem, but I need to think about adding a better constraint for the
default value literal conforming to the type of the feature (which is
tricky in general at development time since the specialized code for the
data type's createFromString/convertToString won't exist at development
time, so maybe it's not possible since a failure to convert to a value
might just reflect an inability to do that at development time rather
than a wrong value).
John Yotka wrote:
> Ed Merks wrote:
>> John,
>> type name. Please open a bugzilla and I'll change the code so that
>> it's not possible via the GUI to set the instance type name to the
>> empty string (which happens accidentally just from activating the
>> cell editor). Use the property view's toolbar's "Restore Default
>> Value" button to set it back to null.
>> open a bugzilla for that too and well have a fix for it by Thursday's
>> build. I'm looking into the cause now...
>> John Yotka wrote:
>>> Ed Merks wrote:
>>>> John,
>>>> the popup menu on the package. It sounds like there's an attribute
>>>> of type "boolean" that has an empty string as its default value.
>>>> I'll try to reproduce this problem tomorrow since such an program
>>>> should just result in a validation diagnostic, not a failure to
>>>> load the .genmodel...
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>> Ed,
>>> effect.
> Ed,
> problem?
Ed Merks
FUDForum. Page generated in 0.03387 seconds
