Home » Modeling » M2T (model-to-text transformation) » Any JET2 sample with Java object input ?
Any JET2 sample with Java object input ? [message #41381] |
Wed, 06 February 2008 13:56 |
Originally posted by: aah.yahoo.com
I am looking for a JET2 sample, where the input is a live Java object --
which was described in JET1 tutorials published. I see that most of the
JET2 samples talk about a sample xml input and the template operates on
it using XPath.
Can someone please share some sample where input is a Java object?
Thanks in advance.
-Anand
Re: Any JET2 sample with Java object input ? [message #41544 is a reply to message #41381] |
Thu, 07 February 2008 16:35 |
Paul Elder Messages: 849 Registered: July 2009 |
Anand:
If you are looking to manipulate Java objects directly, here are a few
suggestions.
1) To lauch a JET transformation, use
JET2Platform.runTransformationOnObject(), passing the object you want.
2) With-in a JET2 template, to access that object, use:
context.getSource().
(BTW, you can use Java scriptlets <% ...java statements ...%> and Java
expressions <%= expression %> within the template).
3) To write text from a scriptlet, use the 'out' variable.
If you can tell us a bit more about the context in which you want to use
JET, I can give you more hints.
Paul
"Anand" <aah@yahoo.com> wrote in message
news:foceb8$bg$1@build.eclipse.org...
> JET2 samples talk about a sample xml input and the template operates on it
> using XPath.
> Thanks in advance.
> -Anand
Re: Any JET2 sample with Java object input ? [message #41604 is a reply to message #41544] |
Fri, 08 February 2008 04:00 |
Originally posted by: anand.hatwalne.gmail.com
Paul, thanks for your reply.
I writing out some C++ code, by walking (parts of) the CDT AST.
So the input to my template would be a IASTTranslationUnit or
IASTCompositeTypeSpecifier object.
Using JET1, I figured out that it was as simple as passing the argument
to the template, and then play with that in the template.
I wasn't exactly sure how to achieve the same using JET2.
Here's a snippet from JET1 that I have put together. An analogy/example
with JET2 to achieve the same, would be really nice.
<%@jet package="com.mypackage"
imports="org.eclipse.cdt.core.dom.ast.* java.util.*"
class="MyGenerator"
<% IASTTranslationUnit translationUnit = (IASTTranslationUnit) argument; %>
<%= Do Something here from the TU passed %>
thanks again,
Anand
Paul Elder wrote the following on 2/7/2008 10:05 PM:
> Anand:
> suggestions.
> Paul
>> Hi,
>> using XPath.
>> Thanks in advance.
>> -Anand
Re: Any JET2 sample with Java object input ? [message #41758 is a reply to message #41604] |
Wed, 13 February 2008 15:44 |
Anand:
Apart form context.getSource(), you can also set JET2 context variables:
context.setVariable("someName", someValue);
You can then get these inside your templates:
context.getVariable("someName");
Paul
"Anand Hatwalne" <anand.hatwalne@gmail.com> wrote in message
news:fogk59$apb$1@build.eclipse.org...
> Using JET1, I figured out that it was as simple as passing the argument to
> class="MyGenerator"
> thanks again,
> Anand
>> Anand:
>> suggestions.
>> Thanks,
>> Paul
>>> Hi,
>>> it using XPath.
>>> Thanks in advance.
>>> -Anand
Current Time: Sat Apr 27 02:56:30 GMT 2024
Powered by FUDForum. Page generated in 0.04024 seconds
