Home » Eclipse Projects » Standard Widget Toolkit (SWT) » mouse interaction for Sing / SWT bridge
mouse interaction for Sing / SWT bridge [message #407064] Thu, 08 January 2004 19:58 Go to next message
Originally posted by: moopa06.ca.com
eclipse3m5.
I cannot get any swing things to respond to mouse events. For example a
JButton just sits there. A Button (awt) works fine - so I must be doing
almost the right thing.
Any ideas?
Re: mouse interaction for Sing / SWT bridge [message #407995 is a reply to message #407064] Fri, 09 January 2004 10:44 Go to previous messageGo to next message
Which platform? Can you get this snippet to work?
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-swt-home/snippits/snippet135.html
"paul moore" <moopa06@ca.com> wrote in message
news:btkuc4$2kl$1@eclipse.org...
> eclipse3m5.
> Any ideas?
Re: mouse interaction for Sing / SWT bridge [message #407999 is a reply to message #407995] Fri, 09 January 2004 12:29 Go to previous messageGo to next message
the snippet works (as free standing app).
My simplest test is this (in a ViewPart)
Frame m_frame;
public void createPartControl(Composite parent)
m_frame = SWT_AWT.new_Frame(parent);
m_frame.setLayout(new BorderLayout());
m_frame.add(new JButton("hello"), BorderLayout.NORTH);
m_frame.add(new Button("hello 2"), BorderLayout.SOUTH);
m_frame.add(new JTree(), BorderLayout.CENTER);
the button works fine but the jbutton and the jtree (popluated with
default nodes = colors, sports,...)just sit there
Re: mouse interaction for Sing / SWT bridge [message #408000 is a reply to message #407999] Fri, 09 January 2004 12:30 Go to previous messageGo to next message
windows xp
Re: mouse interaction for Sing / SWT bridge [message #408002 is a reply to message #407999] Fri, 09 January 2004 12:43 Go to previous messageGo to next message
Just to be clear. I am running my code as an eclipse 3.0 m5 RCP plugin.
With free standing app I have no problems.
Re: mouse interaction for Sing / SWT bridge [message #408775 is a reply to message #407999] Wed, 14 January 2004 13:10 Go to previous messageGo to next message
Sorry Paul, I can't look at this now. Can you enter a bugzilla report with
the fragment? Thanks.
news:btmoeb$3rq$1@eclipse.org...
> Frame m_frame;
Re: mouse interaction for Sing / SWT bridge [message #410910 is a reply to message #407064] Sat, 17 January 2004 08:44 Go to previous message
Originally posted by: jmickelonis.earthlink.net
paul moore wrote:
> eclipse3m5.
> Any ideas?
Yeah. You're adding directly onto the awt frame... try creating an awt
panel, adding to that, then adding the panel to the frame, like in the
example. The components will then respond to all mouse events.
Previous Topic:Printing and printing dialogs
Next Topic:populting swt tables scalability
Current Time: Thu Nov 06 12:54:53 EST 2025
Powered by FUDForum. Page generated in 0.04151 seconds
