Home » Modeling » EMF » Password property
Password property [message #406875] |
Tue, 06 February 2007 19:31 |
Originally posted by: marcus.tangermann.web.de
more than one year ago there was a question about password-like feature.
Meanwhile, is it possible to show a password as '*****' in properties view?
Best regards
Marcus
Re: Password property [message #406916 is a reply to message #406915] |
Wed, 07 February 2007 19:39 |
Miles Parker Messages: 1341 Registered: July 2009 |
...not to mention encrypting it so someone can't just grab it from the
backing store. :) :)
On 2007-02-07 12:59:58 -0500, Steve Blass <sblass@acm.org> said:
> ...and once you change getPropertyValue you'll probably want to provide
> a method for retrieving the actual value when you need the real
> password rather than ****'s ;)
> Ed Merks wrote:
>> Marcus,
>> Yes, you'll have to fiddle with ItemPropertyDescriptor.getProperyValue.
>> Marcus Tangermann wrote:
>>> Ed,
>>> thanks for you advice. I've got the cell editor working (shows ***
>>> instead of text when editing).
>>> Now I have to check how to display '****' when cell editor is not
>>> active. I guess this will somehow work using getEditableValue of
>>> PropertySource.
>>> Marcus
>>> Ed Merks schrieb:
>>>> Marcus,
>>>> No, we've never provided such a feature. I assume you'd want to show
>>>> "*" even as the user typed their password. If that's the case, you'd
>>>> need to create a specialized cell editor; there are quite a few answers
>>>> to the question of how to do that:
>>>> http://www.eclipse.org/search/search.cgi?q=custom+cell+edito r&cmd=Search%21&form=extended&wf=574a74&ps=1 0&m=all&t=5&ul=%2Fnewslists%2Fnews.eclipse.tools .emf&wm=wrd&t=News&t=Mail
>>>> < http://www.eclipse.org/search/search.cgi?q=custom+cell+edito r&cmd=Search%21&form=extended&wf=574a74&ps=1 0&m=all&t=5&ul=%2Fnewslists%2Fnews.eclipse.tools .emf&wm=wrd&t=News&t=Mail>
Marcus
>>>> Tangermann wrote:
>>>>> Hi,
>>>>> Best regards
>>>>> Marcus
Re: Password property [message #406917 is a reply to message #406916] |
Wed, 07 February 2007 19:44 |
Ed Merks Messages: 33142 Registered: July 2009 |
Miles,
I wondered about that too. :-)
Resource supports the load and save option, OPTION_CIPHER. With 2.2.x,
you can use CryptoCipherImpl or in 2.3.0 you can use AESCipherImpl or
DESCipherImpl. This encrypts the entire resource though...
>> provide a method for retrieving the actual value when you need the
>> real password rather than ****'s ;)
>> Ed Merks wrote:
>>> Marcus,
>>>> Ed,
>>>> PropertySource.
>>>> Marcus
>>>> Ed Merks schrieb:
>>>>> Marcus,
>>>>> show "*" even as the user typed their password. If that's the
>>>>> case, you'd need to create a specialized cell editor; there are
>>>>> quite a few answers to the question of how to do that:
> Marcus
>>>>> Tangermann wrote:
>>>>>> Hi,
>>>>>> feature.
>>>>>> properties view?
>>>>>> Best regards
>>>>>> Marcus
Ed Merks
Re: Password property [message #406937 is a reply to message #406915] |
Fri, 09 February 2007 07:49 |
finally...it works :-)
This is propably an ugly implementation...but hey, it works ;-)
So, for all of you who face the same problem:
1. Extend AdapterFactoryContentProvider and implement
createPropertySource
2. Extend PropertySource and implement createPropertyDescriptor
3. Extend PropertyDescriptor and implement createPropertyEditor
4. If the second parameter of the constructor is a derived property
descriptor (PasswordItemPropertyDescriptor), save the reference to
the descriptor a variable
5. In createPropertyEditor create new instance of TextCellEditor and set
style to SWT.PASSWORD
6. Extend ItemPropertyDescriptor and override createPropertyValueWrapper
Name it e.g. PasswordItemPropertyDescriptor
7. Extend PropertyValueWrapper and name it e.g. PasswordValueWrapper
8. In the createPropertyValueWrapper method save the "real" value in a
variable (second parameter of the method)
9. Overwrite the doSetValue method of the TextCellEditor created above.
Call super.doSetValue with the real value from the
10. Finally change the createItemPropertyDescriptor in the model edit
code to instantiate the PasswordItemPropertyDescriptor
Steve Blass schrieb:
> ...and once you change getPropertyValue you'll probably want to >provide
>password
Re: Password property [message #406943 is a reply to message #406938] |
Fri, 09 February 2007 14:53 |
Couldn't one provide a derived method that provides and sets the plain
text version of the password, persisting that to the actual encrypted
EReference string? You might want to make sure that notifications etc..
are disabled so that people can't register for notifications at
runtime. Not to mention providing new adapters and what not. Or perhaps
you could actually use a SetCommand to manage this.. Still a relativly
niave solution, but..
On 2007-02-09 06:32:32 -0500, Ed Merks <merks@ca.ibm.com> said:
> Marcus,
> Thanks for publishing your results! Perhaps we should consider
> providing support for something like this using a setting on the
> GenFeature (perhaps as new Property Type choice). If someone wants to
> open a feature request for that, feel free.
> I wonder how you are storing this password in a way that keeps it
> secure? I'm not even sure if it's possible or sensible to define an
> EDataType that does encryption and decryption automatically; of course
> it wouldn't be very useful for the cell editor to be editing the
> encrypted value, so such a data type would need special handling in the
> cell editor, but then it already does...
>> Hi,
>> > a method for retrieving the actual value when you need the real >password
Re: Password property [message #406946 is a reply to message #406943] |
Fri, 09 February 2007 15:53 |
Miles,
One approach I've heard people use is to set an encrypted version of the
password to the model and to decrypt it when it's fetched. So within
the model itself, you can never just see the plain value...
> etc.. are disabled so that people can't register for notifications at
> perhaps you could actually use a SetCommand to manage this.. Still a
> relativly niave solution, but..
>> Marcus,
>> to open a feature request for that, feel free.
>> course it wouldn't be very useful for the cell editor to be editing
>> the encrypted value, so such a data type would need special handling
>> in the cell editor, but then it already does...
>>> Hi,
>>> set
>>> >provide
>>> >password
Ed Merks
Current Time: Sat Apr 27 04:15:37 GMT 2024
Powered by FUDForum. Page generated in 0.07822 seconds
