Unsupported or unrecognized format [message #405836] |
Tue, 06 January 2004 08:30 |
Originally posted by: angeles_sorano.yahoo.com.ar
I've finished my own plugin (two plugins: core and ui).
Plugin has and especific editor, two views, and outline view....
And now i'm testing it and I have the following .log error:
!SESSION Jan 06, 2004 10:02:59.680
java.version=1.4.0_01
Command-line arguments: -pdelaunch -dev bin -feature org.eclipse.platform
-data C:\eclipse\runtime-workspace -os win32 -ws win32 -arch x86 -nl en_US
-configuration
file:C:/eclipse/workspace/.metadata/.plugins/org.eclipse.pde .core/C__eclipse_runtime-workspace/platform.cfg
-install file:C:/eclipse/
!ENTRY org.eclipse.ui 4 4 Jan 06, 2004 10:02:59.700
!MESSAGE Unhandled exception caught in event loop.
!ENTRY org.eclipse.ui 4 0 Jan 06, 2004 10:02:59.730
!MESSAGE Unsupported or unrecognized format
!STACK 0
org.eclipse.swt.SWTException: Unsupported or unrecognized format
at org.eclipse.swt.SWT.error(SWT.java:2332)
at org.eclipse.swt.SWT.error(SWT.java:2262)
at org.eclipse.swt.internal.image.FileFormat.load(FileFormat.ja va:73)
at org.eclipse.swt.graphics.ImageLoader.load(ImageLoader.java:1 24)
at org.eclipse.swt.graphics.ImageData.<init>(ImageData.java:311)
org.eclipse.jface.resource.URLImageDescriptor.getImageData(U RLImageDescriptor.java:51)
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:118)
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:94)
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:83)
org.eclipse.jface.action.ActionContributionItem$ImageCache.g etImage(ActionContributionItem.java:117)
org.eclipse.jface.action.ActionContributionItem.updateImages (ActionContributionItem.java:721)
org.eclipse.jface.action.ActionContributionItem.update(Actio nContributionItem.java:596)
org.eclipse.jface.action.ActionContributionItem.fill(ActionC ontributionItem.java:302)
at org.eclipse.jface.action.MenuManager.update(MenuManager.java :555)
at org.eclipse.jface.action.MenuManager.update(MenuManager.java :456)
at org.eclipse.jface.action.MenuManager.fill(MenuManager.java:2 09)
org.eclipse.jface.action.MenuManager.handleAboutToShow(MenuM anager.java:337)
at org.eclipse.jface.action.MenuManager.access$0(MenuManager.ja va:333)
at org.eclipse.jface.action.MenuManager$2.menuShown(MenuManager .java:345)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:116)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :81)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:840)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:865)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:845)
at org.eclipse.swt.widgets.Control.WM_INITMENUPOPUP(Control.jav a:3147)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:2791 )
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1229)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:2361 )
at org.eclipse.swt.internal.win32.OS.TrackPopupMenu(Native Method)
at org.eclipse.swt.widgets.Menu._setVisible(Menu.java:218)
at org.eclipse.swt.widgets.Display.runPopups(Display.java:1863)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1538)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1402)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
If you need something else to check out, please ask me for it.
Angeles Sorano
mailto: soranom@ar.ibm.com
FUDForum. Page generated in 0.02557 seconds
