Home » Modeling » EMF » How to extract the XML data from the FeatureMap that represents the XML any type
How to extract the XML data from the FeatureMap that represents the XML any type [message #405292] Sun, 12 November 2006 17:39 Go to next message
Originally posted by: darkker.gmail.com
Is there a way to extract the XML data from the FeatureMap that represents
the XML any type?
As I see, all XML data from the any element is parsed into a number of
EFeatureMaps and enclosing EFeatures which represent the XML structure.
But what to do, if it is required to extract plain XML data?
I'm speaking about something like this:
EAttribute attribute = object.eClass().getEStructuralFeature("any");
FeatureMap map = (FeatureMap)object.eGet(attribute);
String xmlString = SomeMagicClass.getXMLData(map);
System.out.println("Read:" + xmlString);
// Read: <A x="123"><b> </b></A>
Is there any ideas?
Thanks in advance,
Vlad
Re: How to extract the XML data from the FeatureMap that represents the XML any type [message #405295 is a reply to message #405292] Mon, 13 November 2006 07:46 Go to previous messageGo to next message
--------------090405040800060908020102
Vlad,
You'll find this article useful and then you'll likely have more
specific questions:
Binding XML to Java
< http://www.theserverside.com/tt/articles/article.tss?l=Bindi ngXMLJava>
Vladimir P wrote:
> represents the XML any type?
> Is there any ideas?
> Thanks in advance,
> Vlad
<html>
<head>
http-equiv="Content-Type">
</head>
Vlad,<br>
<br>
specific questions:<br>
<blockquote><a target="_out"
href=" http://www.theserverside.com/tt/articles/article.tss?l=Bindi ngXMLJava">Binding
XML to Java</a><br>
</blockquote>
<br>
Vladimir P wrote:
<blockquote cite="midc72f59e88204587cf1d7cf8fc6330e2d$1@www.eclipse.org"
type="cite">Hi,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
// Read: &lt;A x="123"&gt;&lt;b&gt; &lt;/b&gt;&lt;/A&gt;
<br>
<br>
<br>
Is there any ideas?
<br>
<br>
Thanks in advance,
<br>
<br>
Vlad
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------090405040800060908020102--
Re: How to extract the XML data from the FeatureMap that represents the XML any [message #405299 is a reply to message #405295] Tue, 14 November 2006 04:49 Go to previous messageGo to next message
Originally posted by: pyanov.mera.ru
Hi Ed,
Thanks for the usefull article, it clarifies a lot the usage of AnyTypes
in the EMF.
To be more specific:
I'm a writing a GUI application (sort of data-driven) that is intended for
editing a complex data structure, described by the EMF model. The model is
generated from the XML schema and loaded dynamicaly at application
start-up. Some parts of the model can store some arbitrary XML data. This
parts are described as anyType.
The problem is that the same piece of XML data should be represented in
two forms:
1. In the model it is described by a mixture of of EMF classes FeatureMap
and EStructuralFeature.
2. On the screen it is represented as a string, which user can edit,
copy/paste etc.
I'm looking for a simple way to convert EMF anyType FeatureMap <-> XML
string representation.
The only way I see now is to implement EMF serialization/deserialization
of the XML data on the fly.
But it seems to me a tricky and slow solution.
Do you know any other solution? Maybe there is some helper XYZUtil class
that simplifies this?
Thanks in advance,
Vlad
Re: How to extract the XML data from the FeatureMap that represents the XML any [message #405301 is a reply to message #405299] Tue, 14 November 2006 06:36 Go to previous messageGo to next message
--------------070102000809030902000009
Vlad,
Ultimately walking the structure to produce a string will be necessary
and right now such code is tied to the save mechanism of the resource
implementation. XMLHelperImpl.saveString might do the trick, but
getting the root element name to be correct will be tricky, since that's
typically controlled by a containing document root. One brute force
approach would be to serialize to DOM using this XMLResource method
Document save(Document document, Map<?, ?> options, DOMHandler handler);
and use the mapping from EObjects to that DOM as a way of extracting the
branch of the DOM you need, but you'd have to save the whole tree and do
it again each time there is a change...
Vladimir P wrote:
> Hi Ed,
> AnyTypes in the EMF.
> for editing a complex data structure, described by the EMF model. The
> model is generated from the XML schema and loaded dynamicaly at
> application start-up. Some parts of the model can store some arbitrary
> XML data. This parts are described as anyType.
> in two forms:
> FeatureMap and EStructuralFeature.
> copy/paste etc.
> serialization/deserialization of the XML data on the fly.
> class that simplifies this?
> Thanks in advance,
> Vlad
<html>
<head>
</head>
Vlad,<br>
<br>
implementation.
Re: How to extract the XML data from the FeatureMap that represents the XML any [message #405318 is a reply to message #405301] Wed, 15 November 2006 03:35 Go to previous message
Ed,
I have solved the problem by serializing the container object that holds
the any data to XML and then cutting the first and the last lines to
remove tags <container_object_name> and </container_object_name>. Before
deserialization I put these tags back. This approach works fine, even it
looks tricky :)).
One more thing to mention: I have noticed that the XML
formatting(indentation, whitespace characters, etc) is preserved in any
data during serialization /deserialization . Thats a really good feature
of EMF!
Vlad
Previous Topic:Purely reflective EMF editor
Next Topic:NsUri as reference
Current Time: Thu Nov 06 10:58:45 EST 2025
Powered by FUDForum. Page generated in 0.03650 seconds
