Re: JDBC problem [message #43129 is a reply to message #42518] |
Wed, 21 May 2003 18:16 |
Originally posted by: stelian.iancu.gmx.net
Sridhar wrote:
> Many Thanks for your response.
> I checked the \"java.library.path\" variable and it does include
> $ORACLE_HOME/lib. However I noticed that the sequence of entries is not
> the same as those in the environment of the shell that launched the
> Eclipse IDE. In otherwords, Eclipse seems to be constructing its own
> LD_LIBRARY_PATH (based on the environment variable). I tried to set
> -Djava.library.path to my LD_LIBRARY_PATH but that did not help. I am
> wondering if there is any way we can specify the environment parameters in
> a config file.
Try instead -Djava.library.path=$ORACLE_HOME/lib and see if it works.
Stelian Iancu
Linux registered user 287835
Be different. Think.
Re: JDBC problem [message #43750 is a reply to message #42518] |
Thu, 22 May 2003 14:56 |
Haris Peco Messages: 1072 Registered: July 2009 |
You set LD_LIBRARY_PATH in .profile (or .bash_profile) like oracle user
btw.
export LD_LIBRARY_PATH=$OARCLE_HOME/lib
Call eclipse after this
You can thin driver,too - then You needn't oracle lib
regards
Harsi Peco
Sridhar wrote:
> a config file.
> Thanks
> Sridhar
> snpe wrote:
>> Hi,
>> You haven\'t $ORACLE_HOME/lib in LD_LIBRARY_PATH or /etc/ld.so.conf,
>> probably I think that this work like oracle user on command line and then
>> installer set LD_LIBRARY_PATH for you
>> regards
>> Haris Peco
>> Sridhar wrote:
>> > I have a simple java program that gets a JDBC Connection. If I run this
>> > program on a command line it runs fine. However if it is run from the
>> > Eclipse debugger, I get runtime exception. I am wondering how to fix
>> > this problem.
>> > Thanks in advance.
>> > Sridhar
>> > Here is the code fragment I am using:
>> > try {
>> > String sDriver = \"oracle.jdbc.driver.OracleDriver\";
>> > String sURL = \"jdbc:oracle:oci8:@myDb\";
>> > String sUsername = \"myacct\";
>> > String sPassword = \"myPwd\";
>> > Class.forName( sDriver ).newInstance();
>> > Connection conn = DriverManager.getConnection ( sURL,
>> > sUsername,
>> > sPassword);
>> > catch(Exception ex) {ex.printStackTrace();}
>> > Here is the exception I am getting:
>> > ld.so.1: oracleleap: fatal: libskgxp8.so: open failed: No such file or
>> > directory
>> > java.sql.SQLException: ORA-12547: TNS:lost contact
>> > at oracle.jdbc.dbaccess.DBError.throwSqlException(DBError.java: 168)
>> > at oracle.jdbc.oci8.OCIDBAccess.check_error(OCIDBAccess.java:15 97)
>> > at oracle.jdbc.oci8.OCIDBAccess.logon(OCIDBAccess.java:354)
>> > at
>> > oracle.jdbc.driver.OracleConnection.<init>(OracleConnection.java:246)
>> > at
oracle.jdbc.driver.OracleDriver.getConnectionInstance(Oracle Driver.java:365)
>> > at oracle.jdbc.driver.OracleDriver.connect(OracleDriver.java:26 0)
>> > at java.sql.DriverManager.getConnection(DriverManager.java:517)
>> > at java.sql.DriverManager.getConnection(DriverManager.java:177)
Re: JDBC problem [message #46431 is a reply to message #43750] |
Fri, 23 May 2003 17:26 |
Sridhar Messages: 12 Registered: July 2009 |
Many Thanks for the suggestions.
I tried all the possible combinations. Looks like there is a fundamental
problem with eclipse being able to locate and load a library from the
LD_LIBRARY_PATH.
One of our friends was able to use an Oracle driver and it seems to be
fine.
I observed an interesting behavior, when I used
-Djava.library.path=$ORACLE_HOME/lib:$MY_LD_LIBRARY_PATH, it was able to
load oracle library, however it was complaining about another library file
not (one of our shared libs located) found (same error message as before
but complaining about a different library). Without Oracle stuff eclipse
loads our library fine.
Sridhar
snpe wrote:
> btw.
> regards
> Harsi Peco
> Sridhar wrote:
> > Hi,
> > a config file.
> > Thanks
> > Sridhar
> > snpe wrote:
> >> Hi,
> >> regards
> >> Haris Peco
> >> > this problem.
> >> > Thanks in advance.
> >> > Sridhar
> >> > try {
> >> > sUsername,
> >> > sPassword);
> >> > directory
> >> > at
> >> > at
Re: JDBC problem [message #46623 is a reply to message #46431] |
Fri, 23 May 2003 21:19 |
Hi Sridhar,
Oracle lib isn't java lib.You must LD_LIBRARY_PATH out of eclipse (before
run eclipse) with :
export LD_LIBRARY_PATH=$ORACLE_HOME/lib
run eclipse
or in .bash_profile
It is better that edit /etc/ld.so.conf (must be root) and add line :
/usr/oracle/lib
change /usr/oracle with ORACLE_HOME and call
ldconfig
then start eclipse
You must use thin JDBC driver URL like
jdbc:oracle:thin:user/password@hostname:1521:SID
then , You must set Oracle Net on port 1521 and sid SID
You must add jdbc jar in eclipse, too
regards
Haris Peco
Sridhar wrote:
> LD_LIBRARY_PATH.
> fine.
> Thanks
> Sridhar
> snpe wrote:
>> Hi,
>> btw.
>> regards
>> Harsi Peco
>> Sridhar wrote:
>> > Hi,
>> > in a config file.
>> > Thanks
>> > Sridhar
>> > snpe wrote:
>> >> Hi,
>> >> then installer set LD_LIBRARY_PATH for you
>> >> regards
>> >> Haris Peco
>> >> > this program on a command line it runs fine. However if it is run
>> >> > from the Eclipse debugger, I get runtime exception. I am wondering
>> >> > how to fix this problem.
>> >> > Thanks in advance.
>> >> > Sridhar
>> >> > try {
>> >> > sUsername,
>> >> > sPassword);
>> >> > or directory
>> >> > at
>> >> > at
FUDForum. Page generated in 0.02655 seconds
