| quick q regarding eclipse 1.0 [message #41060] |
Wed, 08 January 2003 12:40  |
Originally posted by: jochs.weirdtable.org
does anyone know if 1.0 will work with a 1.4 level VM? The instructions say
1.3 level not 1.3 or higher...
thanx in adv.
-J
| Re: quick q regarding eclipse 1.0 [message #41343 is a reply to message #41312] |
Thu, 09 January 2003 12:32  |
Originally posted by: daniel_megert.oti.com
Depends on what you mean with "works". You might be able to run it but
you will not be able to code against 1.4 features (e.g. assertions)
inside Eclipse.
Dani
Jared Burns wrote:
>Short answer - I don't know.
>1.4 didn't exist when Eclipse 1.0 shipped, so it was never tested. However,
>if the VM is backwards compatible with 1.3 classes (as it's supposed to
>be), it should just work.
>- Jared
>>say 1.3 level not 1.3 or higher...
| Re: quick q regarding eclipse 1.0 [message #588534 is a reply to message #41060] |
Thu, 09 January 2003 11:12  |
- Jared
| Re: quick q regarding eclipse 1.0 [message #588543 is a reply to message #41312] |
inside Eclipse.
Dani
>- Jared
FUDForum. Page generated in 0.03117 seconds
