Home » Archived » OHF » Mesa Test 1221
Mesa Test 1221 [message #41053] |
Mon, 25 February 2008 12:21  |
Originally posted by: charlie.babitt.gmx.at
Hallo! I'm trying to get Mesa test 1221 running and I get the following
errors:
The mesa SERVER:
SSL_accept: :before/accept initialization
SSL_accept: :error in SSLv3 read client hello B
ERROR19113:error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version
number:s3_pkt.c:290
What confuses me is the logoutput of the consumer: http-8080-1, WRITE:
SSLv2 client hello message, length = 98.
Is there a way to force it to use SSLv3? Or is this the problem that the
mesa server is expecting SSLv3 and the Consumer is sending SSLv2?
From the logs of the consumer:
trustStore type is : jks
trustStore provider is :
init truststore
adding as trusted cert:
Subject: EMAILADDRESS=certificates@acme.com, CN=ACME Certificate
Factory, OU=Research Division, O=ACME Integrated Systems, L=Champaign,
ST=Illinois, C=US
Issuer: EMAILADDRESS=certificates@acme.com, CN=ACME Certificate
ST=Illinois, C=US
Algorithm: RSA; Serial number: 0x0
Valid from Fri Sep 07 05:25:17 CEST 2007 until Sun Nov 30 04:25:17 CET
2008
Subject: EMAILADDRESS=mesa@wuerl.wustl.edu, CN=MESA Certificate Factory,
OU=MIR, O=Washington University, L=St. Louis, ST=Missouri, C=US
Issuer: EMAILADDRESS=mesa@wuerl.wustl.edu, CN=MESA Certificate Factory,
2008
Valid from Mon Oct 17 20:20:53 CEST 2005 until Sun Aug 13 20:20:53 CEST
2006
2008
OU=MIR Production, O=Washington University, L=St. Louis, ST=Missouri, C=US
Valid from Fri Sep 07 05:25:18 CEST 2007 until Sun Nov 30 04:25:18 CET
2008
2008
trigger seeding of SecureRandom
done seeding SecureRandom
http-8080-1, setSoTimeout(30000) called
%% No cached client session
*** ClientHello, TLSv1
RandomCookie: GMT: 1187115210 bytes = { 86, 131, 41, 241, 183, 104, 70,
238, 177, 244, 207, 83, 68, 151, 27, 80, 235, 219, 27, 110, 39, 16, 115,
97, 173, 177, 134, 66 }
Session ID: {}
Cipher Suites: [SSL_RSA_WITH_RC4_128_MD5, SSL_RSA_WITH_RC4_128_SHA,
TLS_RSA_WITH_AES_128_CBC_SHA, TLS_DHE_RSA_WITH_AES_128_CBC_SHA,
TLS_DHE_DSS_WITH_AES_128_CBC_SHA, SSL_RSA_WITH_3DES_EDE_CBC_SHA,
SSL_DHE_RSA_WITH_3DES_EDE_CBC_SHA, SSL_DHE_DSS_WITH_3DES_EDE_CBC_SHA,
SSL_RSA_WITH_DES_CBC_SHA, SSL_DHE_RSA_WITH_DES_CBC_SHA,
SSL_DHE_DSS_WITH_DES_CBC_SHA, SSL_RSA_EXPORT_WITH_RC4_40_MD5,
SSL_RSA_EXPORT_WITH_DES40_CBC_SHA, SSL_DHE_RSA_EXPORT_WITH_DES40_CBC_SHA,
SSL_DHE_DSS_EXPORT_WITH_DES40_CBC_SHA]
Compression Methods: { 0 }
[write] MD5 and SHA1 hashes: len = 73
0000: 01 00 00 45 03 01 47 C2 F1 CA 56 83 29 F1 B7 68 ...E..G...V.)..h
0010: 46 EE B1 F4 CF 53 44 97 1B 50 EB DB 1B 6E 27 10 F....SD..P...n'.
0020: 73 61 AD B1 86 42 00 00 1E 00 04 00 05 00 2F 00 sa...B......../.
0030: 33 00 32 00 0A 00 16 00 13 00 09 00 15 00 12 00 3.2.............
0040: 03 00 08 00 14 00 11 01 00 .........
http-8080-1, WRITE: TLSv1 Handshake, length = 73
[write] MD5 and SHA1 hashes: len = 98
0000: 01 03 01 00 39 00 00 00 20 00 00 04 01 00 80 00 ....9... .......
0010: 00 05 00 00 2F 00 00 33 00 00 32 00 00 0A 07 00 ..../..3..2.....
0020: C0 00 00 16 00 00 13 00 00 09 06 00 40 00 00 15 ............@...
0030: 00 00 12 00 00 03 02 00 80 00 00 08 00 00 14 00 ................
0040: 00 11 47 C2 F1 CA 56 83 29 F1 B7 68 46 EE B1 F4 ..G...V.)..hF...
0050: CF 53 44 97 1B 50 EB DB 1B 6E 27 10 73 61 AD B1 .SD..P...n'.sa..
0060: 86 42 .B
http-8080-1, WRITE: SSLv2 client hello message, length = 98
http-8080-1, handling exception: java.net.SocketException: Connection reset
http-8080-1, SEND TLSv1 ALERT: fatal, description = unexpected_message
http-8080-1, WRITE: TLSv1 Alert, length = 2
http-8080-1, Exception sending alert: java.net.SocketException: Broken pipe
http-8080-1, called closeSocket()
http-8080-1, called close()
http-8080-1, called closeInternal(true)
Re: Mesa Test 1221 [message #41177 is a reply to message #41053] |
Mon, 03 March 2008 12:33   |
Hi Patrick,
There seems to be another thing going on -
do you have a firewall up?
- Sarah
> errors:
> The mesa SERVER:
> number:s3_pkt.c:290
> init truststore
> ST=Illinois, C=US
> ST=Illinois, C=US
> 2008
> Factory, OU=MIR, O=Washington University, L=St. Louis, ST=Missouri, C=US
> 2008
> 2006
> 2008
> Factory, OU=MIR Production, O=Washington University, L=St. Louis,
> ST=Missouri, C=US
> ST=Missouri, C=US
> 2008
> ST=Missouri, C=US
> ST=Missouri, C=US
> 2008
> Session ID: {}
> 0060: 86 42 .B
Re: Mesa Test 1221 [message #41239 is a reply to message #41177] |
Thu, 06 March 2008 11:55  |
Originally posted by: patrick.mangesius.healthatnet.at
The issue is solved, it was not a firewall problem but the usage of a
wrong cipher for initating the handshake. That caused the mesa test server
to stop communicating with the client...
Thanks for you help
Re: Mesa Test 1221 [message #584799 is a reply to message #41053] |
Hi Patrick,
- Sarah
> errors:
> The mesa SERVER:
> number:s3_pkt.c:290
> init truststore
> ST=Illinois, C=US
> ST=Illinois, C=US
> 2008
> 2008
> 2006
> 2008
> ST=Missouri, C=US
> ST=Missouri, C=US
> 2008
> ST=Missouri, C=US
> ST=Missouri, C=US
> 2008
> Session ID: {}
> 0060: 86 42 .B
Re: Mesa Test 1221 [message #584831 is a reply to message #41177] |
Thanks for you help
Current Time: Tue Aug 19 13:16:23 EDT 2025
Powered by FUDForum. Page generated in 0.03957 seconds
