Home » Modeling » EMF » EMF to XML Persistence
EMF to XML Persistence [message #403755] Fri, 22 September 2006 03:54 Go to next message
Hi ,
I have a small issue while persisting EMF (XMI) as XML .I have an EMF
model I want that model to be persisted as XML
E.g I have Struts EMF model and it needs to be persisted as
Struts-config.xml
I have a set of Mappings EMF Feature to XML element , but i get errors
while loading the model
Say for e.g my Root Feature StrutsConfigType of EMF is mapped to a XML
element <struts-config> , its saving properly but when i try to load the
same in the editor its searching for the struts-config as feature rather
than my actual StrutsConfigType EClass .
Any pointers and help in this Regard will be highly apperiaciated.Also
some examples on using EXTENDED_META_DATA option and its sub classes
Kamesh
Re: EMF to XML Persistence [message #403761 is a reply to message #403755] Fri, 22 September 2006 07:58 Go to previous messageGo to next message
Kamesh,
Does your model have a DocumentRoot EClass? Is it based on a schema
originally, i.e., did you import the model from a .xsd? If there is a
document root present, the root element of the instance must match one
of the element-based features in the document root; only if there is no
document root will the element name be used to look up an EClass. The
files org.eclipse.emf.ecore.xmi.impl.EMOF*.java show we use this to
serialize .ecore as .emof.
Kamesh Sampath wrote:
> Hi ,
> Struts-config.xml
> the same in the editor its searching for the struts-config as feature
> rather than my actual StrutsConfigType EClass .
> Kamesh
Re: EMF to XML Persistence [message #403765 is a reply to message #403761] Fri, 22 September 2006 09:36 Go to previous messageGo to next message
Ed Merks wrote:
> Kamesh,
>> Hi ,
>> Struts-config.xml
>> Thanks,
>> Kamesh
Ed:
I dont have the document root I just used the DTD and generate the
*.ecore file from scratch matching the DTD . When i save the model its
saving it properly but when i load the same in the Editor it sucks !
I followed the IBM Redbook on EMF and GEF to do the Custom serilization.
Please let me know what are all the things i need to take care when
saving and loding the document.
I want to simulate somthing like the plugin.xml editor for Struts
configuation file editing .
Kamesh
Re: EMF to XML Persistence [message #403766 is a reply to message #403765] Fri, 22 September 2006 10:47 Go to previous messageGo to next message
Kamesh,
One of the things you can do is Generate Test Code and that will produce
an XyzExample.java in the *.tests project. With that you should be able
to reproduce any problems in a minimal environment. If you could zip up
your model project and your *.tests project for that model, modified to
reproduce the problem you are seeing, then I can much more easily answer
your question via such a concrete example. You can send it to my e-mail
directly if you don't wish to make it public in the newsgroup as an
attachment. My e-mail is merks at ca dot ibm dot com.
> Ed Merks wrote:
>> Kamesh,
>> a document root present, the root element of the instance must match
>> one of the element-based features in the document root; only if there
>> is no document root will the element name be used to look up an
>> EClass. The files org.eclipse.emf.ecore.xmi.impl.EMOF*.java show we
>> use this to serialize .ecore as .emof.
>>> Hi ,
>>> EMF model I want that model to be persisted as XML
>>> Struts-config.xml
>>> errors while loading the model
>>> XML element <struts-config> , its saving properly but when i try to
>>> load the same in the editor its searching for the struts-config as
>>> feature rather than my actual StrutsConfigType EClass .
>>> apperiaciated.Also some examples on using EXTENDED_META_DATA option
>>> and its sub classes
>>> Thanks,
>>> Kamesh
> Ed:
> Thanks
> Kamesh
Re: EMF to XML Persistence [message #403767 is a reply to message #403766] Fri, 22 September 2006 10:55 Go to previous message
Ed Merks wrote:
> Kamesh,
>> Ed Merks wrote:
>>> Kamesh,
>>>> Hi ,
>>>> Struts-config.xml
>>>> and its sub classes
>>>> Thanks,
>>>> Kamesh
>> Ed:
>> Thanks
>> Kamesh
Ed:
Thanks for the input . Will try to do the way you told ,if am not
successfull will send it across to your email.
Kamesh
Previous Topic:How to create a Custom EMF Editor
Next Topic:EMF "Plug-in Dependencies" Question
Current Time: Wed May 14 10:08:23 EDT 2025
Powered by FUDForum. Page generated in 0.04089 seconds
