ATL : [message #40961] |
Wed, 23 May 2007 13:19 |
Originally posted by: yassin_chkouri.yahoo.fr
hi,
when i lunch my application with ATL i have the good result and when i
lunch it with command line i have same links not good.
I use command line donne by Denis :
may be the error comes from :
when i lunch the application with alt i use one metamodel(the in and the
out is the same)
and when i use the command lines am obligated to give the in metamodel and
the out metamodel.
some one can help me plaise
thank's in advance
Re: [ATL] : command line problem [message #41271 is a reply to message #41118] |
Thu, 24 May 2007 10:27 |
when I launch the command line , this is messages posted in the console :
--trans file:/home/chkouri/workspace/arl/BipOptimisation/timedToUnti med.asm
--in IN=waterflow2.model
bip=/home/chkouri/workspace/arl/bipMetamodel/bip/bip.ecore EMF
Input metamodel bip @ org.atl.eclipse.engine.AtlEMFModelHandler@99681b not
yet loaded - loading from
Referenced extents: []
Using input metamodel bip : MOF
Loading input model IN from waterflow2.model
Using input model IN : bip
--out OUT=coucou.model
Using output metamodel bip : MOF
Creating new model OUT for output
Starting model transformation
Model transformation done
Wrote coucou.model
the out model"coucou.model" contains same reference not correct.
when i lunch it with ATL is correct
Re: [ATL] : command line problem [message #41541 is a reply to message #41485] |
Thu, 24 May 2007 15:55 |
you are right , when I launch my application in eclipse the box allow
inter-model references is not activate. when i activate the box i had the
same result.
how can i change in the command line interface "allow inter-model
references" to FALSE.
Thanks for your help Dennis
FUDForum. Page generated in 0.03549 seconds
