| How to get namespace attributes using Encore model? [message #403389] |
Wed, 06 September 2006 02:48  |
I use EMF generate an Encore model from some schema files, such like below:
<schema xmlns="http://www.w3.org/2001/XMLSchema" ......>
<element name="module" type="scdl:Module"/>
<element name="component" type="scdl:Component"/>
<complexType name="Module">
<complexContent>
</complexContent>
</complexType>
<complexType name="component">
<complexContent>
</complexContent>
</complexType>
</schema>
There are maybe 2 kinds of xml files which correspond to module element
and component element respectively.
I want to parser a component element loaded from a xml file. But I can't
get the namespace attibutes. I find it could get XMLNSPrefixMap if I get a
DocumentRoot element(From API). How could I get the DocumentRoot element?
Do I need to get the DocumentRoot first if I want to get namespace
attibutes?
It could be parserd as a Component but can't be DocumentRoot when I load
the file like the following way(If I change Component to DocumentRoot ,it
will occur error):
Resource resource = new
XMLResourceImpl(URI.createFileURI("component.xml"));
XMLResource.XMLInfo info = new XMLInfoImpl();
info.setXMLRepresentation(XMLResource.XMLInfo.ELEMENT);
info.setName("component");
XMLResource.XMLMap map = new XMLMapImpl();
map.add(ScaPackage.eINSTANCE.getComponent(), info);
Map options = new HashMap();
options.put(XMLResource.OPTION_XML_MAP, map);
try {
resource.load(options);
} catch (IOException e) {
e.printStackTrace();
Component component = (Component)resource.getContents().get(0);
Thanks for any help!
| Re: How to get namespace attributes using Encore model? [message #403393 is a reply to message #403389] |
Wed, 06 September 2006 09:14  |
Shan,
Use the popup in the Generator to "Generate Test Code" and then have a
look at the XyzExample.java in the generated *.tests project. It shows
how to create a new instance and how to load an existing instance.
> below:
> <complexContent>
> </complexContent>
> </complexType>
> <complexContent>
> </complexContent>
> </complexType>
> </schema>
> element and component element respectively.
> can't get the namespace attibutes. I find it could get XMLNSPrefixMap
> if I get a DocumentRoot element(From API). How could I get the
> attibutes?
> load the file like the following way(If I change Component to
> DocumentRoot ,it will occur error):
> try {
FUDForum. Page generated in 0.03537 seconds
