Home » Modeling » EMF » when try to generate .genmodel from .ecore file, the ecore could not be loaded
when try to generate .genmodel from .ecore file, the ecore could not be loaded [message #403388] Tue, 05 September 2006 23:29 Go to next message
the .ecore file is generated through EclipseUML, but when i try to import
the .ecore file, it always failed.
(The "finish" button always is always disabled.)
any reason for this?
Re: when try to generate .genmodel from .ecore file, the ecore could not be loaded [message #403391 is a reply to message #403388] Wed, 06 September 2006 08:56 Go to previous messageGo to next message
Chen,
Check the error log view. There must be some clues as to what's gone wrong.
> Thanks
Re: when try to generate .genmodel from .ecore file, the ecore could not be loaded [message #403392 is a reply to message #403391] Wed, 06 September 2006 09:10 Go to previous messageGo to next message
I checked..but there is no clue for this...
I actually only build a very simiple Ecore model with only one attibute, but
still...
I have attached my ecore file to this mail..could u help me check what's
wrong with this?
I wanna generate the .genmodel from this ...
Thanks in advance..
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:edmghl$2bv$2@utils.eclipse.org...
> Chen,
> wrong.
>> Thanks
Re: when try to generate .genmodel from .ecore file, the ecore could not be loaded [message #403395 is a reply to message #403392] Wed, 06 September 2006 09:19 Go to previous messageGo to next message
Hi, Ed,
I worked that out.
I direclty modified the .ecore file according to some .ecore file i created
before,
It seems that i need
<ecore:EPackage xmi:version="2.0" and
<eClassifiers xsi:type="ecore:EClass" name="ModelModelUI">
before adding this, i only have some EAttributes..
Thanks very much.
chen
"chen" <wangchen1981@gmail.com> wrote in message
news:edmhbo$7n2$1@utils.eclipse.org...
> but still...
> wrong with this?
> Thanks in advance..
>> Chen,
>> wrong.
>>> import
>>> Thanks
Re: when try to generate .genmodel from .ecore file, the ecore could not be loaded [message #403396 is a reply to message #403392] Wed, 06 September 2006 09:21 Go to previous message
--------------040503030403050900050209
Chen,
The resource doesn't contain an EPackage so it's being treated like an
empty file. An EClass in isolation is not meaningful. It must be
nested in an EPackage.
> still...
> wrong with this?
> Thanks in advance..
>> Chen,
>> wrong.
>>> Thanks
<html>
<head>
</head>
Chen,<br>
<br>
empty file.&nbsp; An EClass in isolation is not meaningful.&nbsp; It must be
nested in an EPackage.<br>
<br>
<br>
chen wrote:
<blockquote cite="midedmhbo$7n2$1@utils.eclipse.org" type="cite">
<pre wrap="">I checked..but there is no clue for this...
still...
wrong with this?
Thanks in advance..
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:edmghl$2bv$2@utils.eclipse.org">news:edmghl$2bv$2@utils.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Chen,
wrong.
chen wrote:
</pre>
<pre wrap="">the .ecore file is generated through EclipseUML, but when i try to import
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------040503030403050900050209--
Previous Topic:How to get namespace attributes using Encore model?
Next Topic:Invoking validate(..) programmatically
Current Time: Wed Nov 05 07:46:56 EST 2025
Powered by FUDForum. Page generated in 0.04489 seconds
