Home » Modeling » EMF » Problem in edit plugin when subclassing from Ecore
Re: Problem in edit plugin when subclassing from Ecore [message #402936 is a reply to message #402934] |
Fri, 11 August 2006 13:46 |
Ed Merks Messages: 33142 Registered: July 2009 |
--------------000502090901040102070001
Victor,
I would expect the generated .edit plugin's plugin class to include a
reference to the EcoreEditPlugin's instance like UML2's edit plugin
class does:
* Create the instance.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated NOT
public UMLEditPlugin() {
super(new ResourceLocator[]{*EcoreEditPlugin.INSTANCE*,
EMFEditPlugin.INSTANCE});
This will result in delegation during property lookup.
Victor Sanchez wrote:
> Hello!
> I know that it is not advisable to subclass Ecore, but once I did this I
> had problems to navigate models in the Sample Ecore Editor, concretely
> with the Properties view. This happens in EMF v2.2.0.
> The Item Provider for an EClass that subclasses directly from an Ecore
> element lists in its generated 'getPropertyDescriptors' method all the
> inherited properties from the Ecore element, together with the ones that
> specifically belong to it. The properties are added sequentially through
> independent methods whose name is 'add<property_nm>PropertyDescriptor'.
> The problem is that those properties that are inherited from an Ecore
> element are referencing string such as '_UI_ENamedElement_type' or
> '_UI_ENamedElement_name_feature', but these are missing from the
> 'plugin.properties' generated file in the Edit plugin, so in the
> Properties View nothing appeared at all when selecting objects of the
> affected types.
> In order for the .genmodel to work I have had to change the textual
> references to Ecore in the .ecore model by hand from
> 'eSuperTypes=" ../../../plugin/org.eclipse.emf.ecore/model/Ecore.ecore#...'
> to 'eSuperTypes="http://www.eclipse.org/emf/2002/Ecore#...', so otherwise
> I wouldn't come up with the abovementioned problem.
> What I was wondering is whether the code generation should be more
> consistent with these circumstances and either:
> 1.- automatically include the missing strings in the
> 'plugin.properties' file or
> 2.- eliminate the conflicting property descriptor additions for the
> '<type>ItemProvider' files, which I suppose is an unacceptable solution.
> Thanks
> Victor
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Victor,<br>
<br>
class does:<br>
<blockquote> /**<br>
* Create the instance.<br>
* <!-- begin-user-doc --><br>
* <!-- end-user-doc --><br>
* @generated NOT<br>
*/<br>
public UMLEditPlugin() {<br>
super(new ResourceLocator[]{<b>EcoreEditPlugin.INSTANCE</b>,<br>
EMFEditPlugin.INSTANCE});<br>
}<br>
</blockquote>
This will result in delegation during property lookup.<br>
<br>
<br>
<blockquote cite="midpan.2006.08.11.12.51.59.4328@opencanarias.com"
type="cite">
<pre wrap="">Hello!
affected types.
to 'eSuperTypes="<a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/2002/Ecore#">http://www.eclipse.org/emf/2002/Ecore#</a>...', so otherwise
Victor
</pre>
</blockquote>
<br>
</body>
</html>
--------------000502090901040102070001--
Ed Merks
Re: Problem in edit plugin when subclassing from Ecore [message #402941 is a reply to message #402937] |
Fri, 11 August 2006 15:02 |
--------------080707010000080003070608
Victor,
I wondered about that too. Perhaps because all models depend on Ecore's
types we filter Ecore out which we shouldn't do if Ecore's classes are
being extended, but then we recommend folks not do that. If you can
provide a small example to illustrate the issue, we can look into fixing
it. Yes, I'm too lazy, I mean busy, to make one. ;-)
> Thank you very much. I finally only included a reference to the
> 'EcoreEditPlugin' instance and now the editor works fine.
> By the way, is there a reason why this reference is not included
> automatically in the generated plugin class?
> Best regards!
> Victor
> On Fri, 11 Aug 2006 09:46:29 -0400, Ed Merks wrote:
>> Victor,
>> class does:
>> * @generated NOT
<html>
<head>
</head>
Victor,<br>
<br>
Ecore's types we filter Ecore out which we shouldn't do if Ecore's
classes are being extended, but then we recommend folks not do that.
If you can provide a small example to illustrate the issue, we can look
into fixing it. Yes, I'm too lazy, I mean busy, to make one. ;-)<br>
<br>
<br>
<blockquote cite="midpan.2006.08.11.14.31.30.268400@opencanarias.com"
type="cite">
<pre wrap="">Thank you very much. I finally only included a reference to the
Best regards!
Victor
</pre>
<blockquote type="cite">
<pre wrap="">Victor,
class does:
* @generated NOT
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------080707010000080003070608--
Ed Merks
Re: Problem in edit plugin when subclassing from Ecore [message #402948 is a reply to message #402941] |
Fri, 11 August 2006 16:22 |
Victor Sanchez Messages: 28 Registered: July 2009 |
Ok, I know what the problem is. I've based the test on a single EClass
contained in an EPackage and ENamedElement as its ESuper Type.
When editing the .genmodel an Ecore EPackage dependency is shown under
the main package, and under these circumstances the generated .edit
plugin's plugin class includes the dependency with the Ecore Edit
plugin as expected:
* @generated
public TempEditPlugin() {
super
(new ResourceLocator [] {
EcoreEditPlugin.INSTANCE,
Now I put my hands directly upon the .ecore file text and change the
reference to the super type ENamedElement from:
to
and a similar change is performed on the .genmodel file for the
'usedGenPackages' property so it now has the following value:
'usedGenPackages="http://www.eclipse.org/emf/2002/GenModel#//ecore">'
Just after this last modification, the genmodel file is no longer
showing the Ecore dependency in the Sample Ecore Editor, and at the same
time, the edit plugin generation is now missing the Ecore Edit plugin
instance in the resource locator of the 'TempEditPlugin' constructor.
Regards!
Victor
On Fri, 11 Aug 2006 11:02:55 -0400, Ed Merks wrote:
> Victor,
>> Best regards!
>> Victor
Re: Problem in edit plugin when subclassing from Ecore [message #402950 is a reply to message #402948] |
Fri, 11 August 2006 16:43 |
--------------010300050005000907000906
Victor,
If you extend the Ecore types, it's important to use the version of
Ecore with an associated GenModel so that you will pick up all the
GenModel settings for the Ecore model (such as the bit flags setting).
I.e., you really should use
if you are extending Ecore and you are likely run into problems if you
don't (as you're seeing already)...
> plugin as expected:
> * @generated
> super
> to
> Regards!
> Victor
>> Victor,
>>> Best regards!
>>> Victor
<html>
<head>
</head>
Victor,<br>
<br>
I.e., you really should use<br>
<blockquote>
<pre wrap="">org.eclipse.emf.ecore/model/Ecore.ecore</pre>
</blockquote>
don't (as you're seeing already)...<br>
<br>
<br>
<blockquote cite="midpan.2006.08.11.16.22.43.874663@opencanarias.com"
type="cite">
<pre wrap="">Ok, I know what the problem is. I've based the test on a single EClass
plugin as expected:
* @generated
super
to
'eSuperTypes=<a class="moz-txt-link-rfc2396E" href="http://www.eclipse.org/emf/2002/Ecore#... 'andasimilarchangeisperformedonthe.genmodelfileforthe'usedGe nPackages'propertysoitnowhasthefollowingvalue:'usedGenPackag es= ">"http://www.eclipse.org/emf/2002/Ecore#...'
'usedGenPackages="</a<a class="moz-txt-link-rfc2396E" href="http://www.eclipse.org/emf/2002/GenModel#//ecore">"http://www.eclipse.org/emf/2002/GenModel#//ecore"</a>>'
Regards!
Victor
</pre>
</pre>
Best regards!
Victor
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------010300050005000907000906--
Ed Merks
Current Time: Fri Apr 26 11:35:22 GMT 2024
Powered by FUDForum. Page generated in 0.03390 seconds
