Mixed Content with elementWildcard and complex subfeatures [message #401941] |
Tue, 20 June 2006 11:51 |
Originally posted by: mail.robertmitschke.com
Hi all,
I have a problem using EMF with mixed Content.
I have a class of Type MType2 which can contain mixed content. Besides
Mixed Content it also has a EReference to another Type (SType2).
From the EMF documentation and information from google, I found out that I
have to use FeatureMaps. So MType2 has a mixed attribute and the feature
mtf2 of Type SType2 is derived, volatile and transient. (see ecore
snapshot below, I simplified it a little bit for easier understandability)
When I now use the simple tree based editor to create a model, the Option
of creating a child node SType 2 is greyed out. I can only create the
mixed content stuff.
I debugged through the code and apparently the problem seems to be that
the SType2 instances do not match a wildcard. That fact makes the command
not executable, ... the menu item is greyed out.
I assume it has to do with: <details key="kind" value="elementWildcard"/>
Unfortunately I do not really understand what this ecore entry means to
EMF and thus do not know what else to enter there.
I would like the feature map to store all the mixed content and my feature
of type SType2, so that all are ordered.
Thank you a lot in advance,
Regards Robert
This is the Main Type:
<eClassifiers xsi:type="ecore:EClass" name="MType2">
<eAnnotations
source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="name" value="MType2"/>
<details key="kind" value="mixed"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="mtf2"
ordered="false" upperBound="-1"
eType="#//SType2" volatile="true" transient="true" derived="true"
containment="true">
</eStructuralFeatures>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="mixed"
unique="false" upperBound="-1"
eType="ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EFeatureMapEntry">
<eAnnotations
<details key="name" value=":mixed"/>
</eAnnotations>
</eClassifiers>
This is the Sub Type (feature of Main Type):
<eClassifiers xsi:type="ecore:EClass" name="SType2">
<eAnnotations
<details key="name" value="SType2"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="l"
eType="#//String" volatile="true"
transient="true" derived="true">
<eStructuralFeatures xsi:type="ecore:EReference" name="e"
ordered="false" eType="#//SSType"
volatile="true" transient="true" derived="true" containment="true">
<eAnnotations
</eAnnotations>
</eClassifiers>
Re: Mixed Content with elementWildcard and complex subfeatures [message #401944 is a reply to message #401941] |
Tue, 20 June 2006 12:25 |
Ed Merks Messages: 33217 Registered: July 2009 |
--------------060402030703010401070200
Robert,
I'd normally expect the mixed feature to be the first feature. Only
element-based features derive from the mixed feature so you need to add
*this*:
* <eAnnotations
source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">*
* <details key="kind" value="element"/>*
* </eAnnotations>*
Robert Mitschke wrote:
> Hi all,
> that I have to use FeatureMaps. So MType2 has a mixed attribute and
> the feature mtf2 of Type SType2 is derived, volatile and transient.
> (see ecore snapshot below, I simplified it a little bit for easier
> understandability)
> Option of creating a child node SType 2 is greyed out. I can only
> create the mixed content stuff.
> that the SType2 instances do not match a wildcard. That fact makes the
> command not executable, ... the menu item is greyed out.
> to EMF and thus do not know what else to enter there.
> feature of type SType2, so that all are ordered.
> Regards Robert
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> <eAnnotations
> </eAnnotations>
> containment="true">
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
<html>
<head>
http-equiv="Content-Type">
</head>
Robert,<br>
<br>
Ed Merks
FUDForum. Page generated in 0.02837 seconds
