Home » Eclipse Projects » Rich Client Platform (RCP) » RCP and GEF: Cannot open editor
RCP and GEF: Cannot open editor [message #400797] Mon, 20 December 2004 19:11 Go to next message
I'm trying to learn both RCP and GEF. Peter Mayne posted a nice GEF
plugin some time ago to the GEF newsgroup and now I'm trying to create a
RCP application of it.
He defined that files ending ".smeg" open the GEF editor. However, I'd
like to open the editor within the postWindowOpen method of the
WorkbenchAdvisor class and I don't want a persisted model. I'd like to
provide the model when starting the application.
Here's the postWindowOpen method of the WorchbenchAdvisor class:
public void postWindowOpen(IWorkbenchWindowConfigurer configurer) {
super.postWindowOpen(configurer);
SmegEditorInput input = new SmegEditorInput();
input.setModelRoot(new SmegDiagramModel());
String editorId = "com.spherion.ap.smeg.editors.SmegEditor";
IWorkbenchPage page = configurer.getWindow().getActivePage();
try {
page.openEditor(input, editorId, true);
} catch (PartInitException e) {
e.printStackTrace();
But I always get a PartInitException (Unable to open editor, unknown
editor ID: com.spherion.ap.smeg.editors.SmegEditor) as can be seen at
the end of this posting.
The editor should be known, though:
plugin.xml:
<extension
point="org.eclipse.ui.editors">
<editor
class="com.spherion.ap.smeg.editors.SmegEditor"
default="true"
name="Smeg Editor"
id="com.spherion.ap.smeg.editors.SmegEditor"/>
</extension>
I'd be very happy if someone could enlighten me on what I'm doing wrong.
I've been trying to get this running for more than 2 days now and cannot
find a solution.
Thanks in advance for any hint on what I'm missing.
Christian
Output when running the RCP app:
Invalid Menu Extension (Path is invalid): org.eclipse.update.ui.updateMenu
org.eclipse.update.ui.configManager
Invalid Menu Extension (Path is invalid): org.eclipse.update.ui.newUpdates
org.eclipse.ui.actions.showKeyAssistHandler
Plugin com.spherion.ap.smeg, extension org.eclipse.ui.editors
Required attribute 'icon' not defined
org.eclipse.ui.PartInitException: Unable to open editor, unknown editor
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:630)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2207)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2139)
at org.eclipse.ui.internal.WorkbenchPage.access$5(WorkbenchPage .java:2131)
at org.eclipse.ui.internal.WorkbenchPage$8.run(WorkbenchPage.ja va:2117)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2112)
com.spherion.ap.smeg.SmegWorkbenchAdvisor.postWindowOpen(Sme gWorkbenchAdvisor.java:36)
at org.eclipse.ui.internal.WorkbenchWindow.open(WorkbenchWindow .java:586)
org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Wo rkbench.java:587)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1170)
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:178)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:665)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:886)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1516)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:285)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
at com.spherion.ap.smeg.SmegApplication.run(SmegApplication.jav a:18)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:220)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:710)
at org.eclipse.core.launcher.Main.main(Main.java:694)
Re: RCP and GEF: Cannot open editor [message #400810 is a reply to message #400797] Tue, 21 December 2004 10:50 Go to previous messageGo to next message
This indicates that the workbench skipped your editor extension because
it's missing an icon attribute. Add this attribute, with the value
being a plug-in relative path to a 16x16 .gif file, and try again.
It also looks like you're including the org.eclipse.ui.ide and
org.eclipse.ui.editors plug-ins, which are not designed for reuse in RCP
apps.
See
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-ui-home/rcp/faq.html#idePlugin
Nick
Re: RCP and GEF: Cannot open editor [message #400859 is a reply to message #400810] Tue, 21 December 2004 17:03 Go to previous messageGo to next message
> apps.
> See
> Nick
Thanks Nick. It works now. I just don't understand why the plugin.xml
editor doesn't tell me to add an icon if it is required. But I'm happy
as the editor can be opened.
Christian
Re: RCP and GEF: Cannot open editor [message #400865 is a reply to message #400859] Tue, 21 December 2004 18:13 Go to previous messageGo to next message
Not to mention, why is it required. Do all applications display the
editor's icon?
"Christian Hauser" <c.hauser@active.ch> wrote in message
news:cqa6j2$fca$1@www.eclipse.org...
> > apps.
> > See
> > Nick
> Christian
Re: RCP and GEF: Cannot open editor [message #401535 is a reply to message #400859] Wed, 22 December 2004 16:38 Go to previous messageGo to next message
The workbench could be made more lenient here. The icon attribute is
not marked as required in the schema because there are other
configurations (e.g. external editors) where the icon doesn't make sense.
Please file a bug report against Platform UI for this, if you care.
Nick
>> because it's missing an icon attribute. Add this attribute, with the
>> value being a plug-in relative path to a 16x16 .gif file, and try again.
>> RCP apps.
>> See
>> Nick
> Christian
Eclipse Executable Jar File not working [message #405104 is a reply to message #400797] Tue, 18 January 2005 15:53 Go to previous message
Originally posted by: sfrierdich.custom-mfg-eng.com
HI
I creates an executable jar file for my application. When I click on the
file I get the same error everytime that the main could not be found.
The main class is pointed when created the jar file. Anyone have any
suggestions
Steve
Previous Topic:View state
Next Topic:RCP appl connecting to a JBOSS server
Current Time: Fri Nov 07 16:53:43 EST 2025
Powered by FUDForum. Page generated in 0.04624 seconds
