Home » Modeling » EMF » HREF Problem
Re: HREF Problem [message #398935 is a reply to message #398930] |
Wed, 01 March 2006 16:46 |
Stefan Sommer Messages: 6 Registered: July 2009 |
------=_NextPart_000_00A8_01C63D58.12E60A40
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
i am using EMF Version 2.1.2 and the method =
adaptor.getConnector().eIsProxy() returns true. Do i have to use a newer =
version of emf or is there another solution to access the referenced =
object without loading it explicitly?
"Ed Merks" <merks@ca.ibm.com> schrieb im Newsbeitrag =
news:du4ckk$e9j$1@utils.eclipse.org...
Stefan,
Which version of EMF are you using? Older versions used to always =
treat handle "href" exactly as it is for XMI, i.e., it would set the =
value as the InternalEObject.eProxyURI of the current object.... You can =
tell this is happening if adapter.getConnector().eIsProxy() returns =
true.
Stefan Sommer wrote:=20
i am trying to load a xml which has a hyperref to another document. =
In my testcode the getHRef-Method returns null?
adaptorResource.load(options);
adaptor.getConnector().getHref();
Before loading the adaptor i added the 2 required resources to the =
resourceset and i think the loader must initialize the connector ref as =
a proxy. What's going wrong?
The xml i am trying to load:
<?xml version=3D"1.0" encoding=3D"UTF-8"?>
<adaptor xmlns:ecore=3D"http://www.eclipse.org/emf/2002/Ecore" =
xmlns:xsi=3D"http://www.w3.org/2001/XMLSchema-instance" =
xsi:noNamespaceSchemaLocation=3D"C:\workspace\wbII\CH.obj.wb.model\resour=
ces\core_modelDefinition.xsd">
<timeout code=3D"da vinci">1000</timeout>
<name>Read_from_Bison</name>
<enabled>true</enabled>
<maxTx>8</maxTx>
<mode>reader</mode>
<length>2</length>
<que>
<enabled>false</enabled>
</que>
<connector href=3D"sample_connector.xml#abc"/>
</adaptor>
The schema for my hyperref-complextype looks like this:
<xs:complexType name=3D"ConnectorRef">
<xs:attribute name=3D"href" type=3D"xs:anyURI" use=3D"required" =
ecore:reference=3D"Connector"/>
</xs:complexType>
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.2900.2802" name=3DGENERATOR></HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT size=3D1> </FONT><FONT face=3DArial size=3D2>Hi,</FONT>
<P><FONT face=3DArial size=3D2>i am using EMF Version 2.1.2 and the =
method=20
version=20
of emf or is there another solution to access the referenced object =
without=20
loading it explicitly?</FONT></P></DIV>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
schrieb im Newsbeitrag <A=20
href=3D"news:du4ckk$e9j$1@utils.eclipse.org">news:du4ckk$e9j$1@utils.ecli=
pse.org</A>...</DIV>Stefan,<BR><BR>Which=20
treat handle=20
"href" exactly as it is for XMI, i.e., it would set the value as the=20
InternalEObject.eProxyURI of the current object.... You can tell this =
is=20
true.<BR><BR><BR>Stefan=20
Sommer wrote:=20
<BLOCKQUOTE cite=3Dmiddu48rh$34v$1@utils.eclipse.org type=3D"cite">
<STYLE></STYLE>
<DIV>Hi,</DIV>
<DIV>i am trying to load a xml which has a hyperref to =
another=20
document. In my testcode the getHRef-Method returns null?</DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial><FONT size=3D2> <FONT=20
face=3D"Courier =
New">adaptorResource.load(options);</FONT></FONT></FONT> </DIV>
<DIV><FONT face=3D"Courier New" size=3D2><FONT face=3D"Times New =
Roman"=20
size=3D3> </FONT><FONT face=3D"Courier New"=20
size=3D2>adaptor.getConnector().getHref();</FONT></FONT></DIV >
<DIV> </DIV>
<DIV> Before loading the adaptor i added the 2 required =
resources to=20
the resourceset and i think the loader must initialize the connector =
ref as=20
a proxy. What's going wrong?</DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV>The xml i am trying to load:</DIV>
<BLOCKQUOTE dir=3Dltr style=3D"MARGIN-RIGHT: 0px">
<DIV><FONT size=3D2></FONT>
<P><FONT size=3D2><?xml version=3D"1.0"=20
encoding=3D"UTF-8"?></FONT></P><FONT size=3D2></FONT>
<P><FONT size=3D2><adaptor xmlns:ecore=3D<A =
class=3Dmoz-txt-link-rfc2396E=20
href=3D"http://www.eclipse.org/emf/2002/Ecore">"http://www.eclipse.org/em=
f/2002/Ecore"</A>=20
xmlns:xsi=3D<A class=3Dmoz-txt-link-rfc2396E=20
href=3D"http://www.w3.org/2001/XMLSchema-instance">"http://www.w3.org/200=
1/XMLSchema-instance"</A>=20
ces\core_modelDefinition.xsd"></FONT></P><FONT=20
size=3D2></FONT>
<P><FONT size=3D2><timeout code=3D"da=20
vinci">1000</timeout></FONT></P><FONT size=3D2></FONT>
<P><FONT =
size=3D2><name>Read_from_Bison</name> </FONT></P><FONT=20
size=3D2></FONT>
<P><FONT =
size=3D2><enabled>true</enabled> </FONT></P><FONT=20
size=3D2></FONT>
<P><FONT size=3D2><maxTx>8</maxTx></FONT ></P><FONT=20
size=3D2></FONT>
<P><FONT size=3D2><mode>reader</mode></FONT ></P><FONT=20
size=3D2></FONT>
<P><FONT size=3D2><length>2</length></FONT ></P><FONT=20
size=3D2></FONT>
<P><FONT size=3D2><que></FONT></P><FONT size=3D2></FONT>
<P><FONT =
size=3D2><enabled>false</enabled> </FONT></P><FONT=20
size=3D2></FONT>
<P><FONT size=3D2></que></FONT></P><FONT size=3D2></FONT>
<P><FONT size=3D2><connector=20
href=3D"sample_connector.xml#abc"/></FONT></P><FONT =
size=3D2></FONT>
<P><FONT size=3D2></adaptor></FONT></P></DIV></BLOCKQUOTE >
<DIV> </DIV>
<DIV>The schema for my hyperref-complextype looks like this:</DIV>
<P><xs:complexType name=3D"ConnectorRef"></P>
<P><xs:attribute name=3D"href" type=3D"xs:anyURI" =
use=3D"required"=20
ecore:reference=3D"Connector"/></P>
<P></xs:complexType></P></FONT></DIV></BLOCKQUOTE ><BR></BLOCKQUOTE>=
</BODY></HTML>
------=_NextPart_000_00A8_01C63D58.12E60A40--
Re: HREF Problem [message #398946 is a reply to message #398935] |
Wed, 01 March 2006 20:18 |
Ed Merks Messages: 33141 Registered: July 2009 |
--------------080705020803010507040107
Stefan,
XMLHandler has this code in the constructor:
hrefAttribute = XMLResource.HREF;
if
(Boolean.TRUE.equals(options.get(XMLResource.OPTION_USE_ENCO DED_ATTRIBUTE_STYLE)))
hrefAttribute = null;
This SAXXMLHandler method uses that:
protected void handleObjectAttribs(EObject obj)
if (attribs != null)
InternalEObject internalEObject = (InternalEObject)obj;
for (int i = 0, size = attribs.getLength(); i < size; ++i)
String name = attribs.getQName(i);
if (name.equals(idAttribute))
xmlResource.setID(internalEObject, attribs.getValue(i));
else if (name.equals(*hrefAttribute*) &&
(!recordUnknownFeature || types.peek() != UNKNOWN_FEATURE_TYPE))
handleProxy(internalEObject, attribs.getValue(i));
else if (!name.startsWith(XMLResource.XML_NS) &&
!notFeatures.contains(name))
setAttribValue(obj, name, attribs.getValue(i));
So you need this to be null for it to work properly. Are you using the
XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE option?
> newer version of emf or is there another solution to access the
> referenced object without loading it explicitly?
> "Ed Merks" <merks@ca.ibm.com <mailto:merks@ca.ibm.com>> schrieb im
> Newsbeitrag news:du4ckk$e9j$1@utils.eclipse.org...
> Stefan,
> the value as the InternalEObject.eProxyURI of the current
> object.... You can tell this is happening if
> adapter.getConnector().eIsProxy() returns true.
>> Hi,
>> connector ref as a proxy. What's going wrong?
>> <?xml version="1.0" encoding="UTF-8"?>
>> <adaptor xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xsi:noNamespaceSchemaLocation=" C:\workspace\wbII\CH.obj.wb.model\resources\core_modelDefini tion.xsd ">
>> <timeout code="da vinci">1000</timeout>
>> <maxTx>8</maxTx>
>> <mode>reader</mode>
>> <length>2</length>
>> <que>
>> </que>
>> <connector href="sample_connector.xml#abc"/>
>> </adaptor>
>> <xs:complexType name="ConnectorRef">
>> <xs:attribute name="href" type="xs:anyURI" use="required"
>> ecore:reference="Connector"/>
>> </xs:complexType>
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Stefan,<br>
<br>
XMLHandler has this code in the constructor:<br>
<br>
<small> hrefAttribute = XMLResource.HREF;<br>
<br>
if
(Boolean.TRUE.equals(options.get(XMLResource.OPTION_USE_ENCO DED_ATTRIBUTE_STYLE))) <br>
{<br>
hrefAttribute = null;<br>
}</small><br>
<br>
This SAXXMLHandler method uses that:<br>
<blockquote><small> protected void handleObjectAttribs(EObject obj)<br>
{<br>
if (attribs != null)<br>
{<br>
InternalEObject internalEObject = (InternalEObject)obj;<br>
for (int i = 0, size = attribs.getLength(); i < size; ++i)<br>
{<br>
String name = attribs.getQName(i);<br>
if (name.equals(idAttribute))<br>
{<br>
xmlResource.setID(internalEObject, attribs.getValue(i));<br>
}<br>
else if (name.equals(<b>hrefAttribute</b>) &&
(!recordUnknownFeature || types.peek() != UNKNOWN_FEATURE_TYPE))<br>
{<br>
handleProxy(internalEObject, attribs.getValue(i));<br>
}<br>
!notFeatures.contains(name))<br>
{<br>
setAttribValue(obj, name, attribs.getValue(i));<br>
}<br>
}<br>
}<br>
}</small><br>
</blockquote>
<small>XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE option?</small><br>
<br>
<br>
<blockquote cite="middu4j58$4dl$1@utils.eclipse.org" type="cite">
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<meta content="MSHTML 6.00.2900.2802" name="GENERATOR">
<div><font size="1"> </font><font face="Arial" size="2">Hi,</font>
<p><font face="Arial" size="2">i am using EMF Version 2.1.2 and the
method adaptor.getConnector().eIsProxy() returns true. Do i have to use
a newer version of emf or is there another solution to access the
referenced object without loading it explicitly?</font></p>
</div>
<blockquote
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;">
<div>"Ed Merks" <<a href="mailto:merks@ca.ibm.com">merks@ca.ibm.com</a>>
schrieb im Newsbeitrag <a href="news:du4ckk$e9j$1@utils.eclipse.org">news:du4ckk$e9j$1@utils.eclipse.org</a>...</div>
Stefan,<br>
<br>
can tell this is happening if adapter.getConnector().eIsProxy() returns
true.<br>
<br>
<br>
<blockquote cite="middu48rh$34v$1@utils.eclipse.org" type="cite">
<style></style>
<div>Hi,</div>
<div>i am trying to load a xml which has a hyperref to another
document. In my testcode the getHRef-Method returns null?</div>
<div> </div>
<div><font face="Arial"><font size="2"> <font face="Courier New">adaptorResource.load(options);</font></font></font> </div>
<div><font face="Courier New" size="2"><font
face="Times New Roman" size="3"> </font><font face="Courier New"
size="2">adaptor.getConnector().getHref();</font></font> </div>
<div> </div>
<div> Before loading the adaptor i added the 2 required resources
to the resourceset and i think the loader must initialize the connector
ref as a proxy. What's going wrong?</div>
<div> </div>
<div> </div>
<div>The xml i am trying to load:</div>
<blockquote style="margin-right: 0px;" dir="ltr">
<div>
<p><font size="2"><?xml version="1.0" encoding="UTF-8"?></font></p>
<p><font size="2"><adaptor xmlns:ecore=<a
class="moz-txt-link-rfc2396E"
href="http://www.eclipse.org/emf/2002/Ecore">"http://www.eclipse.org/emf/2002/Ecore"</a>
xmlns:xsi=<a class="moz-txt-link-rfc2396E"
href="http://www.w3.org/2001/XMLSchema-instance">"http://www.w3.org/2001/XMLSchema-instance"</a>
xsi:noNamespaceSchemaLocation=" C:\workspace\wbII\CH.obj.wb.model\resources\core_modelDefini tion.xsd "></font></p>
<p><font size="2"><timeout code="da
vinci">1000</timeout></font></p>
<p><font size="2"><name>Read_from_Bison</name> </font></p>
<p><font size="2"><enabled>true</enabled> </font></p>
<p><font size="2"><maxTx>8</maxTx></font ></p>
<p><font size="2"><mode>reader</mode></font ></p>
<p><font size="2"><length>2</length></font ></p>
<p><font size="2"><que></font></p>
<p><font size="2"><enabled>false</enabled> </font></p>
<p><font size="2"></que></font></p>
<p><font size="2"><connector
href="sample_connector.xml#abc"/></font></p>
<p><font size="2"></adaptor></font></p>
</div>
</blockquote>
<div> </div>
<div>The schema for my hyperref-complextype looks like this:</div>
<div><font size="2">
<p><xs:complexType name="ConnectorRef"></p>
<p><xs:attribute name="href" type="xs:anyURI" use="required"
ecore:reference="Connector"/></p>
<p></xs:complexType></p>
</font></div>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------080705020803010507040107--
Ed Merks
Re: HREF Problem [message #398967 is a reply to message #398946] |
Thu, 02 March 2006 09:18 |
------=_NextPart_000_0009_01C63DE2.A2735B10
When i set the option "OPTION_USE_ENCODED_ATTRIBUTE_STYLE" to false it =
works fine!
thankz a lot
greets stef
news:du4vhr$cm5$1@utils.eclipse.org...
Stefan,
hrefAttribute =3D XMLResource.HREF;
=20
if =
(Boolean.TRUE.equals(options.get(XMLResource.OPTION_USE_ENCO DED_ATTRIBUTE=
_STYLE)))
hrefAttribute =3D null;
if (attribs !=3D null)
InternalEObject internalEObject =3D (InternalEObject)obj;
for (int i =3D 0, size =3D attribs.getLength(); i < size; ++i)
String name =3D attribs.getQName(i);
else if (name.equals(hrefAttribute) && =
(!recordUnknownFeature || types.peek() !=3D UNKNOWN_FEATURE_TYPE))
else if (!name.startsWith(XMLResource.XML_NS) && =
So you need this to be null for it to work properly. Are you using =
the XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE option?
Hi,=20
Stefan,
true.
i am trying to load a xml which has a hyperref to another =
Before loading the adaptor i added the 2 required resources to =
the resourceset and i think the loader must initialize the connector ref =
<maxTx>8</maxTx>
<mode>reader</mode>
<length>2</length>
<que>
</que>
</adaptor>
</xs:complexType>
<HTML><HEAD>
<DIV><FONT size=3D2><FONT size=3D3>When i set the option</FONT>=20
"OPTION_USE_ENCODED_ATTRIBUTE_STYLE" </FONT><FONT size=3D3>to false it =
works=20
fine!</FONT></DIV>
<DIV><FONT size=3D2></FONT> </DIV>
<DIV>thankz a lot</DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV>greets stef</DIV>
<BLOCKQUOTE=20
href=3D"news:du4vhr$cm5$1@utils.eclipse.org">news:du4vhr$cm5$1@utils.ecli=
pse.org</A>...</DIV>Stefan,<BR><BR>XMLHandler=20
has this code in the constructor:<BR><BR><SMALL> =20
hrefAttribute =3D XMLResource.HREF;<BR> =
<BR> =20
if=20
_STYLE)))<BR> =20
{<BR> hrefAttribute =3D=20
null;<BR> }</SMALL><BR><BR>This SAXXMLHandler method =
uses=20
that:<BR>
<BLOCKQUOTE><SMALL> protected void handleObjectAttribs(EObject=20
obj)<BR> {<BR> if (attribs !=3D=20
null)<BR> {<BR> =20
InternalEObject internalEObject =3D=20
(InternalEObject)obj;<BR> for (int i =
=3D 0, size=20
=3D attribs.getLength(); i < size; =
++i)<BR> =20
{<BR> String name =3D=20
attribs.getQName(i);<BR> =
if=20
(name.equals(idAttribute))<BR> =
{<BR> =20
xmlResource.setID(internalEObject,=20
attribs.getValue(i));<BR> =20
}<BR> else if=20
(name.equals(<B>hrefAttribute</B>) && (!recordUnknownFeature =
||=20
types.peek() !=3D=20
UNKNOWN_FEATURE_TYPE))<BR> =
{<BR> =20
handleProxy(internalEObject,=20
}<BR> else if=20
(!name.startsWith(XMLResource.XML_NS) &&=20
!notFeatures.contains(name))<BR>  =
;=20
{<BR> =20
setAttribValue(obj, name,=20
}<BR> }<BR> =
}<BR> =20
}</SMALL><BR></BLOCKQUOTE>So you need this to be null for it to work =
properly. Are you using the=20
<SMALL>XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE=20
option?</SMALL><BR><BR><BR>Stefan Sommer wrote:=20
<BLOCKQUOTE cite=3Dmiddu4j58$4dl$1@utils.eclipse.org type=3D"cite">
<DIV><FONT size=3D1> </FONT><FONT face=3DArial =
size=3D2>Hi,</FONT>=20
method=20
adaptor.getConnector().eIsProxy() returns true. Do i have to use a =
newer=20
object=20
without loading it explicitly?</FONT></P></DIV>
<BLOCKQUOTE=20
BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A=20
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>> schrieb =
im=20
Newsbeitrag <A=20
treat=20
value as=20
tell this=20
is happening if adapter.getConnector().eIsProxy() returns=20
true.<BR><BR><BR>Stefan Sommer wrote:=20
<BLOCKQUOTE cite=3Dmiddu48rh$34v$1@utils.eclipse.org =
type=3D"cite">
<STYLE></STYLE>
<DIV>Hi,</DIV>
another=20
<DIV> </DIV>
face=3D"Courier =
Roman"=20
<DIV> </DIV>
resources=20
to the resourceset and i think the loader must initialize the =
connector=20
ref as a proxy. What's going wrong?</DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV>
<P><FONT =
<P><FONT =
<P><FONT =
<P><FONT =
<DIV> </DIV>
<DIV>The schema for my hyperref-complextype looks like =
this:</DIV>
use=3D"required"=20
</BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0009_01C63DE2.A2735B10--
Re: HREF Problem [message #398978 is a reply to message #398967] |
Thu, 02 March 2006 12:47 |
--------------050805030404090904050301
Stefan,
I'm concerned that it might be working correctly, but for the wrong
reason. Perhaps you've generated code before this bugzilla was fixed:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=81512
I would expect the resource to use that option set to TRUE for both load
and save like this:
public Resource createResource(URI uri) {
XMLResource result = new WemResourceImpl(uri);
result.getDefaultSaveOptions().put(XMLResource.OPTION_EXTEND ED_META_DATA,
extendedMetaData);
result.getDefaultLoadOptions().put(XMLResource.OPTION_EXTEND ED_META_DATA,
extendedMetaData);
result.getDefaultSaveOptions().put(XMLResource.OPTION_SCHEMA _LOCATION,
Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_EN CODED_ATTRIBUTE_STYLE,
Boolean.TRUE);*
result.getDefaultSaveOptions().put(XMLResource.OPTION_USE_EN CODED_ATTRIBUTE_STYLE,
Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_LE XICAL_HANDLER,
Boolean.TRUE);
return result;
> works fine!
> thankz a lot
> greets stef
> Newsbeitrag news:du4vhr$cm5$1@utils.eclipse.org...
> Stefan,
> if
> using the XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE option?
>> Hi,
>> schrieb im Newsbeitrag news:du4ckk$e9j$1@utils.eclipse.org...
>> Stefan,
>> always treat handle "href" exactly as it is for XMI, i.e., it
>> would set the value as the InternalEObject.eProxyURI of the
>> current object.... You can tell this is happening if
>>> Hi,
>>> the connector ref as a proxy. What's going wrong?
>>> <adaptor
>>> <maxTx>8</maxTx>
>>> <mode>reader</mode>
>>> <length>2</length>
>>> <que>
>>> </que>
>>> </adaptor>
>>> </xs:complexType>
<html>
<head>
</head>
Stefan,<br>
<br>
reason. Perhaps you've generated code before this bugzilla was fixed:<br>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=81512">https://bugs.eclipse.org/bugs/show_bug.cgi?id=81512</a><br>
</blockquote>
load and save like this:<br>
<br>
<small> public Resource createResource(URI uri) {<br>
XMLResource result = new WemResourceImpl(uri);<br>
extendedMetaData);<br>
<br>
Boolean.TRUE);<br>
<br>
<b>
Boolean.TRUE);</b><br>
Boolean.TRUE);<br>
<br>
Boolean.TRUE);<br>
return result;<br>
}</small><br>
<br>
<blockquote cite="middu6d71$d1a$1@utils.eclipse.org" type="cite">
<div><font size="2"><font size="3">When i set the option</font>
"OPTION_USE_ENCODED_ATTRIBUTE_STYLE" </font><font size="3">to false it
works fine!</font></div>
<div> </div>
<div>thankz a lot</div>
<div> </div>
<div>greets stef</div>
<blockquote
schrieb im Newsbeitrag <a href="news:du4vhr$cm5$1@utils.eclipse.org">news:du4vhr$cm5$1@utils.eclipse.org</a>...</div>
Stefan,<br>
<br>
<br>
<br>
if
{<br>
}</small><br>
<br>
{<br>
{<br>
{<br>
{<br>
}<br>
{<br>
}<br>
{<br>
}<br>
}<br>
}<br>
}</small><br>
</blockquote>
<br>
<br>
the method adaptor.getConnector().eIsProxy() returns true. Do i have to
use a newer version of emf or is there another solution to access the
</div>
<blockquote
Stefan,<br>
<br>
true.<br>
<br>
<br>
<style></style>
<div>Hi,</div>
another document. In my testcode the getHRef-Method returns null?</div>
<div> </div>
<div> </div>
resources to the resourceset and i think the loader must initialize the
connector ref as a proxy. What's going wrong?</div>
<div> </div>
<div> </div>
<blockquote dir="ltr" style="margin-right: 0px;">
<div>
</div>
</blockquote>
<div> </div>
use="required" ecore:reference="Connector"/></p>
</font></div>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------050805030404090904050301--
Ed Merks
Current Time: Fri Apr 26 02:37:59 GMT 2024
Powered by FUDForum. Page generated in 0.03699 seconds
