Home » Modeling » EMF » How to get the Command elements from a xsd component
How to get the Command elements from a xsd component [message #398619] Sun, 19 February 2006 17:58 Go to next message
I was using the following lines to get my original list of commands:
//c is an instanceof XSDConcreteComponent
XSDItemProviderAdapterFactory ipaf = new XSDItemProviderAdapterFactory();
BasicCommandStack commandStack= new BasicCommandStack();
AdapterFactoryEditingDomain editingDomain = new AdapterFactoryEditingDomain(m_ipaf , m_commandStack, new HashMap());
ItemProviderAdapter ipa = (ItemProviderAdapter)ipaf.createAdapter(c);
Collection cd = ipa.getNewChildDescriptors(c, editingDomain, null);
if(cd.size() > 0) {
  Iterator iter = cd.iterator();
  CommandParameter cp = null;
  while (iter.hasNext()) {
    cp = (CommandParameter)iter.next();
    CreateChildCommand ccc = new CreateChildCommand(m_editingDomain, c, cp.getEStructuralFeature(), cp.getEValue(), cd, ipa);
    //Do something with the create child command here
After your(Ed Merks) suggestion that i use the adapt method instead of casting directly, i adapted it to IEditingDomainItemProvider, which is the clostest i can find that fits what i need.
so the new code is:
IEditingDomainItemProvider edip = (IEditingDomainItemProvider)ipaf.adapt(c, IEditingDomainItemProvider.class);
Collection cd = edip.getNewChildDescriptors(c, editingDomain, null);
if(cd.size() > 0) {
    Command ccc = edip.createCommand(c, m_editingDomain, CreateChildCommand.class, cp);
    //Do something with the command here
When i do this however, during runtime i get the exception
java.lang.ClassCastException
at org.eclipse.emf.edit.provider.ItemProviderAdapter.createComm and(ItemProviderAdapter.java:855)
What am I doing wrong
Re: How to get the Command elements from a xsd component [message #398625 is a reply to message #398619] Mon, 20 February 2006 07:45 Go to previous messageGo to next message
Frank,
Try using CreateChildCommand.create (the way CreateChildAction does)
instead calling createCommand directly on the item provider.
>if(cd.size() > 0) {
>so the new code is:
>if(cd.size() > 0) {
Re: How to get the Command elements from a xsd component [message #398631 is a reply to message #398625] Mon, 20 February 2006 09:12 Go to previous messageGo to next message
I still get the same error
at org.eclipse.emf.edit.domain.AdapterFactoryEditingDomain.crea teCommand(AdapterFactoryEditingDomain.java:397)
at org.eclipse.emf.edit.command.CreateChildCommand.create(Creat eChildCommand.java:64)
I have the source for the non-standalone emf. Although at line 855 in ItemProviderAdaptor doesn't seem to match the error, I'm guessing the class cast error occurs at the block
else if (commandClass == CreateChildCommand.class)
      CommandParameter newChildParameter = (CommandParameter)commandParameter.getValue();
      result =
        createCreateChildCommand
          (domain,
           commandParameter.getEOwner(),
           newChildParameter.getEStructuralFeature(),
           newChildParameter.getValue(),
           newChildParameter.getIndex(),
           commandParameter.getCollection());
It seems to cast the CommandParameter value to another CommandParameter, from what I see, the CommandParameter I'm passing in has a value that's not an instanceof CommandParameter. The code I'm using is
Command ccc = CreateChildCommand.create(editingDomain, cp.getFeature(), cp.getValue(), cp.getCollection());
where cp is gotten as in the previous message thread
Re: How to get the Command elements from a xsd component [message #398633 is a reply to message #398631] Mon, 20 February 2006 09:21 Go to previous message
--------------060301060001000403010107
Frank,
It doesn't look like you are passing the right arguments for this method:
public static Command create(EditingDomain domain, Object owner,
Object newChildDescriptor,
Collection selection)
return domain.createCommand(
new CommandParameter(owner, null, newChildDescriptor, selection));
It's good to look at CreateChildAction because that works for sure.
>      result =
>          (domain,
<html>
<head>
</head>
Frank,<br>
<br>
method:<br>
<blockquote>&nbsp; public static Command create(EditingDomain domain, Object
owner,<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Object newChildDescriptor,<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Collection selection)<br>
&nbsp; {<br>
&nbsp;&nbsp;&nbsp; return domain.createCommand(<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; CreateChildCommand.class,<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; new CommandParameter(owner, null, newChildDescriptor, selection));<br>
&nbsp; }<br>
</blockquote>
It's good to look at CreateChildAction because that works for sure.<br>
<br>
<br>
frank wrote:
<blockquote
cite="mid27573387.1140444787696.JavaMail.root@cp1.javalobby.org"
type="cite">
<pre wrap="">I still get the same error
      result =
          (domain,
</pre>
</blockquote>
<br>
</body>
</html>
--------------060301060001000403010107--
Previous Topic:Dynamic generation of an EClass from an arbitrary Java class
Next Topic:Additional code in the model
Current Time: Mon Sep 22 05:08:32 EDT 2025
Powered by FUDForum. Page generated in 0.03391 seconds
