Home » Modeling » EMF » reloading genmodel fails
reloading genmodel fails [message #398573] Wed, 15 February 2006 12:18 Go to next message
Hi all,
I'm just running into a strange problem.
When I try to reload some genmodel, it fails to detect the available
ecore models (I'm generating from annotated java code). I can see an
NullPointerException in the log (stack trace included at the end for
plugin org.eclipse.emf.importer.java).
But, if I just cut & paste the project (with a different name) it works
just fine... So I suspect some configuration files to be corrupted?
Unfortunately I cannot find something like that in the Eclipse's
metadata folder.
Any clue?
Serge.
EMF build ID: 200601190000
Stack trace:
org.eclipse.emf.codegen.ecore.genmodel.impl.GenBaseImpl.find GenPackageHelper(GenBaseImpl.java:801)
org.eclipse.emf.codegen.ecore.genmodel.impl.GenBaseImpl.find GenPackage(GenBaseImpl.java:873)
org.eclipse.emf.importer.java.builder.JavaEcoreBuilder.used( JavaEcoreBuilder.java:491)
org.eclipse.emf.importer.java.builder.JavaEcoreBuilder.analy seProject(JavaEcoreBuilder.java:306)
org.eclipse.emf.importer.java.builder.JavaEcoreBuilder.compu teEPackages(JavaEcoreBuilder.java:456)
org.eclipse.emf.importer.java.JavaImporter.doComputeEPackage s(JavaImporter.java:82)
org.eclipse.emf.importer.ModelImporter.computeEPackages(Mode lImporter.java:482)
org.eclipse.emf.importer.java.ui.JavaPackagePage.computeEPac kages(JavaPackagePage.java:106)
org.eclipse.emf.importer.java.ui.JavaPackagePage$2.execute(J avaPackagePage.java:81)
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:100)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1714)
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:112)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:360)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:305)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 843)
org.eclipse.emf.importer.java.ui.JavaPackagePage.computeEPac kages(JavaPackagePage.java:96)
org.eclipse.emf.importer.java.ui.JavaPackagePage$1.run(JavaP ackagePage.java:59)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3262)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2908)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:808 )
at org.eclipse.jface.window.Window.open(Window.java:786)
org.eclipse.emf.converter.ui.OpenWizardActionDelegate.run(Op enWizardActionDelegate.java:112)
org.eclipse.emf.converter.ui.OpenWizardActionDelegate.run(Op enWizardActionDelegate.java:102)
org.eclipse.ui.actions.ActionDelegate.runWithEvent(ActionDel egate.java:70)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:241)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:530)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:480)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:392)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:914)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3285)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2905)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1762)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1726)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:397)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:106)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:109)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:379)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Re: reloading genmodel fails [message #398574 is a reply to message #398573] Wed, 15 February 2006 12:37 Go to previous messageGo to next message
Serge,
Can you open the .genmodel you are reloading with the Generator editor
without it producing error messages about missing packages? Does create
a new .genmodel work okay? (I.e., File->New->Other->Eclipse Modeling
Framework->EMF Model.)
Serge Fantino wrote:
> Hi all,
> works just fine... So I suspect some configuration files to be
> corrupted? Unfortunately I cannot find something like that in the
> Eclipse's metadata folder.
> Any clue?
> Serge.
> Stack trace:
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: reloading genmodel fails [message #398575 is a reply to message #398574] Wed, 15 February 2006 12:57 Go to previous message
Thanks Ed...
Actually I just upgraded EMF to the last release and now it works nice :)
Regarding your questions:
- I can open the .genmodel
- I cannot create a new one
Serge.
Ed Merks wrote:
> Serge,
>> Hi all,
>> Any clue?
>> Serge.
>> Stack trace:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
Previous Topic:Overriding ItemPropertyDescriptor.setPropertyValue
Next Topic:Customized XML persistence
Current Time: Wed Nov 05 12:28:30 EST 2025
Powered by FUDForum. Page generated in 0.03655 seconds
