Home » Modeling » EMF » Update EMF Model
Update EMF Model [message #398521] Tue, 14 February 2006 04:50 Go to next message
Hi All,
I'd like to know if it is possible (and how) to update the EMF Model in
the following scenario:
1. Create an EMF Model from XSD schema
2. Work with EMF Model
3. Update XSD schema
4. I want to update the EMF model (not to create new model, I need to
keep my modifications in the Model) according to updated XSD schema
Thanks in advance!
Trifonov
Re: Update EMF Model [message #398526 is a reply to message #398521] Tue, 14 February 2006 05:33 Go to previous message
Trifonov,
rightclick the model file and select "Reload...". You will have to go
through the "New Model" wizard again, but your defaults will be preset.
After that you will have to regenerate the code. It's important that you
mark methods that you changed with @generated NOT. Otherwise your
changes will be overwritten when regenerating!
Oliver
Trifonov wrote:
> Hi All,
> Thanks in advance!
> Trifonov
Previous Topic:Dynamic use of EMF
Next Topic:EMF Documentation Plans?
Current Time: Wed Nov 05 11:12:04 EST 2025
Powered by FUDForum. Page generated in 0.23495 seconds
