| JMerge Support for Java5 Annotations [message #398054] |
Wed, 25 January 2006 15:17  |
Does JMerge have support for Java 5 Annotations? I have been looking but
can't find an answer for the right JMerge target anywhere, so here is an
example:
My JET templates are generating code with java 5 annotations.
* @generated
@Column(name="NM")
public String getName() {
return name;
I then use JMerge. Everything is working fine with JMerge except for
annotation. If I change the method body without removing the @gen tag the
code is properly blowna away. But, the same is not true if I change the
annotation.
| Re: JMerge Support for Java5 Annotations [message #398055 is a reply to message #398054] |
Wed, 25 January 2006 15:58   |
--------------040804000108030005050902
John,
No, this isn't supported yet, but we've started to work on it.
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=124372>
>example:
> * @generated
> @Column(name="NM")
> return name;
>annotation.
<html>
<head>
<title></title>
</head>
John,<br>
<br>
No, this isn't supported yet, but we've started to work on it.<a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=124372"><br>
</a>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=124372">https://bugs.eclipse.org/bugs/show_bug.cgi?id=124372</a><br>
</blockquote>
<br>
John Gilbert wrote:
<blockquote cite="middr8meo$7m1$1@utils.eclipse.org" type="cite">
<pre wrap="">Does JMerge have support for Java 5 Annotations? I have been looking but
example:
* @generated
@Column(name="NM")
return name;
annotation.
</pre>
</blockquote>
<br>
</body>
</html>
--------------040804000108030005050902--
| Re: JMerge Support for Java5 Annotations [message #412191 is a reply to message #412189] |
Fri, 17 August 2007 07:37  |
Catherine,
No, because 2.2 didn't have AST-based support and handling Java 5
annotations doesn't work with JDOM (or at least we never added any
support that would handle them).
Catherine Griffin wrote:
> I know that full support for Java 5 annotations is under dvelopment,
> but is there a way to set up the merge rules on 2.2 so that the
> annotation will be overwritten when the code is merged ?
> Thanks, Catherine.
FUDForum. Page generated in 0.03406 seconds
